the path is still 4-2-3 for this? with your dv version 1.5.9?RESET_9999 wrote: Mon Sep 26, 2022 5:52 pmyes, unless the language is one that I didn't implement.
By default, it will pick up the English audio/subs
kazuma
ha, I know why.BadSector81 wrote: Mon Sep 26, 2022 9:29 pm Try to run DoVi Scripts from another drive. Not from your system C:
The same happened to me and it solved. I still got error message but I can find the picture in the output folder.
will fix it in the next version.
I dont know, the worfklow order changed a bit in the latest version..kazuma wrote: Mon Sep 26, 2022 9:56 pm the path is still 4-2-3 for this? with your dv version 1.5.9?
what device do you play DV again?
hell001
So basically do the same process as normal even though the DV is 1080p? The active area is the same?RESET_9999 wrote: Mon Sep 26, 2022 9:40 pmright , for that case, you only have to convert P5 to P8.hell001 wrote: Mon Sep 26, 2022 8:43 pm Yes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?
I suggest you always check the dv source L5 before doing a Hybrid though. Because you will notice that a lot of DV web-dl has incorrect or missing L5.
Guys please, try this non-official version:
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
yeshell001 wrote: Mon Sep 26, 2022 10:12 pm So basically do the same process as normal even though the DV is 1080p? The active area is the same?
kazuma
LG C9 oled.RESET_9999 wrote: Mon Sep 26, 2022 10:02 pmI dont know, the worfklow order changed a bit in the latest version..kazuma wrote: Mon Sep 26, 2022 9:56 pm the path is still 4-2-3 for this? with your dv version 1.5.9?
option 1 (lossless but can be unstable)
mkv P7 input: 7-2-3
bdmv input: 7-2-2
option 2 (quality loss when input is FEL but 100% stable)
mkv P7 input: 4-2-2
bdmv input: 4-1-1
As far as I was aware, all DV layers are 1080p. I'm sure someone will correct me if I am wrong...hell001 wrote: Mon Sep 26, 2022 3:46 pm Hi all. Stupid question here, but is there a difference between a 1080p DV layer and 2160p DV layer? There is a release I am trying to hybridize and I have the 4K HDR, but only have access to the 1080p Profile 5 DV. Does anyone have any experience with something like that?
legosoff
bluray disc folder yes. 7-4-2 or 7-4-3 excellent. no problem.kazuma wrote: Mon Sep 26, 2022 4:02 pmhow do i know when it is a profile 7 file?RESET_9999 wrote: Mon Sep 26, 2022 12:51 pmif your input is a bluray disc folder yes. 7-4-2 or 7-4-3legosoff wrote: Mon Sep 26, 2022 8:17 am Thanks for the reply. How do I re-process, 4) MODE.P= / 2) MODE.2= right?
if it's a P7 mkv then use 7-4-4 or 7-4-5
7-4-1 is only for when you want to mux raw P5/P8 HEVC,AC3,EC3,SRT...
But one mkv problem dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 7-4-4 after that, the green screen again. How do I fix it on profile 7? Thank you.
Ibuprofen
For MEL discs I have been using this to discard the EL layer and create a base RPU for mp4 encoding.
This thread says that FEL discs need an additional step to remove_mapping that strips out the additional EL processing.
https://github.com/quietvoid/dovi_tool/discussions/168
Can anyone confirm this is needed on FEL discs?
I ran both approaches (discard vs remove_mapping) on a FEL disc and the json metadata was quite different.
dovi_tool -m 2 convert --discard video.hevc https://github.com/quietvoid/dovi_tool/discussions/168
fel_to_p81.json
"mode": 2,
"remove_mapping": true
dovi_tool --edit-config fel_to_p81.json mux --bl bl.hevc --el el.hevc --discard -
mapping removal is only for Profile 7 input. When input is P8, my script assumes that the mapping was already removed.legosoff wrote: Tue Sep 27, 2022 8:26 am bluray disc folder yes. 7-4-2 or 7-4-3 excellent. no problem.
I'll check if i can add support for p8 that still have the mapping
yes thats correct and you should always remove the mapping for FEL to p8
legosoff
I get you, you're right. These films of his were ready on 08.06, BL + RU, apparently there is a problem, and the other films that are there are working fine. It's most dvh.08.06, BL+RU someone did it wrong. I decide to download the Blu-ray disc, solely trusting myself.RESET_9999 wrote: Tue Sep 27, 2022 3:45 pmmapping removal is only for Profile 7 input. When input is P8, my script assumes that the mapping was already removed.legosoff wrote: Tue Sep 27, 2022 8:26 am bluray disc folder yes. 7-4-2 or 7-4-3 excellent. no problem.
sw5163
You can just manually remove those additional mapping in that p8 file, saves the redownloading time.legosoff wrote: Tue Sep 27, 2022 4:04 pm It's most dvh.08.06, BL+RU someone did it wrong. I decide to download the Blu-ray disc, solely trusting myself.
Sometimes I find it difficult to remux Blu-ray disc when there is a single video stream that consists of multiple m2ts files.
So I actually prefer FEL remux version.
Only the first part and remove_mapping of that post is useful, the rest part regarding MMR and polynomial mapping discussion is just me being stupid, please ignore. But I would like to express my thanks to @quietvoid and @RESET_9999 and you all, really teach me a lot.Ibuprofen wrote: Tue Sep 27, 2022 3:12 pm This thread says that FEL discs need an additional step to remove_mapping that strips out the additional EL processing.
