sdftool errors and drive not showing up
speedygonzo5
Post by speedygonzo5 »
i get errors red warning box saying
unhandled exception has occured in your application. click continue and application will ignore error.
LG wh16ns40
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
Re: sdftool errors and drive not showing up
speedygonzo5 wrote: Tue Sep 27, 2022 7:46 pm i get errors red warning box saying
unhandled exception has occured in your application. click continue and application will ignore eroor.....
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.4.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
Try providing some useful info:
Are you using Windows 10 or 11?
Do you have MakeMKV v1.15.2 or above installed in the default location (on C: drive)?
What is drive model and firmware version?
How is drive connected to PC?
Does your PC user account have admin privileges?
speedygonzo5
actualy i dont have makemkv,
im using windows 10
drive model is wh16ns40
as far as firmware i dont know cant read it, and i ran the program in admin mode
drive is internal sata
Post by d00zah »
speedygonzo5 wrote: Tue Sep 27, 2022 10:26 pm actualy i dont have makemkv,
im using windows 10
The SDFtool Flasher is a front-end for the MakeMKV sdftool... no MakeMKV, no back-end functionality.
Requirements:
Windows 10 64 bit version
MakeMKV v1.15.1 (or higher) installed
.NET Framework 4.7.2 **only for SDFtool Flasher v1.2.0**
And just to be safe... what month/year was the wh16ns40 manufactured?
MakeMKV can 'tell' you.
speedygonzo5
2022 jan sn50 is the svc code
question does makemkv have function to use rtx graphics card to work with the file i think dvdfab does
Post by d00zah »
speedygonzo5 wrote: Tue Sep 27, 2022 11:05 pm question does makemkv have function to use rtx graphics card to work with the file i think dvdfab does
As MakeMKV doesn't do any encoding, I don't see why it would need to.
edit: well, maybe audio, but no... not terribly resource-intensive.
speedygonzo5
can i backup the firmware the drive came with is that firmware dumpif cant and need to revert what should i do and wich firmware is apprpriate for a wh16ns40 also i get error 0x8f056103 do i use write firmware or recover?
if can get this workin can maybe purchase when it goes on sale
and am using newest beta makemkv trial
windows 10
sn50
Post by d00zah »
speedygonzo5 wrote: Fri Sep 30, 2022 9:37 pm can i backup the firmware the drive came with is that firmware dumpif cant and need to revert what should i do and wich firmware is apprpriate for a wh16ns40 also i get error 0x8f056103 do i use write firmware or recover?
windows 10
sn50
FW v1.05 is encrypted IIRC, so backup is not possible. Refer to Ultimate UHD Drives Flashing Guide Updated 2022 for recommended FW.
On the off chance you need to revert... why not go to the source?
speedygonzo5
oh ok, well what about thye error im getting why cant i use the trial or downgrade the makemkv?
Post by d00zah »
speedygonzo5 wrote: Fri Sep 30, 2022 10:09 pm oh ok, well what about thye error im getting why cant i use the trial or downgrade the makemkv?
The embedded beta key expires right around now, so you'll need to wait until Mike posts a new one & apply it. Always found here... MakeMKV is free while in beta.
speedygonzo5
no it worked i still get that error though and now an additional redbox it even ripped one of my blurays but wouldnt play the main file im guessing cause the patcher isnt working
Post by d00zah »
speedygonzo5 wrote: Fri Sep 30, 2022 10:20 pm no it worked i still get that error though and now an additional redbox
'enc' correctly selected? image? Have no idea what the 'redbox' might say? NO disc in drive, right? Please copy/paste MakeMKV LibreDrive/Drive info here.
speedygonzo5
it worked without disk in drive but after it was done i got error code 0x8f052603
update now back in mkv and checking firmware was not written so0 is an error issue
yea its marked check
and im using the de. files idk if makes a difference but might want to later be able to use another program like dvd to compare if can. i mean due to the price id prefer make mkv but i wanna see if the other software has tools makemkv dont, cant use there trial for whatever reason can change /flash the drive without buying and not going to do that for now
Last edited by speedygonzo5 on Fri Sep 30, 2022 10:38 pm, edited 2 times in total.
Post by d00zah »
speedygonzo5 wrote: Fri Sep 30, 2022 10:30 pm it worked without disk in drive but after it was done i got error code 0x8f052603
yea enc is unmarked as it says thats only for one type of drive
speedygonzo5
not sure what libredrive is, i usualy just use power dvd as i already own the software. i can try the mk firmware but i tried downloading it and said download failed
