Segmentation fault on Arch Linux
Daren
Re: Segmentation fault on Arch Linux
#46 Post by Daren » Wed Sep 21, 2022 9:04 am
It has been 1.5 months now, can we at least get a statement on the status?
pipo233
#47 Post by pipo233 » Wed Sep 21, 2022 3:27 pm
@daren
Well that is what i also want to know..
I have the feeling that mike is waiting for the big distro vendors to fix the problem, they have makemkv in their repo's and thus they are a distributing this software so they have to maintain it themselves
What if find strange is that mike does respond very recently to this post viewtopic.php?f=3&t=1840
but doesn't response to a post where lots of people complaining that it is not working anymore?
timeshifter
#48 Post by timeshifter » Thu Sep 22, 2022 6:56 pm
mwoliver wrote:
Tue Aug 30, 2022 1:30 pm
Indeed, it would be encouraging to see an ack by mike admin about this problem and a "working on it guys" bit of reassurance before we all delve into potentially destructive means to get makemkv working again. The lack of any sort of comment is a bit worrisome given that this has been a top-of-the-page item for close to a month. One could even speculate that the issues are gargantuan ...
I don't know how gargantuan the problem is, but if it's related to the deprecation of DT_HASH in favor of DT_GNU_HASH in glibc, then it seems a solvable problem. Some info here: https://maskray.me/blog/2022-08-21-glib ... t-gnu-hash
The community could probably figure out a solution for the open-source portion of the code, but can't do much about the secret-sauce binary blob if it is where the problem is triggered. Seems to be since I can run makemkvcon and the GUI without trouble - crash happens as soon as the application attempts to access a disk, which invokes the secret magic.
Master of Thyme and Spice
:D Registered User :D
burgess-m
#49 Post by burgess-m » Sat Sep 24, 2022 11:56 am
Perhaps you meant this post viewtopic.php?f=19&t=29136&p=127060#p127060 ?
Mike's response in the topic you linked to was in 2010.
pipo233
#50 Post by pipo233 » Sun Sep 25, 2022 6:27 pm
@burgess-m
jeez i missed that topic is from 2010.. i feel stupid
But the point was that mike does respond to other topics but not this one
Mitch
#51 Post by Mitch » Sat Oct 01, 2022 1:47 am
It doesn't look like this problem is going to be fixed anytime soon, if at all, but I figured out a complete MakeMKV/VLC GUI Flatpak solution that works perfectly. I don't use MakeMKV from the command line, but since the GUI works I'm sure there's a way to launch makemkvcon as well. In any case I can now use MakeMKV as I always have, and VLC can actually play Blu-rays with menus better than ever before.
So here are the instructions on how to install from Flathub on Arch. Adjust the instructions as needed for your distro.
Install Flatpak and then reboot:
sudo pacman -S flatpak
Add Flatpak flathub repository:
flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo
Install MakeMKV (choose latest app from list like "app/com.makemkv.MakeMKV/x86_64/stable"):
flatpak install makemkv
Install VLC (choose latest app from list like "app/org.videolan.VLC/x86_64/stable"):
flatpak install vlc
Install VLC MakeMKV plugin (choose latest plugin from list like "runtime/org.videolan.VLC.Plugin.makemkv/x86_64/3-21.08"):
flatpak install vlc
Install VLC Java plugin (choose latest plugin from list like "runtime/org.videolan.VLC.Plugin.bdj/x86_64/3-21.08"):
flatpak install vlc
Install VLC FDK-AAC plugin (choose latest plugin from list like "runtime/org.videolan.VLC.Plugin.fdkaac/x86_64/3-21.08"):
flatpak install vlc
That's it. You should now have a working MakeMKV/VLC installation.
Chewi
#52 Post by Chewi » Sat Oct 01, 2022 12:31 pm
It's happening on Gentoo as well. I doubt it's the DT_HASH vs DT_GNU_HASH issue, as I had Mike fix MakeMKV to support both back when Gentoo was only using the latter.
Chewi
#53 Post by Chewi » Sat Oct 01, 2022 4:31 pm
I've bisected and it's caused by this change. It reverts cleanly against glibc 2.36 and then it works. I'm guessing it won't be hard for Mike to fix.
mwoliver
#54 Post by mwoliver » Fri Oct 07, 2022 2:49 am
...and we can't even get an ack in this thread that it's even on the radar. Frustrating, to be honest. A one-liner like "hey guys, I know things are messed up right now, but sit tight while I sort it out" would go a long way.
Zontar
#55 Post by Zontar » Wed Oct 12, 2022 6:23 pm
This error also occurs on Fedora 37 (beta). Fedora 37 should get released next week.
#56 Post by mike admin » Wed Oct 12, 2022 9:58 pm
Fixed in 1.17.2, just released.
DepriSheep
#57 Post by DepriSheep » Thu Oct 13, 2022 10:33 am
Thank you very much!
timeshifter
#58 Post by timeshifter » Thu Oct 13, 2022 2:27 pm
I can confirm that 1.17.2 no longer segfaults on my Arch Linux system. MakeMKV GUI (non-flatpak) works again, and integration with other tools (eg. VLC) seems fixed.
Thank you, Mike. This fix is much appreciated. Communications still need improvement, not going to lie, but thanks for being responsive in your own special way.
