legosoff wrote: Thu Sep 29, 2022 5:59 am Hi! I wanted AAC-LC audio, you will be able to create a new mode 7/4/8 Bluray Disc to Profile "5" + AAC-LC Quality 5.
Since PCM 32 bit is a lot of scales to spend, it would be better to AAC-LC it's good quality than EAC3.
right, DEE applies some DRC and it can't be disabled. It also inverts the side and back channels. What a joke Dolby, you're really the new Apple...
I'll look into adding an AAC 7.1 workflow but my only problem is that the LG TVs only support 5.1 channels with AAC tracks.
https://drive.google.com/file/d/10VPaqP ... sp=sharing
Also, have you tried the new workflow that use plex Easy Audio Encoder EAC3 7.1.
mad83 wrote: Thu Sep 29, 2022 8:14 am Hi,
@RESET_9999,
could it be possible to implement in muxing path (7,1,1) information about audio delay (negative/positive) due to fact that other audio languages could have some delays.
I mean to be possible to set delay for audio before muxing mp4 file with DV.
yes this is something I wanted to implement but I forgot about it.
legosoff
Post by legosoff »
RESET_9999 wrote: Thu Sep 29, 2022 11:05 am
I have LG 1C eARC SN11R, PCM 8 channels to play only music and no voice, there are 6 channels left sleeping. FLAC 8 channels, only music and no voice, there are 6 channels left sleeping. AAC-LC and EAC3 full channels 8 and 6 to play. No plex, I have a website using the browser DASH and HLS.
FrostByte
Post by FrostByte »
@RESET_9999
Been using the EAE option (6.3.8 ) to create EAC 7.1 tracks at 1024kbps and it seems to be working well. Thanks
Noticed the output looks like filename_7.1_.ec3
Just curious so I looked at Workflow.8 and it wants to put %bitrate% after the last underscore, but I don't see where it's supposed to get bitrate from which is always null. Internally it seems to default to 1024 just fine, so it's just the filename I guess
legosoff wrote: Thu Sep 29, 2022 12:24 pm I have LG 1C eARC SN11R, PCM 8 channels to play only music and no voice, there are 6 channels left sleeping. FLAC 8 channels, only music and no voice, there are 6 channels left sleeping. AAC-LC and EAC3 full channels 8 and 6 to play. No plex, I have a website using the browser DASH and HLS. https://cinemahd-deaf.org/
https://radikal.host/i/2022-09-29-15-20-07.aoIOO
did you try the channel test mkv I just shared?
On my LG C2, all the audio tracks pass the 7.1 test except AAC.
Also, the C2 EDID reports AAC support at max 5.1 while EAC3 it says 7.1.
FrostByte wrote: Thu Sep 29, 2022 12:56 pm @RESET_9999
yeah i forgot to remove the bitrate user input. Bitrate will always be 1024kbps with EAE...
did you try the beta3 1.6.0 ? I also added a cmd that lists the stream ID so you can choose the right one.
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
legosoff
Post by legosoff »
RESET_9999 wrote: Thu Sep 29, 2022 1:29 pm
No mkv, safari browser not support mkv, mp4 only. LG 1C browser webOS AAC support 7.1, I checked it was a test done C mix L mix R mix Ls mix Rs mix Lb max Rb max LFE mix, it works there is sound.
legosoff wrote: Thu Sep 29, 2022 1:38 pm LG 1C browser webOS AAC support 7.1, I checked it was a test done C mix L mix R mix Ls mix Rs mix Lb max Rb max LFE mix, it works there is sound.
Well, if you play a regular movie, of course, there will be sound in all the channels because the AVR upmix the channels.
But If you use the channel test file i posted on your C1 internal player, I would be surprised if the results were different than my C2.
FrostByte
Post by FrostByte »
RESET_9999 wrote: Thu Sep 29, 2022 1:32 pm
I'll give the beta a shot today, thanks
legosoff
Post by legosoff »
RESET_9999 wrote: Thu Sep 29, 2022 2:06 pm
Okay, good. I'll do it again wavs C.wav L.wav R.wav Ls.wav Rs.wav Lb.wav Rb.wav LFE.wav, VEGAS Pro make volume -59,9 dB C.wav L.wav R.wav Ls.wav Rs.wav LFE.wav, and volume 0 dB Lb.wav Rb.wav, DTS-HD Master Audio Suite, ffmpeg aac 7.1 on LG 1C it is running loudly Lb и Rb and C, L, R, Ls, Rs LFE sound no, so it works AAC 7.1 LG C1.
https://webostv.developer.lge.com/devel ... o-audio-60 AAC channels is unknown.
legosoff wrote: Thu Sep 29, 2022 2:37 pm Okay, good. I'll do it again wavs C.wav L.wav R.wav Ls.wav Rs.wav Lb.wav Rb.wav LFE.wav, VEGAS Pro make volume -59,9 dB C.wav L.wav R.wav Ls.wav Rs.wav LFE.wav, and volume 0 dB Lb.wav Rb.wav, DTS-HD Master Audio Suite, ffmpeg aac 7.1 on LG 1C it is running loudly Lb и Rb and C, L, R, Ls, Rs LFE sound no, so it works AAC 7.1 LG C1.
interestingly the C2 support lossless pcm with object audio(possibly truehd mat too) so I think i'm going to buy this EARC device (my avr is ARC) and hope Cavern add support for object based WAV from TrueHD input.(it can only do it for EAC3 right now)
https://github.com/VoidXH/Cavern
https://www.thenaudio.com/product/zone- ... processor/
MAT (MLP):
Max channels: 8
Supported sample rates (kHz): 48
Supports Dolby TrueHD, object audio PCM and channel-based PCM
Hash calculation not required for object audio PCM or channel-based PCM
FrostByte
Post by FrostByte »
RESET_9999 thanks for the 1.6.0 update. I'm getting EAC 7.1 with DTS:X now.
legosoff
Post by legosoff »
https://radikal.host/i/2022-09-30-14-45-24.amSs1 version 1.6.0
7/4/3 here is the error received, why?
legosoff wrote: Fri Sep 30, 2022 11:49 am https://radikal.host/i/2022-09-30-14-45-24.amSs1 version 1.6.0
looks like your BD doesnt have DV ?
I just tried with a DV BD:
1) MODE.1= Single-Track (p5, p8, p7)
2) MODE.2= Dual-Track (p7)
3) MODE.3= Demuxer (p5, p8, p7)
4) MODE.4= Apple iOS compatible MP4
5) MODE.5= back to main menu
Choice? [1,2,3,4,5]?4
                                         * CHOOSE A WORKFLOW *
-- DVH1 "P5" HDR10 BL: these workflows are for the AppleTV.
-- Because profile 5 is supposed to use a different colorspace, colors may not be accurate.
1) Workflow.1= MANUAL: Any P8/P5 HEVC/H265 + Any Audio(lossless audio included) + SRT subtitle
2) Workflow.2= Bluray Disc to Profile "5" + AC3/EC3
3) Workflow.3= Bluray Disc to Profile "5" + PCM
4) Workflow.4= MKV/TS Profile 7/8 to Profile "5" + AC3/EC3
5) Workflow.5= MKV/TS Profile 7/8 to Profile "5" + PCM
6) Workflow.6= HDR10 or HDR10plus to DoVi Profile "5" + AC3/EC3
7) Workflow.7= HDR10 or HDR10plus to DoVi Profile "5" + PCM
8) Workflow.8= back to main menu
Choice? [1,2,3,4,5,6,7,8]?3
-- If no external subtitles, just press enter to skip
-- Expect the first audio track to be lossless
Drag and drop your BD folder and press enter...
Drag and drop the main movie MPLS and press enter...
D:\samples\DTSHD\BDMV\PLAYLIST\00000.mpls
Drag and drop your SRT subtitle file(optional) and/or press enter...
DGDemux 1.0.0.59 by Donald A. Graft
Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA]
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
'D:\TEMP_folder\en.dts': Using the demultiplexer for the format 'DTS'.
'D:\TEMP_folder\en.dts' track 0: Using the output module for the format 'DTS'.
The file 'D:\TEMP_folder\au.mkv' has been opened for writing.
Progress: 100%
The cue entries (the index) are being written...
Multiplexing took 1 second.
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      57. 17.100 / 57. 17.100
  libavcodec     59. 18.100 / 59. 18.100
  libavformat    59. 16.100 / 59. 16.100
  libavdevice    59.  4.100 / 59.  4.100
  libavfilter     8. 24.100 /  8. 24.100
  libswscale      6.  4.100 /  6.  4.100
  libswresample   4.  3.100 /  4.  3.100
  libpostproc    56.  3.100 / 56.  3.100
Input #0, matroska,webm, from 'D:\TEMP_folder\au.mkv':
  Metadata:
    encoder         : libebml v1.4.2 + libmatroska v1.6.4
  Duration: 00:07:00.00, start: 0.000000, bitrate: 2255 kb/s
  Stream #0:0(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s16p (default)
    Metadata:
      BPS             : 2253739
      DURATION        : 00:06:59.999993280
      NUMBER_OF_FRAMES: 39375
      NUMBER_OF_BYTES : 118321016
      _STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream mapping:
  Stream #0:0 -> #0:0 (dts (dca) -> pcm_s32le (native))
Press [q] to stop, [?] for help
Output #0, mov, to 'D:\TEMP_folder\au.mov':
  Metadata:
    encoder         : Lavf59.16.100
  Stream #0:0(eng): Audio: pcm_s32le (in32 / 0x32336E69), 48000 Hz, 5.1(side), s32, 9216 kb/s (default)
    Metadata:
      BPS             : 2253739
      encoder         : Lavc59.18.100 pcm_s32le
size=  472503kB time=00:07:00.00 bitrate=9216.0kbits/s speed=58.3x
video:0kB audio:472500kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000538%
'D:\TEMP_folder\EL.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'D:\TEMP_folder\EL.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
The file 'D:\TEMP_folder\EL.mkv' has been opened for writing.
'D:\TEMP_folder\EL.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1920/1080.
Progress: 1%
Multiplexing took 0 seconds.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP_folder\el.chunk.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Parsing RPU file...
Exporting metadata...
Done.
converting and injecting RPU...
Rewriting file with interleaved EL NALUs..
Track Importing HEVC - Width 3840 Height 2160 FPS 480000/20020 SAR 1/1
OpenGOP detected - adjusting file brand
HEVC Import results: 1451 samples (18112 NALUs) - Slices: 800 I 3384 P 7424 B - 1951 SEI - 320 IDR - 480 CRA
HEVC Stream uses forward prediction - stream CTS offset: 2 frames
IsoMedia import au.mov - track ID 1 - Audio (SR 48000 - 6 channels)
0.500 secs Interleaving
the script has completed...
Appuyez sur une touche pour continuer...
legosoff
Post by legosoff »
RESET_9999 wrote: Fri Sep 30, 2022 11:59 am
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
Progress: 100%
  Metadata:
    Metadata:
      BPS             : 2253739
Stream mapping:
  Metadata:
    Metadata:
      BPS             : 2253739
Progress: 1%
Progress: 100%
Parsing RPU file...
Done.
Yes, everything is ok.
Post by Manixx2020beyound »
When using dee to encode hevc, how can we tell if forward reshaping has taken place what are the signs in the meta/Rpu to look for??
I assume if the adaptive reshaping flag is present/true it’s included in my meta can anyone answer??
Last edited by Manixx2020beyound on Fri Sep 30, 2022 5:16 pm, edited 2 times in total.
