theprinz2023
Post by theprinz2023 » Wed Sep 28, 2022 6:26 pm
Hello everyone I hope someone can help me I start the script and take these options 7-1-2 at the end I always get this message Error: The file 'E:\lost\DoVi_Scripts_1.5.6_TOOLS\DoVi_Scripts\\TEMP_folder\en.dts' could not be opened for reading: open file error.
Source file "E:\lost\DoVi_Scripts_1.5.6_TOOLS\DoVi_Scripts\\TEMP_folder\au.mkv" not found.
muxing into a MP4 profile 8 DoVi file. Be patient, it can take a while. 40min+ on slow HDD!
ERRORS! Can't open input file: E:\lost\DoVi_Scripts_1.5.6_TOOLS\DoVi_Scripts\\TEMP_folder\audio.ac3
Error parsing command line! I've tried several times now but without success
kazuma
Post by kazuma » Wed Sep 28, 2022 8:37 pm
reset_9999 why i'm getting this error with version 1.5.9.? i'm getting this with 4-2-2 and 4-2-3. i tried a mkv file and ts.
https://ibb.co/0yndCxc
Post by RESET_9999 » Wed Sep 28, 2022 8:51 pm
yeah so many problems when the script is on a C:\ drive that I can't reproduce on my system. If you can, use the script on a non-windows drive. Not only it will be faster but you wont slow down your PC.
In your picture, it fails to detect if the input is dual tracks so if your input is single track, you can ignore it.
you can also try v1.6.0.beta.2. that i just posted here. I changed the temp folder behavior, maybe that will fix your problem
kazuma
Post by kazuma » Wed Sep 28, 2022 9:00 pm
yeah, i used a extern hdd before for this process without problems. i didn't expect that the C station don't work, learned again. thank you i gonna try you're new version.
BadSector81
Post by BadSector81 » Wed Sep 28, 2022 9:29 pm
RESET_9999 wrote:
Mon Sep 26, 2022 10:01 pm
BadSector81 wrote:
Mon Sep 26, 2022 9:29 pm
Try to run DoVi Scripts from another drive. Not from your system C:
The same happened to me and it solved. I still got error message but I can find the picture in the output folder.
ha, I know why.
will fix it in the next version.
Hi! I tested beta and it was perfect! Thanks!!
Post by RESET_9999 » Wed Sep 28, 2022 11:04 pm
Does your Bluray Disc input contain at least 1 DTS or THD english track?
I know some discs only have LPCM audio and this is not supported "yet".
which BD is it?
legosoff
Post by legosoff » Thu Sep 29, 2022 5:59 am
Hi! I wanted AAC-LC audio, you will be able to create a new mode 7/4/8 Bluray Disc to Profile "5" + AAC-LC Quality 5.
Since PCM 32 bit is a lot of scales to spend, it would be better to AAC-LC it's good quality than EAC3.
https://i.ibb.co/2c7DLpz/2022-09-22-17-32-57.png - The original TrueHD 7.1
https://i.ibb.co/gFHQLg3/1.png - EAC3 7.1 1536 bitrate
https://i.ibb.co/0DCkHj9/2.png - AAC-LC 7.1 1640 bitrate
mad83
Post by mad83 » Thu Sep 29, 2022 8:14 am
@RESET_9999,
could it be possible to implement in muxing path (7,1,1) information about audio delay (negative/positive) due to fact that other audio languages could have some delays.
I mean to be possible to set delay for audio before muxing mp4 file with DV.
Post by RESET_9999 » Thu Sep 29, 2022 11:05 am
right, DEE applies some DRC and it can't be disabled. It also inverts the side and back channels. What a joke Dolby, you're really the new Apple...
I'll look into adding an AAC 7.1 workflow but my only problem is that the LG TVs only support 5.1 channels with AAC tracks.
https://drive.google.com/file/d/10VPaqP ... sp=sharing
Also, have you tried the new workflow that use plex Easy Audio Encoder EAC3 7.1.
@RESET_9999,
yes this is something I wanted to implement but I forgot about it.
legosoff
Post by legosoff » Thu Sep 29, 2022 12:24 pm
I have LG 1C eARC SN11R, PCM 8 channels to play only music and no voice, there are 6 channels left sleeping. FLAC 8 channels, only music and no voice, there are 6 channels left sleeping. AAC-LC and EAC3 full channels 8 and 6 to play. No plex, I have a website using the browser DASH and HLS.
FrostByte
Post by FrostByte » Thu Sep 29, 2022 12:56 pm
@RESET_9999
Been using the EAE option (6.3.8 ) to create EAC 7.1 tracks at 1024kbps and it seems to be working well. Thanks
Noticed the output looks like filename_7.1_.ec3
Just curious so I looked at Workflow.8 and it wants to put %bitrate% after the last underscore, but I don't see where it's supposed to get bitrate from which is always null. Internally it seems to default to 1024 just fine, so it's just the filename I guess
Post by RESET_9999 » Thu Sep 29, 2022 1:29 pm
I have LG 1C eARC SN11R, PCM 8 channels to play only music and no voice, there are 6 channels left sleeping. FLAC 8 channels, only music and no voice, there are 6 channels left sleeping. AAC-LC and EAC3 full channels 8 and 6 to play. No plex, I have a website using the browser DASH and HLS. https://cinemahd-deaf.org/
https://radikal.host/i/2022-09-29-15-20-07.aoIOO
did you try the channel test mkv I just shared?
On my LG C2, all the audio tracks pass the 7.1 test except AAC.
Also, the C2 EDID reports AAC support at max 5.1 while EAC3 it says 7.1.
Post by RESET_9999 » Thu Sep 29, 2022 1:32 pm
@RESET_9999
yeah i forgot to remove the bitrate user input. Bitrate will always be 1024kbps with EAE...
did you try the beta3 1.6.0 ? I also added a cmd that lists the stream ID so you can choose the right one.
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
legosoff
Post by legosoff » Thu Sep 29, 2022 1:38 pm
No mkv, safari browser not support mkv, mp4 only. LG 1C browser webOS AAC support 7.1, I checked it was a test done C mix L mix R mix Ls mix Rs mix Lb max Rb max LFE mix, it works there is sound.
Post by RESET_9999 » Thu Sep 29, 2022 2:06 pm
Well, if you play a regular movie, of course, there will be sound in all the channels because the AVR upmix the channels.
But If you use the channel test file i posted on your C1 internal player, I would be surprised if the results were different than my C2.
