Can't rip certain Law and Order SVU DVDs - Empty VIDEO_TS folder
chuckthetekkie
Post by chuckthetekkie » Thu Sep 29, 2022 8:34 pm
MakeMKV cannot open certain DVDs from the Law and Order series. If the VIDEO_TS folder is empty the app gives me a bunch of errors.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
udf: udf_get_node: bad allocation extension size in udf_node
Calculated BUP offset for VTS #8 does not match one in IFO header
I've never seen DVDs that had an empty VIDEO_TS folder yet play fine in a DVD player. Another DVD ripping app I use on my Mac called Mac DVD Ripper Pro (MDRP) has no issues extracting each episode.
What kind of protection is being used here?
Bokonon42
Re: Can't rip certain Law and Order SVU DVDs - Empty VIDEO_TS folder
Post by Bokonon42 » Fri Oct 14, 2022 4:32 pm
I believe I am encountering the same issue with Season 7 DVDs of Chicago Med.
Tried 1.17.2 on mac & win.
