Strange, is it only showing green screen on Apple or is it green on all DV capable device?
Thank you both for confirming this is needed for all FEL discs. Time to reprocess again.
RESET_9999 wrote: ↑Tue Sep 27, 2022 3:46 pmyes thats correct and you should always remove the mapping for FEL to p8
sw5163 wrote: ↑Tue Sep 27, 2022 5:19 pmYou can just manually remove those additional mapping in that p8 file, saves the redownloading time.
Sometimes I find it difficult to remux Blu-ray disc when there is a single video stream that consists of multiple m2ts files.
So I actually prefer FEL remux version.
Only the first part and remove_mapping of that post is useful, the rest part regarding MMR and polynomial mapping discussion is just me being stupid, please ignore. But I would like to express my thanks to @quietvoid and @RESET_9999 and you all, really teach me a lot.Ibuprofen wrote: ↑Tue Sep 27, 2022 3:12 pmThis thread says that FEL discs need an additional step to remove_mapping that strips out the additional EL processing.
https://github.com/quietvoid/dovi_tool/discussions/168![]()
RESET_9999 wrote: ↑Tue Sep 27, 2022 7:54 pmthen the problem is something else... what movie is it?
also at this point, a sample would be useful
Valerian.and.the.City.of.a.Thousand.Planets.2017.2160p.UHD.DV.BDRemux.mkv
Format : Matroska
Format version : Version 4
File size : 72.9 GiB
Duration : 2 h 17 min
Overall bit rate mode : Variable
Overall bit rate : 76.2 Mb/s
Movie name : Valerian and the City of a Thousand Planets (2017)
Encoded date : UTC 2022-09-06 10:28:44
Writing application : mkvmerge v69.0.0 ('Day And Age') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Cover : Yes
Attachments : cover.jpg
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 44.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.224
Stream size : 42.6 GiB (58%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 632 cd/m2
Maximum Frame-Average Light : 298 cd/m2
Here, it's not mine, someone made it apparently a problem. So it's better for me to have a Blu-ray Disk or remux m2ts sure calmly.
No, my LG 1C DV works fine, and Apple only has a green screen. Here is a Blu-Ray Disk on 7/4/2 excellent Apple.
which mode?sw5163 wrote: ↑Tue Sep 27, 2022 5:19 pmYou can just manually remove those additional mapping in that p8 file, saves the redownloading time.
is (last dev) ffmpeg still ok for demuxing?
ffmpeg \
-hide_banner -y\
-i "$c" \
-map 0:0 -c:v copy -bsf:v hevc_mp4toannexb -f hevc bl.hevc \
-map 0:1 -c:v copy -bsf:v hevc_mp4toannexb -f hevc el.hevc \
-map "#0x$2" -c:a copy audio.ac3 && \
tsmuxer doviac3.meta /Dovi/"$name".ts
try this: https://drive.google.com/file/d/1Zw2_v1 ... sp=sharing
I hope it's not the new mp4box causing issues...
Yes, great, millions of colored. How do you do it?RESET_9999 wrote: ↑Wed Sep 28, 2022 11:11 amtry this: https://drive.google.com/file/d/1Zw2_v1 ... sp=sharing
I used the original bluray and 7-4-3
then can you specify what you mean here exactly?
Yes, it has already been done, 7 profile is being executed after 7/4/4, the green screen is still again.
No, if the 8.1 or 7 profile is on it will be 7-4-4 still green screen. Blu-ray originals are of course excellent 7-4-3.RESET_9999 wrote: ↑Wed Sep 28, 2022 12:06 pmI used the original bluray and 7-4-3
then can you specify what you mean here exactly?Yes, it has already been done, 7 profile is being executed after 7/4/4, the green screen is still again.
https://radikal.host/i/2022-09-28-15-19-46.Y6jze
profile 8 = right, as said before (i might add support)legosoff wrote: ↑Wed Sep 28, 2022 12:11 pmNo, if the 8.1 or 7 profile is on it will be 7-4-4 still green screen. Blu-ray originals are of course excellent 7-4-3.
but what profile 7 file did you try? the mapping is removed when input is P7, I just tried and the file is identical to the sample i just gave you
Yes, profile 7 is still a green screen.RESET_9999 wrote: ↑Wed Sep 28, 2022 12:27 pmprofile 8 = right, as said before (i might add support)legosoff wrote: ↑Wed Sep 28, 2022 12:11 pmNo, if the 8.1 or 7 profile is on it will be 7-4-4 still green screen. Blu-ray originals are of course excellent 7-4-3.
I dont think you understand me.
The file you are trying to process is profile 8 and as I said my script assumes the mapping was already removed.
So what profile 7 file did you try?
-- DVH1 "P5" HDR10 BL: these workflows are for the AppleTV.
-- Because profile 5 is supposed to use a different colorspace, colors may not be accurate.
1) Workflow.1= MANUAL: Any P8/P5 HEVC/H265 + Any Audio(lossless audio included) + SRT subtitle
2) Workflow.2= Bluray Disc to Profile "5" + AC3/EC3
3) Workflow.3= Bluray Disc to Profile "5" + PCM
4) Workflow.4= MKV/TS Profile 7/8 to Profile "5" + AC3/EC3
5) Workflow.5= MKV/TS Profile 7/8 to Profile "5" + PCM
6) Workflow.6= HDR10 or HDR10plus to DoVi Profile "5" + AC3/EC3
7) Workflow.7= HDR10 or HDR10plus to DoVi Profile "5" + PCM
8) Workflow.8= back to main menu
Choice? [1,2,3,4,5,6,7,8]?4
-- This workflow convert P7/P8 MKV TS M2TS to fake P5 for the ATV
-- Convert or use existing AC3/EC3 audio
Drag and drop your MKV/TS file and press enter...D:\00000_ST-DL.mkv
Dolby Vision / SMPTE ST 2086
MKV, 1 video track, 1 audio track, 0:07:00, 24p /1.001
1: h265/HEVC, 2160p24 /1.001 (16:9), 10 bits
2: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
v01 Extracting video track number 1...
a02 Extracting audio track number 2...
v01 Creating file "D:\TEMP_folder\ - 1 - h265, 2160p24.h265"...
a02 Creating file "D:\TEMP_folder\ - 2 - DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz.dtsma"...
Video track 1 contains 14355 frames.
eac3to processing took 5 seconds.
Done.
Reordering metadata... Done.
EditConfig {
"mode": 0,
"remove_cmv4": true,
"remove_mapping": true
Parsing RPU file...
Removing CMv4.0 metadata...
Removing polynomial/MMR mapping...
Final metadata length: 7197
Writing RPU file...
injecting RPU...
Parsing RPU file...
Processing input video for frame order info...
Rewriting file with interleaved RPU NALs..
mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
'D:\TEMP_folder\en.dtsma': Using the demultiplexer for the format 'DTS'.
'D:\TEMP_folder\en.dtsma' track 0: Using the output module for the format 'DTS'.
The file 'D:\TEMP_folder\THD.mkv' has been opened for writing.
Progress: 100%
The cue entries (the index) are being written...
Multiplexing took 0 seconds.
MKA, 1 audio track, 0:07:00
1: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz
a01 Extracting audio track number 1...
a01 Decoding with libDcaDec DTS Decoder...
a01 libDcaDec reported the warning "XLL output not lossless".
a01 Remapping channels...
a01 Encoding AC3 <640kbps> with libAften...
a01 Creating file "D:\TEMP_folder\audio.ac3"...
a01 The original audio track has a constant bit depth of 16 bits.
eac3to processing took 9 seconds.
Done.
Track Importing HEVC - Width 3840 Height 2160 FPS 24000/1001 SAR 1/1
OpenGOP detected - adjusting file brand
HEVC Import results: 7197 samples (89186 NALUs) - Slices: 3224 I 17224 P 37128 B - 9212 SEI - 952 IDR - 2272 CRA
HEVC Stream uses forward prediction - stream CTS offset: 2 frames
Track Importing AC-3 - SampleRate 48000 Num Channels 6
0.500 secs Interleaving
the script has completed...
Appuyez sur une touche pour continuer...
I understand you, right 8 профиль mapping was already removed. The topic is closed.RESET_9999 wrote: ↑Wed Sep 28, 2022 12:36 pmI dont think you understand me.
https://radikal.host/i/2022-09-28-16-02-26.Y6sra
So with that P7 file , you're saying you're getting a green screen?
v1.5.9 actually removes mapping blindly as soon as it detect P7 regardless of MEL/FEL, so when the input is P7, the output will always be P8 without mapping.
In v1.6.0, the mapping will be removed only when the script detect FEL input. (also speed improvement)
v1.6.0.beta.2
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
v1.6.0.beta.2
