sdftool errors and drive not showing up
Re: sdftool errors and drive not showing up
Post by d00zah »
speedygonzo5 wrote: Fri Sep 30, 2022 10:36 pm not sure what libredrive is, i usualy just use power dvd as i already own the software
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: M42M37B1234
Highest AACS version: 46
Harware support: Yes
Firmware support: No
Firmware version: 1.05
LibreDrive is what allows MakeMKV to get around FW imposed restrictions.
Guide recommends:
Recommended Firmware to flash for MakeMKV:
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
and v1.05 is indeed encrypred so 'enc' MUST be selected. (SHOULD auto-select).
Newer OEM Firmwares and encrypted:
New Encrypted firmware
List of Know Encrypted firmware (so far, any firmware with date in 2020 is encrypted)
HL-DT-ST-BD-RE_BH16NS40-NS50-1.05-N000600-212005061331.bin
BH.../WH... are the same HW.
BH = Retail/Bundled w/ SW
WH = OEM/bulk, White box
speedygonzo5
Post by speedygonzo5 »
well i know im doing it right,unless theres somthin i need to download for libredrive doesnt look tho, also installed the windows .net whatever,
must be the beta if theres a new beta or workaround let me know i literly just downloaded it doesnt work clean instal ect
i get the beta is bout to run out but thats fine just want to know if it works
and update the fw for mk- the link is broken wont download firmware pack de. is fine
Post by d00zah »
speedygonzo5 wrote: Fri Sep 30, 2022 10:53 pm well i know im doing it right,unless theres somthin i need to download for libredrive doesnt look tho, also installed the windows .net whatever,
Can't really understand that ramble, so I went back & read thru what you've previously posted...
speedygonzo5 wrote: Fri Sep 30, 2022 10:30 pm ...
and im using the de. files idk if makes a difference but might want to later be able to use another program like dvd to compare if can.
implies you are NOT 'doing it right'. Guide says:
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK ... DE does NOT = MK
IF you need it to work w. other SW, WH16NS60 1.0 is recommended (in the 'old' folder)
speedygonzo5
the mk files wont download failed download.
the all you need firmware pack on google drive same thing wont download, just thought id let you know
ur link is broken also broken im using windows so firewall shouldnt be an issue or server/host site or somthing is down
speedygonzo5 wrote: Fri Sep 30, 2022 11:24 pm the mk files wont download failed download.
i just checked the all you need firmware pack is up
Post by d00zah »
mk link is active for me... still.
speedygonzo5
thanks works
speedygonzo5
will i get 4k video quality with the trial or do need upgrade for that?
one other question i decrypted my bluray i own it into a file but i looked and nothing was there why is this what happend firmware was succeful?
MakeMKV v1.17.1 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDSVM/00000.svm' at offset '0'
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00370.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00371.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00378.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00379.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00391.mpls was added as title #0
Title #00372.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00374.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00376.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00373.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00375.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00377.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00380.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00382.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00384.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00386.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00381.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00383.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00385.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00387.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00392.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00394.mpls was added as title #1
File 00396.mpls was added as title #2
File 00395.mpls was added as title #3
File 00397.mpls was added as title #4
Title #00388.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00389.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00393.mpls was added as title #5
File 00390.mpls was added as title #6
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #7
File 00800.mpls was added as title #8
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title #00328.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00301.mpls was added as title #9
Title #00302.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00303.mpls was added as title #10
File 00304.mpls was added as title #11
File 00305.mpls was added as title #12
Title #00306.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00307.mpls has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00308.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00309.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00310.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00311.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00313.mpls was added as title #13
File 00318.mpls was added as title #14
File 00320.mpls was added as title #15
File 00321.mpls was added as title #16
File 00322.mpls was added as title #17
File 00335.mpls was added as title #18
File 00335.mpls(2) was added as title #19
File 00335.mpls(4) was added as title #20
Title #00336.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00340.mpls was added as title #21
Title #00341.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00342.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00343.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00344.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00347.mpls was added as title #22
Title #00348.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00349.mpls has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00350.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00353.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00354.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00800.mpls and was skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02451.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01927.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02559.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02450.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02608.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02636.m2ts was added as title #23
Title #02657.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02628.m2ts was added as title #24
File 02629.m2ts was added as title #25
File 02640.m2ts was added as title #26
File 02641.m2ts was added as title #27
Title #02646.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02647.m2ts was added as title #28
File 02648.m2ts was added as title #29
File 02659.m2ts was added as title #30
Title #02686.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02705.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02713.m2ts was added as title #31
File 02710.m2ts was added as title #32
File 02714.m2ts was added as title #33
speedygonzo5
black friday as soon i figure might be a 50percent off hope theres another bata so can do some through testing and compare nut anyways am intersted in becoming a new customer is the price of the software a onetime fee or is it renewed annualy?
also even though i donwgrade the firmware its not readding right ther eis a slight scratch in one my blurays actually all but there minor andshould be an issue firmward looks successful i and iv noticed its using direct disk acess/ is that why my movies arnt backing up?
the firmwar i instaled on a wh16ns40 is now using the recommneded firware as stated above
i should note that the price is amazing however im getting alot of errors and have limited time to see if what ha ve is doable
speedygonzo5
bump have some questions that need answered i have alot of blurays and dvds hangin around id like to backup as i tend to get them scratch somehow and is just easyer? also would love to have a beta trial as i only got to test it for half a day and got errors at moment it simply dont work for me
speedygonzo5 wrote: Sat Oct 01, 2022 2:27 pm bump have some questions that need answered i have alot of blurays and dvds hangin around id like to backup as i tend to get them scratch somehow and is just easyer? also would love to have a beta trial as i only got to test it for half a day and got errors at moment it simply dont work for me
Please slow down. You just sound aggressive and that won't help with people that are used to people being polite in this forum. And again. Don't wait for a discount. Never happend.
speedygonzo5
i dont mean to come cross as in a hurry im not really but i need to know things work otherwise im just going to send my drive back. dvdfab isnt an option cause its paid and they wont let you use there so called free downgrade tool to test the product wich is really strange cause why offer a free trial if you can use it? so that leaves mkv, the beta aint up now but i did the firmware thing succesfuly and for whatever reason it didnt rip my disk i dont have a huge collection of blurays but like to back um up cause i can be hard on disks
Ezatoka
Post by Ezatoka »
speedygonzo5 wrote: Sat Oct 01, 2022 6:36 pm dvdfab isnt an option cause its paid
Well, paying for a product helps the people creating the tool, which is probably more important with MakeMKV than with DVDfab.
There will be a new beta licence code soon. In the meantime just post what Makemkv says about yor drive. Libredrive enabled etc. Chip version? After everything is positive you can rip BDs and UHDs (internet access has to be enabled for that).
speedygonzo5
i updated this seen someone elses comments and decided to delete this part
Last edited by speedygonzo5 on Mon Oct 03, 2022 12:59 pm, edited 2 times in total.
