yes, unless the language is one that I didn't implement.
By default, it will pick up the English audio/subs
![Image](https://i.ibb.co/Dppnp7B/Capture.png)
Thanks. What is the recommended way of finding the "active area"? MediaInfo simply says 3840x2160 (for the 4K HDR) and 1920x1080 (for the 1080p DV).RESET_9999 wrote: ↑Mon Sep 26, 2022 5:01 pmThe metadata are exactly the same (except the active area of course).hell001 wrote: ↑Mon Sep 26, 2022 4:42 pmThank you, I'll check that out. I've made hybrids before, but not one where the quality on the DV source is different, so I was thrown off. Out of curiosity, what would be the difference if I simply had the 2160p DV layer? Would both layers produce the exact same thing, or is there slight quality loss with the 1080p layer?
So no quality loss... I do it all the time by the way.
I think it is not a problem related to the script itself, it's something else. Infact many other things don't work, for example: when I try to convert HDR10Plus to DoVi it does all steps correctly, unitl it tries to find the RPU.bin to inject into the BL, but it is not able to do that: It says it's impossible to find that file, and I end up with a 0kb .hevc file.hell001 wrote: ↑Mon Sep 26, 2022 4:28 pmSorry, can you clarify what you mean? The phrasing of your answer seems to imply that it doesn't matter that it's 1080p, but I was hoping to hear more about it.RESET_9999 wrote: ↑Mon Sep 26, 2022 4:18 pmyou only have to edit L5.hell001 wrote: ↑Mon Sep 26, 2022 3:46 pmHi all. Stupid question here, but is there a difference between a 1080p DV layer and 2160p DV layer? There is a release I am trying to hybridize and I have the 4K HDR, but only have access to the 1080p Profile 5 DV. Does anyone have any experience with something like that?
So I don't know, maybe it is some OS error.
Automatic way:
When you run my script, it will ask you if you want to edit L5, enter "y" and then enter "a" when it asks you if you want auto or manual L5.
Manual way:
I use staxrip crop function(check the tutorial video in my script link) but it might be easier for you to use avspmod: https://www.videohelp.com/software/AvsP
Well, it looks like my file doesn't have black bars (both 4K HDR and 1080p DV). Here is a screenshot https://i.ibb.co/jvh1GDp/SS.png. unless the blue bar means something? the blue bar moves when I move the mouseRESET_9999 wrote: ↑Mon Sep 26, 2022 6:54 pmAutomatic way:
Manual way:
what does this mean for the 4k/1080p active area?
When there is no black bars, L5 should be set to 0.
If your 1080p is not an itunes web-dl, it should be already set to 0. You can quickly verify any DV metadata with my script : (2-3)
![Image](https://i.ibb.co/nRS3nWR/explorer-KRFCOp-BYUr.gif)
Yes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?RESET_9999 wrote: ↑Mon Sep 26, 2022 8:33 pmWhen there is no black bars, L5 should be set to 0.
Try to run DoVi Scripts from another drive. Not from your system C:LV8HD wrote: ↑Mon Sep 26, 2022 4:31 pmI did, as you can see it is in my pip listRESET_9999 wrote: ↑Mon Sep 26, 2022 4:22 pminteresting, it fails when it tries to save the data into a graph, I have never seen that error and I didn't write that python script so I can't really help you here.( I assure you it's working on my PC)
did you install this version of color science?
https://pypi.org/project/colour-science
The same happened to me and it solved. I still got error message but I can find the picture in the output folder.
right , for that case, you only have to convert P5 to P8.hell001 wrote: ↑Mon Sep 26, 2022 8:43 pmYes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?
I suggest you always check the dv source L5 before doing a Hybrid though. Because you will notice that a lot of DV web-dl has incorrect or missing L5.
the path is still 4-2-3 for this? with your dv version 1.5.9?RESET_9999 wrote: ↑Mon Sep 26, 2022 5:52 pmyes, unless the language is one that I didn't implement.
ha, I know why.BadSector81 wrote: ↑Mon Sep 26, 2022 9:29 pmTry to run DoVi Scripts from another drive. Not from your system C:
will fix it in the next version.
I dont know, the worfklow order changed a bit in the latest version..
what device do you play DV again?
So basically do the same process as normal even though the DV is 1080p? The active area is the same?RESET_9999 wrote: ↑Mon Sep 26, 2022 9:40 pmright , for that case, you only have to convert P5 to P8.hell001 wrote: ↑Mon Sep 26, 2022 8:43 pmYes the L5 is at 0, confirmed with the script. In your original response, you said that I only needed to edit L5. Is that no longer true for this 4K HDR + 1080p DV?
Guys please, try this non-official version:
https://drive.google.com/file/d/1L3oMCJ ... sp=sharing
