right, DEE applies some DRC and it can't be disabled. It also inverts the side and back channels. What a joke Dolby, you're really the new Apple...legosoff wrote: Thu Sep 29, 2022 5:59 am Hi! I wanted AAC-LC audio, you will be able to create a new mode 7/4/8 Bluray Disc to Profile "5" + AAC-LC Quality 5.
Since PCM 32 bit is a lot of scales to spend, it would be better to AAC-LC it's good quality than EAC3.
I'll look into adding an AAC 7.1 workflow but my only problem is that the LG TVs only support 5.1 channels with AAC tracks.
https://drive.google.com/file/d/10VPaqP ... sp=sharing
Also, have you tried the new workflow that use plex Easy Audio Encoder EAC3 7.1.
yes this is something I wanted to implement but I forgot about it.mad83 wrote: Thu Sep 29, 2022 8:14 am Hi,
@RESET_9999,
could it be possible to implement in muxing path (7,1,1) information about audio delay (negative/positive) due to fact that other audio languages could have some delays.
I mean to be possible to set delay for audio before muxing mp4 file with DV.
