deadchip12
Post by deadchip12 » Fri Sep 23, 2022 12:13 pm
RESET_9999 wrote:
Fri Sep 23, 2022 12:45 am
yes, but it has nothing to do with TV-LED which was your question. And I never tested the x800m2 lldv/player-led, that's why there is no mention about the x700 LLDV bug but i expect the same.
About the L1/L2 bug:
So far I'm only seeing differences with the Spears and Munsil clip and the L1/L2 pattern but I only tested two other videos, I didnt have much time to test more content ... I will test more until I'm convinced...
https://www.youtube.com/watch?v=yOCTCsE-E1s
https://www.youtube.com/watch?v=-3iCvnycg2c
https://www.youtube.com/watch?v=dupNfI8vkPk
https://www.youtube.com/watch?v=yxpMguEmVBQ
https://www.youtube.com/watch?v=TJtwu1bwlug
Sorry I'm a bit confused. So tv led and player led dolby vision, each has their own issues?
If I watch a dolby vision movie on the x700 connected to an lg oled, and I suppose what I get is tv led dolby vision, will there be any issue?
Slennox
Post by Slennox » Sat Sep 24, 2022 9:21 am
RESET_9999 wrote:
Tue Feb 22, 2022 4:42 am
instead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
If you want to add anything, let me know.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Hi RESET_9999,
The link is not working anymore. It was very useful. Can you repost it again? Thanks for your great effort.
Jose1001
Post by Jose1001 » Sat Sep 24, 2022 11:46 am
Hello RESST_999 to see if this is possible and how it could be done.
I have a Remastered version of a movie, which instead of having a Bitrate of 50Mb/s like the one in UHD, has a Bitrate of 72Mb/s. I also have the DV(1920x1080) video track from the Full UHD version, and my intention is to put this DV track into the remastered video track to create a profile 8, but according to StaxRip they have a frame difference of 22.
How could this be done, if possible?
Thank you very much and greetings
Donpoku
Post by Donpoku » Sat Sep 24, 2022 12:00 pm
No your C9 is not affected, it was C1/C2(new Cm4)on x7/800(old cm2).
Jose1001
Post by Jose1001 » Sat Sep 24, 2022 2:54 pm
Hi RESET_9999,
Look for a RESET_999 message and below the signature, click on Dolby Vision Material
Post by RESET_9999 » Sat Sep 24, 2022 3:07 pm
djanvi2020 wrote:
Fri Jul 22, 2022 8:40 am
Interesting thought,
A majority of my Dolby Atmos DV discs have 7.1 and DD+ can do 7.1 Unless i missed the memo that DV MP4 or TS files doesnt like 7.1, why aernt we using it if Dolby Atmos or Dolby True HD tracks are in 7.1 and the Dolby Scripts downgrades it to 5.1?
why are we losing those two channels cause i do have a system that can do 7.1 and DD+ can have 7.1?
Just to let you know that I've added a free way to encode 7.1 EC3 track in DoVi_Scripts_1.5.8 (6-3-8).
https://drive.google.com/drive/u/1/fold ... J2M9DvOQRu
The only problem right now is that tsmuxer cant mux those files properly but it should be fixed in the next nightly build. Mkvtoolnix is fine.
MODE.I (1-1) can do that but your two sources are most likely different HDR grades so unless you compare the brightness/colors (6-2-3 6-2-2) and get a close enough match, I wouldn't do that.
The C9 also has the CMV4.0 engine and according to @ deadchip12 it has the same L1/L2 reaction difference as shown here:
yes, two different issues. Again, forget about LLDV if you have an LG TV (or any recent TVs I guess).
Hi RESET_9999,
The link in my signature contains all the info about DV.
legosoff
Post by legosoff » Sun Sep 25, 2022 1:55 pm
Hi! 7) MODE.M4= MP4_MUXER Workflows / 4) MODE.4= Apple iOS compatible MP4 after my iPhone 12 Pro max why is the screen green? https://radikal.host/i/photo.1wEtX
sw5163
Post by sw5163 » Mon Sep 26, 2022 12:13 am
It's most likely caused by the additional mapping data in FEL RPU.
sw5163 wrote:
Tue Sep 06, 2022 12:28 am
staknhalo wrote:
Mon Sep 05, 2022 10:54 pm
You see flashing color artifacts as a result of RPU being improperly misaligned, but processed (or attempted, it's affecting it in some way)
I think those are caused by processing "reshaping data" in RPU (polynomial, and MMR mapping).
From my understanding, P5 RPU has "reshaping data" for ICtCp->YCbCr.
P8.1 RPU doesn't need "reshaping data" for HDR10->HDR10.
P8.4 RPU has "reshaping data" for HLG->PQ.
P7 RPU has "reshaping data" for processing the weird colour in EL (I'm not sure what it really does)
MPV can adapt those polynomial, and MMR mapping for ICtCp->YCbCr, HLG->HDR10 etc.
However, it can't process EL and merge that with BL like proper dolby decoding engine.
Resulting in wrongly processing those "reshaping data" on BL.
I think RPU consists ("reshaping data" for colour space transformation) + (Levels for brightness/contrast trimming)
So you can see some artifacts when scene/brightness change, but it's wrong.
And MPV just abandons all the brightness/contrast trimming.
It’s also probably the reason why it’s so important to “remove_mapping” when converting FEL->MEL
I'm not sure about this, please point out my mistakes, many thanks.
I'm not sure if RESET_9999 's script supports "remove_mapping", you may need to wait for his guidance.
If not, you can also do it manually https://www.avsforum.com/threads/apple- ... n.3252865/
Post by RESET_9999 » Mon Sep 26, 2022 12:28 am
yes, all the workflows except the manual one remove the mapping.( hevc input workflow 1: since I didn't expect someone to input raw p7 hevc, i dont even remember adding support for p7 there lol)
His file looks like a real profile 5 though. I don't have any apple devices so I can't help him.
legosoff
Post by legosoff » Mon Sep 26, 2022 8:17 am
Thanks for the reply. How do I re-process, 4) MODE.P= / 2) MODE.2= right?
Post by RESET_9999 » Mon Sep 26, 2022 12:51 pm
if your input is a bluray disc folder yes. 7-4-2 or 7-4-3
if it's a P7 mkv then use 7-4-4 or 7-4-5
7-4-1 is only for when you want to mux raw P5/P8 HEVC,AC3,EC3,SRT...
hell001
Post by hell001 » Mon Sep 26, 2022 3:46 pm
Hi all. Stupid question here, but is there a difference between a 1080p DV layer and 2160p DV layer? There is a release I am trying to hybridize and I have the 4K HDR, but only have access to the 1080p Profile 5 DV. Does anyone have any experience with something like that?
kazuma
Post by kazuma » Mon Sep 26, 2022 4:02 pm
how do i know when it is a profile 7 file?
LV8HD
Post by LV8HD » Mon Sep 26, 2022 4:11 pm
Hi, I'm kind of new to this script, and every time I try to measure something (HDR10, HDR10Plus or DoVi) I get many errors. I don't know why, since I'm pretty sure I installed all the required py modules. Anyway, this is the log file:
Drag and drop an MKV HDR10 file and press enter..C:\Muxing\Nobody.2021.2160p.AMZN.WEB-DL.x265.10bit.HDR10Plus.DDP5.1-SWTYBLZ_chunk.mkv
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'C:\TEMP2_folder\BL.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
min: 0.0050 cd/m2, max: 1000 cd/m2
Extracting HDR10plus...
Reading parsed dynamic metadata... Done.
Reordering metadata... Done.
Generating and writing metadata to JSON file... Done.
Reading JSON file..
Plotting graph..
Traceback (most recent call last):
  File "C:\Muxing\Tools\Dolby_Vision\DoVi_Scripts\tools\hdr10plus_plot.py", line 97, in <module>
    plt.savefig('nits_plot.png', dpi=150)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\pyplot.py", line 977, in savefig
    res = fig.savefig(*args, **kwargs)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\figure.py", line 3058, in savefig
    self.canvas.print_figure(fname, **kwargs)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\backends\backend_qtagg.py", line 85, in print_figure
    super().print_figure(*args, **kwargs)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\backend_bases.py", line 2319, in print_figure
    result = print_method(
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\backend_bases.py", line 1648, in wrapper
    return func(*args, **kwargs)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\_api\deprecation.py", line 415, in wrapper
    return func(*inner_args, **inner_kwargs)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\backends\backend_agg.py", line 541, in print_png
    mpl.image.imsave(
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\matplotlib\image.py", line 1675, in imsave
    image.save(fname, **pil_kwargs)
  File "C:\Users\leona\AppData\Local\Programs\Python\Python310\lib\site-packages\PIL\Image.py", line 2317, in save
    fp = builtins.open(filename, "w+b")
PermissionError: [Errno 13] Permission denied: 'nits_plot.png'
Impossibile trovare il file specificato.
""Nobody.2021.2160p.AMZN.WEB-DL.x265.10bit.HDR10Plus.DDP5.1-SWTYBLZ_chunk_HDR10plus_plot.png"" non è riconosciuto come comando interno o esterno,
 un programma eseguibile o un file batch.
the script has completed...
Premere un tasto per continuare . . .
To be 100% sure I have all the required modules this is my py list:
Package           Version
astroid           2.12.10
awsmfunc          1.3.2
colorama          0.4.5
colour-science    0.4.1
cycler            0.11.0
dill              0.3.5.1
ffprobe           0.5
fonttools         4.37.1
ijson             3.1.4
imageio           2.21.2
isort             5.10.1
kiwisolver        1.4.4
lazy-object-proxy 1.7.1
matplotlib        3.5.3
mccabe            0.7.0
mypy              0.971
mypy-extensions   0.4.3
numpy             1.23.3
packaging         21.3
Pillow            9.2.0
pip               22.2.2
platformdirs      2.5.2
plotbitrate       1.0.8.0
pylint            2.15.2
pyparsing         3.0.9
PyQt5             5.15.7
PyQt5-Qt5         5.15.2
PyQt5-sip         12.11.0
python-dateutil   2.8.2
scipy             1.9.1
setuptools        63.2.0
six               1.16.0
tomli             2.0.1
tomlkit           0.11.4
typing_extensions 4.3.0
ujson             5.5.0
VapourSynth       60
vs-rekt           1.0.0
vsutil            0.7.0
wheel             0.37.1
wrapt             1.14.1
Could someone help me?
Post by RESET_9999 » Mon Sep 26, 2022 4:18 pm
you only have to edit L5.
mediainfo ( text view / HDR format):
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU
you only need to know that information when you are using Workflow.1 (manual). the other workflows auto-detect the input profile.
