MAKEMKV FOLDER
JPV119
MAKEMKV FOLDER
Post by JPV119 »
New to this forum and can't seem to find an answer for this.
I only use the 'backup' button and make full backups of my 4k disks
and seems to work perfectly so far.
What is the 'MAKEMKV' folder it adds to the backup for?
Can this be deleted or should I leave it?
Thanks,
Jason V
Re: MAKEMKV FOLDER
It stores things necessary to further process the backup via MakeMKV, if you wish to do that. Delete it if you're not going further, as it isn't needed otherwise.
Re: MAKEMKV FOLDER
Mike has posted about this in the past: Directory Structure for Backup
Re: MAKEMKV FOLDER
Delete it if you use it with an Oppo or Oppo clone. These devices don't like any other folder besides BDMV and CERTIFICATE.
