Yes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?RESET_9999 wrote: Mon Sep 26, 2022 8:33 pm When there is no black bars, L5 should be set to 0.
If your 1080p is not an itunes web-dl, it should be already set to 0. You can quickly verify any DV metadata with my script : (2-3)
BadSector81
Try to run DoVi Scripts from another drive. Not from your system C:LV8HD wrote: Mon Sep 26, 2022 4:31 pmI did, as you can see it is in my pip listRESET_9999 wrote: Mon Sep 26, 2022 4:22 pminteresting, it fails when it tries to save the data into a graph, I have never seen that error and I didn't write that python script so I can't really help you here.( I assure you it's working on my PC)LV8HD wrote: Mon Sep 26, 2022 4:11 pm Hi, I'm kind of new to this script, and every time I try to measure something (HDR10, HDR10Plus or DoVi) I get many errors. I don't know why, since I'm pretty sure I installed all the required py modules. Anyway, this is the log
Could someone help me?
did you install this version of color science?
https://pypi.org/project/colour-science
The same happened to me and it solved. I still got error message but I can find the picture in the output folder.
right , for that case, you only have to convert P5 to P8.hell001 wrote: Mon Sep 26, 2022 8:43 pm Yes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?
I suggest you always check the dv source L5 before doing a Hybrid though. Because you will notice that a lot of DV web-dl has incorrect or missing L5.
the path is still 4-2-3 for this? with your dv version 1.5.9?RESET_9999 wrote: Mon Sep 26, 2022 5:52 pmyes, unless the language is one that I didn't implement.
By default, it will pick up the English audio/subs
ha, I know why.BadSector81 wrote: Mon Sep 26, 2022 9:29 pm Try to run DoVi Scripts from another drive. Not from your system C:
will fix it in the next version.
I dont know, the worfklow order changed a bit in the latest version..kazuma wrote: Mon Sep 26, 2022 9:56 pm the path is still 4-2-3 for this? with your dv version 1.5.9?
what device do you play DV again?
So basically do the same process as normal even though the DV is 1080p? The active area is the same?RESET_9999 wrote: Mon Sep 26, 2022 9:40 pmright , for that case, you only have to convert P5 to P8.hell001 wrote: Mon Sep 26, 2022 8:43 pm Yes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?
Guys please, try this non-official version:
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
yeshell001 wrote: Mon Sep 26, 2022 10:12 pm So basically do the same process as normal even though the DV is 1080p? The active area is the same?
LG C9 oled.RESET_9999 wrote: Mon Sep 26, 2022 10:02 pmI dont know, the worfklow order changed a bit in the latest version..kazuma wrote: Mon Sep 26, 2022 9:56 pm the path is still 4-2-3 for this? with your dv version 1.5.9?
option 1 (lossless but can be unstable)
mkv P7 input: 7-2-3
bdmv input: 7-2-2
option 2 (quality loss when input is FEL but 100% stable)
mkv P7 input: 4-2-2
bdmv input: 4-1-1
As far as I was aware, all DV layers are 1080p. I'm sure someone will correct me if I am wrong...hell001 wrote: Mon Sep 26, 2022 3:46 pm Hi all. Stupid question here, but is there a difference between a 1080p DV layer and 2160p DV layer? There is a release I am trying to hybridize and I have the 4K HDR, but only have access to the 1080p Profile 5 DV. Does anyone have any experience with something like that?
bluray disc folder yes. 7-4-2 or 7-4-3 excellent. no problem.kazuma wrote: Mon Sep 26, 2022 4:02 pmhow do i know when it is a profile 7 file?RESET_9999 wrote: Mon Sep 26, 2022 12:51 pmif your input is a bluray disc folder yes. 7-4-2 or 7-4-3legosoff wrote: Mon Sep 26, 2022 8:17 am Thanks for the reply. How do I re-process, 4) MODE.P= / 2) MODE.2= right?
if it's a P7 mkv then use 7-4-4 or 7-4-5
7-4-1 is only for when you want to mux raw P5/P8 HEVC,AC3,EC3,SRT...
But one mkv problem dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 7-4-4 after that, the green screen again. How do I fix it on profile 7? Thank you.
For MEL discs I have been using this to discard the EL layer and create a base RPU for mp4 encoding.
This thread says that FEL discs need an additional step to remove_mapping that strips out the additional EL processing.
https://github.com/quietvoid/dovi_tool/discussions/168
Can anyone confirm this is needed on FEL discs?
I ran both approaches (discard vs remove_mapping) on a FEL disc and the json metadata was quite different.
dovi_tool -m 2 convert --discard video.hevc https://github.com/quietvoid/dovi_tool/discussions/168
fel_to_p81.json
"mode": 2,
"remove_mapping": true
dovi_tool --edit-config fel_to_p81.json mux --bl bl.hevc --el el.hevc --discard -
mapping removal is only for Profile 7 input. When input is P8, my script assumes that the mapping was already removed.legosoff wrote: Tue Sep 27, 2022 8:26 am bluray disc folder yes. 7-4-2 or 7-4-3 excellent. no problem.
I'll check if i can add support for p8 that still have the mapping
