LV8HD
Post by LV8HD »
Hi @RESET_9999, I was trying the new version of the script. I tried to convert DTS-HD Master Audio 7.1 to DDP 7.1 via DEE, but apparently it doesn't work.
This is the log:
Codec AVOption drc_scale (percentage of dynamic range compression to apply) specified for input file #0 (C:\Muxing\HungerGames_IlCantoDellaRivolta_pt2_UHD_t00_chunk.mkv) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some decoder which was not actually used for any stream.
Stream mapping:
  Stream #0:1 (dca) -> pan:default
  pan:default -> Stream #0:0 (pcm_s24le)
Press [q] to stop, [?] for help
[Parsed_pan_0 @ 000001af1f4f52c0] Pure channel mapping detected: 0 1 2 3 6 7 4 5
Output #0, wav, to 'C:\Muxing\TEMP_folder\1.wav':
  Metadata:
    INAM            : HungerGames_IlCantoDellaRivolta_pt2_UHD
    ISFT            : Lavf59.16.100
  Chapters:
    Chapter #0:0: start 0.000000, end 300.299000
      Metadata:
        title           : Chapter 01
  Stream #0:0: Audio: pcm_s24le ([1][0][0][0] / 0x0001), 48000 Hz, 7.1, s32, 9216 kb/s
    Metadata:
      encoder         : Lavc59.18.100 pcm_s24le
size=  337848kB time=00:05:00.30 bitrate=9216.0kbits/s speed=7.68x
video:0kB audio:337848kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000054%
[2022-09-30 14:04:39.182] INFO: Dolby Encoding Engine, version: 5.2.1-5994839.
[2022-09-30 14:04:39.329] Features enabled by the license:  FUCKDOLBY, RAIN, internal, dolby_vision, dolby_audio, hdr10, ac4, sdr_plus.
[2022-09-30 14:04:39.909] ERROR: Unknown filter (pcm_to_ddp).
[2022-09-30 14:04:39.911] ERROR: Could not build workflow.
[2022-09-30 14:04:40.012] INFO: Average CPU usage in system: 8.3 %.
[2022-09-30 14:04:40.014] INFO: Average MEM usage in system: 3128 MB.
[2022-09-30 14:04:40.017] INFO: Max MEM usage in system: 3128 MB.
[2022-09-30 14:04:40.022] INFO: Average CPU used by DEE process: 0 %.
[2022-09-30 14:04:40.025] INFO: Max MEM used by DEE process: 0 MB.
[2022-09-30 14:04:40.030] --- Execution summary starts here ---
Time elapsed: 1.35101 seconds
Application exits with error code: 10
the script has completed...
IDK, it's working on my end... Use EAE instead, DEE sucks!!
LV8HD
Post by LV8HD »
RESET_9999 wrote: Fri Sep 30, 2022 2:58 pm IDK, it's working on my end... Use EAE instead, DEE sucks!!
Tried EAE and confirm it works.
Gatorman
Post by Gatorman »
I've created EAC3 7.1 files from THD with both EAE and DEE, mediainfo reports 7.1 channels for each. However, when I view the files in Plex, they are listed as EAC3 5.1. Is this the expected behavior? I do not have a device that can confirm current audio channels being played.
Gatorman wrote: Fri Sep 30, 2022 6:16 pm I've created EAC3 7.1 files from THD with both EAE and DEE, mediainfo reports 7.1 channels for each. However, when I view the files in Plex, they are listed as EAC3 5.1. Is this the expected behavior? I do not have a device that can confirm current audio channels being played.
yes 7.1 coreless EC3 show as 5.1 in plex but it actually plays in 7.1.
I confirmed using this 7.1 Channel test file:
https://drive.google.com/file/d/10VPaqP ... sp=sharing
Gatorman
Post by Gatorman »
RESET_9999 wrote: Fri Sep 30, 2022 6:27 pm
Sweet! Thank you.
if you want to test the audio quality between all the formats(to my ears, DEE sucks):
https://drive.google.com/file/d/1Q237ad ... sp=sharing
Manixx2020beyound wrote: Fri Sep 30, 2022 1:29 pm When using dee to encode hevc, how can we tell if forward reshaping has taken place what are the signs in the meta/Rpu to look for??
I assume if the adaptive reshaping flag is present/true it’s included in my meta can anyone answer??
@quietvoid correct me if i'm wrong..
The metadata here will always be the same when the reshaping is static like the Resolve P5 encodes ( itunes encodes too)
 "num_pivots_minus_2": [
      7,
      0,
      0
    "pred_pivot_value": [
        0,
        23,
        36,
        150,
        256,
        256,
        228,
        62,
        8
        0,
        1023
        0,
        1023
    "nlq_method_idc": null,
    "nlq_num_pivots_minus2": null,
    "nlq_pred_pivot_value": null,
    "num_x_partitions_minus1": 0,
    "num_y_partitions_minus1": 0
  "rpu_data_mapping": {
    "mapping_idc": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0
        0
        0
    "mapping_param_pred_flag": [
        false,
        false,
        false,
        false,
        false,
        false,
        false,
        false
        false
        false
    "num_mapping_param_predictors": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0
        0
        0
    "diff_pred_part_idx_mapping_minus1": [
    "poly_order_minus1": [
        1,
        1,
        1,
        1,
        1,
        1,
        1,
        1
        0
        0
    "linear_interp_flag": [
        false
        false
    "pred_linear_interp_value_int": [
    "pred_linear_interp_value": [
    "poly_coef_int": [
          -1,
          1,
          -5
          0,
          0,
          -4
          0,
          0,
          -1
          0,
          0,
          -1
          0,
          0,
          -1
          0,
          0,
          -1
          0,
          -2,
          0
          0,
          -2,
          0
          0,
          0
          0,
          0
    "poly_coef": [
          8387646,
          1593755,
          1132588
          55607,
          7100422,
          7114140
          135032,
          4423242,
          5240903
          207340,
          3656369,
          7325448
          300892,
          3196725,
          7892448
          468805,
          2716159,
          8237833
          6272571,
          6847591,
          6739653
          5742186,
          7559493,
          6564664
          1171714,
          6227579
          1058298,
          6211389
    "mmr_order_minus1": [
    "mmr_constant_int": [
    "mmr_constant": [
    "mmr_coef_int": [
    "mmr_coef": [
Gatorman
Post by Gatorman »
Is this normal when using EAE?
Screenshot (711).png (36.24 KiB) Viewed 16622 times
yes, I don't know why...
The EC3 file seems ok, I watched 1 or 2 movies and had no issues.
Gatorman
Post by Gatorman »
RESET_9999 wrote: Thu Sep 29, 2022 11:05 am
I'll look into adding an AAC 7.1 workflow but my only problem is that the LG TVs only support 5.1 channels with AAC tracks.
If you haven't seen it, you can use the qaac encoder from iTunes to get True Variable Bitrate AAC files.
-Cheers
legosoff
Post by legosoff »
Gatorman wrote: Fri Sep 30, 2022 9:45 pm
-Cheers
QAAC a lot of losses, better ffmpeg aac high bitrate 7.1 channels little with losses.
Gatorman
Post by Gatorman »
That's fair.
legosoff
Post by legosoff »
Hi, RESET_9999! I wanted you to do 7/4/2, 7/4/3, 7/4/4 and 7/4/5 command mode save y and n. I need to save RPU.
legosoff wrote: Mon Oct 03, 2022 10:04 am Hi, RESET_9999! I wanted you to do 7/4/2, 7/4/3, 7/4/4 and 7/4/5 command mode save y and n. I need to save RPU.
these workflows convert/inject without extracting the rpu so I won't do that since it would make the already long process much longer.
You can use 2-2 to extract the rpu of any file.
