BadSector81
Post by BadSector81 »
@RESET_9999
Hi! thans for your DoVi Sripts. I love to use them!
Recently I got an error, plz help me. Used: 6-2-3:
[Choice? [1,2,3,4,5,6]?3
--this script plot DV L1 metadata (up to 13 files)
--You must have python, awsmfunc, ijson, numpy
--Also https://pypi.org/project/colour-science/
--Input can be RPU/MKV/TS/M2TS/MP4/
Drag and drop FILE #1 and press enter...C:\Utils\DoVi_Scripts\RPUtesszt.bin
Drag and drop FILE #2 and press enter...
Parsing RPU file...
Exporting metadata...
Done.
A rendszer nem találja a megadott fájlt.
"the script has completed"
A rendszer nem találja a megadott fájlt. (hungarian) means "The system cannot find the specified file"
For a sec a python window poped up but could't read. I installed all what you mentioned.
BadSector81 wrote:
Tue Sep 20, 2022 12:57 pm
@RESET_9999
No clue.
I'm really not a python expert, maybe try to re-install python and the modules.
did you download the latest version of the script with the tools (not only the bat file)? because there's a new tool(py script) needed for that workflow.
BadSector81
RESET_9999 wrote:
Tue Sep 20, 2022 2:05 pm
@RESET_9999
No clue.
Yes, I used your latest pack. I will try with reinstalling python. Thanks!
EDIT:
OK, I found the problem and the solution. It couldn't find my vapoursynth.dll. I moved it from
C:\Program Files\Python310\Lib\site-packages\ to C:\Users\xxx\Appdata\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\
And this workflow had permission problem too so moved everything from C: to D: and worked. Thanks!
sismon
Post by sismon »
Hello, can you please add the option to create a profile dv 05.06 to your tool? my tv (sony-plex-emby) does not support profile 7 as dv and profile 8 has bad colors. I want to create a perfect shape directly from bd. thanks sorry for en, I'm from the Czech Republic
Sony 65XF9005, nasa pc, avr stereo
sismon wrote:
Wed Sep 21, 2022 11:32 am
Use the appletv IOS mp4muxer workflows. (7-4)
Jose1001
Post by Jose1001 »
Hello good afternoon, From DoVi_Scripts it is possible to restore a profile 08.06. and leave it as before, only with HDR and without DV?
Many graces and balances
Jose1001 wrote:
Wed Sep 21, 2022 4:28 pm
yes, 6-1
Jose1001
Post by Jose1001 »
RESET_9999 wrote:
Wed Sep 21, 2022 4:43 pm
yes, 6-1
yes sir thank you very much
Jose1001
Post by Jose1001 »
Hello again RESET_9999 one last question.
To convert a 07.06 to 08.06 .mkv is the correct path in Dovi_Scripts 1.5.5. is: 4,2,5?
I know that the path: 7,1,4 is for MP4 but I want to finish in 08.06 .mkv
Thank you very much
yes
sismon
Post by sismon »
RESET_9999 wrote:
Wed Sep 21, 2022 1:07 pm
thanks, it's working now. unfortunately, in my case, the files have the wrong color even in profile 5. is there a way to fix it?
sw5163
Post by sw5163 »
staknhalo wrote:
Sun Sep 04, 2022 9:46 pm
Now I have an issue with Ep 4, 6 and 8 of Mandalorian S1 DV Profile 5 - mp4box is telling me:
The latest build of mp4box has fixed the atmos remuxing problem, it can also properly remux Mandalorian s01 e04 e06 e08.
Also do you guys know if there is an option in mp4box to convert dvhe->dvh1 when importing mp4?
For example something like: `mp4box -add dvhe.mp4:dvh1flag=true -new dvh1.mp4`
I can't use `stype=dvh1` because it doesn't change 'sample box entry' and will cause black screen on iOS/ATV playback.
Currently I'm using:
ffmpeg -i dvhe.mp4 -c copy dv.hevc
mp4box -add dv.hevc -new dvh1.mp4
But it would be nice if I could just skip the ffmpeg step.
Thanks.
Medtu wrote:
Thu Sep 22, 2022 5:06 pm
Hi, sorry about the English.... Can you give me some advice on what I'm doing wrong ? It is repeatedly displayed see picture
I will need more info to assist you...
Which workflow?
Input media info ?
complete log and not just a screenshot?
deadchip12
Post by deadchip12 »
RESET_9999 wrote:
Tue Sep 20, 2022 11:04 am
deadchip12 wrote:
Tue Sep 20, 2022 12:11 am
About the known issues/limitations of the x700, it says "L2 trim does not work in LLDV". LLDV is the inferior player led dolby vision, correct? What about tv led dolby vision that tvs like lg oled support? I remember it was pointed out here a while back that there were some dolby vision issues with lg oled from previous years; is it player led or tv led dolby vision? Also, based in the spreadsheet, the x800m2 does not have this issue?
LG TVs support TV-LED so you don't have to worry about that.
Didn't you say a while ago that the C2 had issues with dolby vision on the x800m2? And then there were multiple test files. I tried those on my C9 and x700 and also saw the differences at L1 and L2, etc. Sth about the compatibility of Dolby Vision 2.9 and 4.0
yes, but it has nothing to do with TV-LED which was your question. And I never tested the x800m2 lldv/player-led, that's why there is no mention about the x700 LLDV bug but i expect the same.
About the L1/L2 bug:
So far I'm only seeing differences with the Spears and Munsil clip and the L1/L2 pattern but I only tested two other videos, I didnt have much time to test more content ... I will test more until I'm convinced...
https://www.youtube.com/watch?v=yOCTCsE-E1s
https://www.youtube.com/watch?v=-3iCvnycg2c
https://www.youtube.com/watch?v=dupNfI8vkPk
https://www.youtube.com/watch?v=yxpMguEmVBQ
https://www.youtube.com/watch?v=TJtwu1bwlug
