Dolby Vision ?
zarc987
Dolby Vision ?
Post by zarc987 »
What programs can I use to watch Dolby Vision ripped videos on desktop ?
Re: Dolby Vision ?
None
zarc987
Re: Dolby Vision ?
Post by zarc987 »
Billycar11 wrote: Sat Sep 24, 2022 2:39 pmNone
So the videos is un-watchable ?, so to speak
Re: Dolby Vision ?
No you just get regular HDR
zarc987
Re: Dolby Vision ?
Post by zarc987 »
Billycar11 wrote: Sat Sep 24, 2022 2:44 pm No you just get regular HDR
How do I watch HDR on desktop ? Are there programs for it ?
Re: Dolby Vision ?
zarc987 wrote: Sat Sep 24, 2022 2:51 pm
Long as you have an HDR display and HDR capable video card you can watch them.
Lots of programs can do it so require windows to be in HDR mode some can automatically turn it on for you.
VLC you have to turn HDR on in windows
Jriver media center swaps automatically once setup
Mpc with madvr swaps automatically once setup
I even gave you my settings a few months ago
What GPU and display do you have
zarc987
Re: Dolby Vision ?
Post by zarc987 »
Billycar11 wrote: Sat Sep 24, 2022 2:57 pm
I have a normal ASUS 1080p display. No GPU. What HDR display and HDR budget video cards do you recommend ?
Re: Dolby Vision ?
zarc987 wrote: Sat Sep 24, 2022 9:51 pm
What's your current system?
What's your budget for monitor/tv
zarc987
Re: Dolby Vision ?
Post by zarc987 »
Billycar11 wrote: Sun Sep 25, 2022 2:49 am What's your current system?
i7 9700K, ASUS Z390-A, 32 GB RAM.
$300 - $400 ?
Re: Dolby Vision ?
zarc987 wrote: Sun Sep 25, 2022 3:00 am
$300 - $400 ?
You can get away without a video card you can just use display port with that setup that has HDR or you can use a display port to HDMI 2.0/2.1 converter cable to get HDR.
The only problem is you lose lossless audio if you use a converter cable.
There no good HDR monitors or TV's in the 300-400 range
I would recommend one of the oleds from Asus, gigabyte or lg in the 42 inch size they are about $1000 the Asus and gigabyte have display port that would be better for your setup.
https://www.amazon.com/AORUS-Monitor-38 ... PDKIKX0DER
zarc987
Re: Dolby Vision ?
Post by zarc987 »
Billycar11 wrote: Sun Sep 25, 2022 5:46 pm
Is it possible to keep my current 1080p ASUS monitor and get a budget HDR video card ? What do you recommend ?
Re: Dolby Vision ?
zarc987 wrote: Sun Sep 25, 2022 8:22 pm
your display does not do HDR and hdr video card wont help your current IGPU already can do HDR it the monitor that cant
just on that board you need to use display port as the hdmi is only 1.4
