FrostByte
Post by FrostByte » Thu Sep 29, 2022 2:22 pm
RESET_9999 wrote:
Thu Sep 29, 2022 1:32 pm
yeah i forgot to remove the bitrate user input. Bitrate will always be 1024kbps with EAE...
did you try the beta3 1.6.0 ? I also added a cmd that lists the stream ID so you can choose the right one.
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
I'll give the beta a shot today, thanks
legosoff
Post by legosoff » Thu Sep 29, 2022 2:37 pm
RESET_9999 wrote:
Thu Sep 29, 2022 2:06 pm
legosoff wrote:
Thu Sep 29, 2022 1:38 pm
LG 1C browser webOS AAC support 7.1, I checked it was a test done C mix L mix R mix Ls mix Rs mix Lb max Rb max LFE mix, it works there is sound.
Well, if you play a regular movie, of course, there will be sound in all the channels because the AVR upmix the channels.
But If you use the channel test file i posted on your C1 internal player, I would be surprised if the results were different than my C2.
Okay, good. I'll do it again wavs C.wav L.wav R.wav Ls.wav Rs.wav Lb.wav Rb.wav LFE.wav, VEGAS Pro make volume -59,9 dB C.wav L.wav R.wav Ls.wav Rs.wav LFE.wav, and volume 0 dB Lb.wav Rb.wav, DTS-HD Master Audio Suite, ffmpeg aac 7.1 on LG 1C it is running loudly Lb и Rb and C, L, R, Ls, Rs LFE sound no, so it works AAC 7.1 LG C1.
https://webostv.developer.lge.com/devel ... o-audio-60 AAC channels is unknown.
Post by RESET_9999 » Fri Sep 30, 2022 2:09 am
interestingly the C2 support lossless pcm with object audio(possibly truehd mat too) so I think i'm going to buy this EARC device (my avr is ARC) and hope Cavern add support for object based WAV from TrueHD input.(it can only do it for EAC3 right now)
https://github.com/VoidXH/Cavern
https://www.thenaudio.com/product/zone- ... processor/
MAT (MLP):
Max channels: 8
Supported sample rates (kHz): 48
Supports Dolby TrueHD, object audio PCM and channel-based PCM
Hash calculation not required for object audio PCM or channel-based PCM
FrostByte
Post by FrostByte » Fri Sep 30, 2022 11:14 am
RESET_9999 thanks for the 1.6.0 update. I'm getting EAC 7.1 with DTS:X now.
legosoff
Post by legosoff » Fri Sep 30, 2022 11:49 am
https://radikal.host/i/2022-09-30-14-45-24.amSs1 version 1.6.0
7/4/3 here is the error received, why?
Post by RESET_9999 » Fri Sep 30, 2022 11:59 am
looks like your BD doesnt have DV ?
I just tried with a DV BD:
1) MODE.1= Single-Track (p5, p8, p7)
2) MODE.2= Dual-Track (p7)
3) MODE.3= Demuxer (p5, p8, p7)
4) MODE.4= Apple iOS compatible MP4
5) MODE.5= back to main menu
Choice? [1,2,3,4,5]?4
                                         * CHOOSE A WORKFLOW *
-- DVH1 "P5" HDR10 BL: these workflows are for the AppleTV.
-- Because profile 5 is supposed to use a different colorspace, colors may not be accurate.
1) Workflow.1= MANUAL: Any P8/P5 HEVC/H265 + Any Audio(lossless audio included) + SRT subtitle
2) Workflow.2= Bluray Disc to Profile "5" + AC3/EC3
3) Workflow.3= Bluray Disc to Profile "5" + PCM
4) Workflow.4= MKV/TS Profile 7/8 to Profile "5" + AC3/EC3
5) Workflow.5= MKV/TS Profile 7/8 to Profile "5" + PCM
6) Workflow.6= HDR10 or HDR10plus to DoVi Profile "5" + AC3/EC3
7) Workflow.7= HDR10 or HDR10plus to DoVi Profile "5" + PCM
8) Workflow.8= back to main menu
Choice? [1,2,3,4,5,6,7,8]?3
-- If no external subtitles, just press enter to skip
-- Expect the first audio track to be lossless
Drag and drop your BD folder and press enter...
Drag and drop the main movie MPLS and press enter...
D:\samples\DTSHD\BDMV\PLAYLIST\00000.mpls
Drag and drop your SRT subtitle file(optional) and/or press enter...
DGDemux 1.0.0.59 by Donald A. Graft
Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA]
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
'D:\TEMP_folder\en.dts': Using the demultiplexer for the format 'DTS'.
'D:\TEMP_folder\en.dts' track 0: Using the output module for the format 'DTS'.
The file 'D:\TEMP_folder\au.mkv' has been opened for writing.
Progress: 100%
The cue entries (the index) are being written...
Multiplexing took 1 second.
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      57. 17.100 / 57. 17.100
  libavcodec     59. 18.100 / 59. 18.100
  libavformat    59. 16.100 / 59. 16.100
  libavdevice    59.  4.100 / 59.  4.100
  libavfilter     8. 24.100 /  8. 24.100
  libswscale      6.  4.100 /  6.  4.100
  libswresample   4.  3.100 /  4.  3.100
  libpostproc    56.  3.100 / 56.  3.100
Input #0, matroska,webm, from 'D:\TEMP_folder\au.mkv':
  Metadata:
    encoder         : libebml v1.4.2 + libmatroska v1.6.4
  Duration: 00:07:00.00, start: 0.000000, bitrate: 2255 kb/s
  Stream #0:0(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s16p (default)
    Metadata:
      BPS             : 2253739
      DURATION        : 00:06:59.999993280
      NUMBER_OF_FRAMES: 39375
      NUMBER_OF_BYTES : 118321016
      _STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream mapping:
  Stream #0:0 -> #0:0 (dts (dca) -> pcm_s32le (native))
Press [q] to stop, [?] for help
Output #0, mov, to 'D:\TEMP_folder\au.mov':
  Metadata:
    encoder         : Lavf59.16.100
  Stream #0:0(eng): Audio: pcm_s32le (in32 / 0x32336E69), 48000 Hz, 5.1(side), s32, 9216 kb/s (default)
    Metadata:
      BPS             : 2253739
      encoder         : Lavc59.18.100 pcm_s32le
size=  472503kB time=00:07:00.00 bitrate=9216.0kbits/s speed=58.3x
video:0kB audio:472500kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000538%
'D:\TEMP_folder\EL.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'D:\TEMP_folder\EL.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
The file 'D:\TEMP_folder\EL.mkv' has been opened for writing.
'D:\TEMP_folder\EL.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1920/1080.
Progress: 1%
Multiplexing took 0 seconds.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP_folder\el.chunk.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Parsing RPU file...
Exporting metadata...
Done.
converting and injecting RPU...
Rewriting file with interleaved EL NALUs..
Track Importing HEVC - Width 3840 Height 2160 FPS 480000/20020 SAR 1/1
OpenGOP detected - adjusting file brand
HEVC Import results: 1451 samples (18112 NALUs) - Slices: 800 I 3384 P 7424 B - 1951 SEI - 320 IDR - 480 CRA
HEVC Stream uses forward prediction - stream CTS offset: 2 frames
IsoMedia import au.mov - track ID 1 - Audio (SR 48000 - 6 channels)
0.500 secs Interleaving
the script has completed...
Appuyez sur une touche pour continuer...
legosoff
Post by legosoff » Fri Sep 30, 2022 12:19 pm
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
Progress: 100%
  Metadata:
    Metadata:
      BPS             : 2253739
Stream mapping:
  Metadata:
    Metadata:
      BPS             : 2253739
Progress: 1%
Progress: 100%
Parsing RPU file...
Done.
Yes, everything is ok.
Post by Manixx2020beyound » Fri Sep 30, 2022 1:29 pm
When using dee to encode hevc, how can we tell if forward reshaping has taken place what are the signs in the meta/Rpu to look for??
I assume if the adaptive reshaping flag is present/true it’s included in my meta can anyone answer??
Last edited by Manixx2020beyound on Fri Sep 30, 2022 5:16 pm, edited 2 times in total.
LV8HD
Post by LV8HD » Fri Sep 30, 2022 2:49 pm
Hi @RESET_9999, I was trying the new version of the script. I tried to convert DTS-HD Master Audio 7.1 to DDP 7.1 via DEE, but apparently it doesn't work.
This is the log:
Codec AVOption drc_scale (percentage of dynamic range compression to apply) specified for input file #0 (C:\Muxing\HungerGames_IlCantoDellaRivolta_pt2_UHD_t00_chunk.mkv) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some decoder which was not actually used for any stream.
Stream mapping:
  Stream #0:1 (dca) -> pan:default
  pan:default -> Stream #0:0 (pcm_s24le)
[Parsed_pan_0 @ 000001af1f4f52c0] Pure channel mapping detected: 0 1 2 3 6 7 4 5
Output #0, wav, to 'C:\Muxing\TEMP_folder\1.wav':
  Metadata:
    INAM            : HungerGames_IlCantoDellaRivolta_pt2_UHD
    ISFT            : Lavf59.16.100
  Chapters:
    Chapter #0:0: start 0.000000, end 300.299000
      Metadata:
        title           : Chapter 01
  Stream #0:0: Audio: pcm_s24le ([1][0][0][0] / 0x0001), 48000 Hz, 7.1, s32, 9216 kb/s
    Metadata:
      encoder         : Lavc59.18.100 pcm_s24le
size=  337848kB time=00:05:00.30 bitrate=9216.0kbits/s speed=7.68x
video:0kB audio:337848kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000054%
[2022-09-30 14:04:39.182] INFO: Dolby Encoding Engine, version: 5.2.1-5994839.
[2022-09-30 14:04:39.329] Features enabled by the license:  FUCKDOLBY, RAIN, internal, dolby_vision, dolby_audio, hdr10, ac4, sdr_plus.
[2022-09-30 14:04:39.909] ERROR: Unknown filter (pcm_to_ddp).
[2022-09-30 14:04:39.911] ERROR: Could not build workflow.
[2022-09-30 14:04:40.012] INFO: Average CPU usage in system: 8.3 %.
[2022-09-30 14:04:40.014] INFO: Average MEM usage in system: 3128 MB.
[2022-09-30 14:04:40.017] INFO: Max MEM usage in system: 3128 MB.
[2022-09-30 14:04:40.022] INFO: Average CPU used by DEE process: 0 %.
[2022-09-30 14:04:40.025] INFO: Max MEM used by DEE process: 0 MB.
[2022-09-30 14:04:40.030] --- Execution summary starts here ---
Time elapsed: 1.35101 seconds
Application exits with error code: 10
Post by RESET_9999 » Fri Sep 30, 2022 2:58 pm
IDK, it's working on my end... Use EAE instead, DEE sucks!!
LV8HD
Post by LV8HD » Fri Sep 30, 2022 4:31 pm
Tried EAE and confirm it works.
Gatorman
Post by Gatorman » Fri Sep 30, 2022 6:16 pm
I've created EAC3 7.1 files from THD with both EAE and DEE, mediainfo reports 7.1 channels for each. However, when I view the files in Plex, they are listed as EAC3 5.1. Is this the expected behavior? I do not have a device that can confirm current audio channels being played.
More reasons to collect physical media. Ugoos AM6B+.
Post by RESET_9999 » Fri Sep 30, 2022 6:27 pm
yes 7.1 coreless EC3 show as 5.1 in plex but it actually plays in 7.1.
I confirmed using this 7.1 Channel test file:
https://drive.google.com/file/d/10VPaqP ... sp=sharing
Gatorman
Post by Gatorman » Fri Sep 30, 2022 6:35 pm
Sweet! Thank you.
Post by RESET_9999 » Fri Sep 30, 2022 6:43 pm
if you want to test the audio quality between all the formats(to my ears, DEE sucks):
https://drive.google.com/file/d/1Q237ad ... sp=sharing
