yes thats correct and you should always remove the mapping for FEL to p8
I get you, you're right. These films of his were ready on 08.06, BL + RU, apparently there is a problem, and the other films that are there are working fine. It's most dvh.08.06, BL+RU someone did it wrong. I decide to download the Blu-ray disc, solely trusting myself.RESET_9999 wrote: Tue Sep 27, 2022 3:45 pmmapping removal is only for Profile 7 input. When input is P8, my script assumes that the mapping was already removed.legosoff wrote: Tue Sep 27, 2022 8:26 am bluray disc folder yes. 7-4-2 or 7-4-3 excellent. no problem.
But one mkv problem dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 7-4-4 after that, the green screen again. How do I fix it on profile 7? Thank you.
I'll check if i can add support for p8 that still have the mapping
You can just manually remove those additional mapping in that p8 file, saves the redownloading time.legosoff wrote: Tue Sep 27, 2022 4:04 pm It's most dvh.08.06, BL+RU someone did it wrong. I decide to download the Blu-ray disc, solely trusting myself.
Sometimes I find it difficult to remux Blu-ray disc when there is a single video stream that consists of multiple m2ts files.
So I actually prefer FEL remux version.
Only the first part and remove_mapping of that post is useful, the rest part regarding MMR and polynomial mapping discussion is just me being stupid, please ignore. But I would like to express my thanks to @quietvoid and @RESET_9999 and you all, really teach me a lot.Ibuprofen wrote: Tue Sep 27, 2022 3:12 pm This thread says that FEL discs need an additional step to remove_mapping that strips out the additional EL processing.
https://github.com/quietvoid/dovi_tool/discussions/168
You could manually fix it as @sw5163 said but starting from the original untouched disc is always the best workflow.legosoff wrote: Tue Sep 27, 2022 4:04 pm I decide to download the Blu-ray disc, solely trusting myself.
Well, that's a bad idea because most of the remux from seamless branching discs on torrent are done incorrectly with makemkv or mkvtoolnix.sw5163 wrote: Tue Sep 27, 2022 5:19 pm Sometimes I find it difficult to remux Blu-ray disc when there is a single video stream that consists of multiple m2ts files.
The only way to properly remux seamless disc is with DGdemux or Tsmuxer.
btw in my script, you won't even know when the disc is seamless branching, the whole process is automated regardless of the disc.
Interesting, will look into that, thanks!RESET_9999 wrote: Tue Sep 27, 2022 5:56 pm Well, that's a bad idea because most of the remux from seamless branching discs on torrent are done incorrectly with makemkv or mkvtoolnix.
What do you mean by that? Are you suggesting that the way MakeMKV mashes segments together is wrong in some way?RESET_9999 wrote: Tue Sep 27, 2022 5:56 pm Well, that's a bad idea because most of the remux from seamless branching discs on torrent are done incorrectly with makemkv or mkvtoolnix.
yes unless makemkv was updated, It doesnt remove the gap in the lossless audio track which can cause some playback problems.dcoke22 wrote: Tue Sep 27, 2022 6:31 pm What do you mean by that? Are you suggesting that the way MakeMKV mashes segments together is wrong in some way?
Yes, it has already been done, 7 profile is being executed after 7/4/4, the green screen is still again.RESET_9999 wrote: Tue Sep 27, 2022 5:56 pmYou could manually fix it as @sw5163 said but starting from the original untouched disc is always the best workflow.legosoff wrote: Tue Sep 27, 2022 4:04 pm I decide to download the Blu-ray disc, solely trusting myself.
then the problem is something else... what movie is it?legosoff wrote: Tue Sep 27, 2022 7:23 pm Yes, it has already been done, 7 profile is being executed after 7/4/4, the green screen is still again.
also at this point, a sample would be useful
Strange, is it only showing green screen on Apple or is it green on all DV capable device?
Thank you both for confirming this is needed for all FEL discs. Time to reprocess again.
RESET_9999 wrote: Tue Sep 27, 2022 3:46 pmyes thats correct and you should always remove the mapping for FEL to p8
sw5163 wrote: Tue Sep 27, 2022 5:19 pmYou can just manually remove those additional mapping in that p8 file, saves the redownloading time.legosoff wrote: Tue Sep 27, 2022 4:04 pm It's most dvh.08.06, BL+RU someone did it wrong. I decide to download the Blu-ray disc, solely trusting myself.
https://github.com/quietvoid/dovi_tool/discussions/168![]()
RESET_9999 wrote: Tue Sep 27, 2022 7:54 pmthen the problem is something else... what movie is it?legosoff wrote: Tue Sep 27, 2022 7:23 pm Yes, it has already been done, 7 profile is being executed after 7/4/4, the green screen is still again.
Valerian.and.the.City.of.a.Thousand.Planets.2017.2160p.UHD.DV.BDRemux.mkv
Format : Matroska
Format version : Version 4
File size : 72.9 GiB
Duration : 2 h 17 min
Overall bit rate mode : Variable
Overall bit rate : 76.2 Mb/s
Movie name : Valerian and the City of a Thousand Planets (2017)
Encoded date : UTC 2022-09-06 10:28:44
Writing application : mkvmerge v69.0.0 ('Day And Age') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Cover : Yes
Attachments : cover.jpg
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 44.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.224
Stream size : 42.6 GiB (58%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 632 cd/m2
Maximum Frame-Average Light : 298 cd/m2
Here, it's not mine, someone made it apparently a problem. So it's better for me to have a Blu-ray Disk or remux m2ts sure calmly.
No, my LG 1C DV works fine, and Apple only has a green screen. Here is a Blu-Ray Disk on 7/4/2 excellent Apple.
which mode?sw5163 wrote: Tue Sep 27, 2022 5:19 pmYou can just manually remove those additional mapping in that p8 file, saves the redownloading time.legosoff wrote: Tue Sep 27, 2022 4:04 pm It's most dvh.08.06, BL+RU someone did it wrong. I decide to download the Blu-ray disc, solely trusting myself.
is (last dev) ffmpeg still ok for demuxing?
ffmpeg \
-hide_banner -y\
-i "$c" \
-map 0:0 -c:v copy -bsf:v hevc_mp4toannexb -f hevc bl.hevc \
-map 0:1 -c:v copy -bsf:v hevc_mp4toannexb -f hevc el.hevc \
-map "#0x$2" -c:a copy audio.ac3 && \
tsmuxer doviac3.meta /Dovi/"$name".ts
