Pioneer BDR-XS07TUHD Hardware Region Lock Workaround
Konten
#1 Post by Konten » Tue Sep 20, 2022 7:58 pm
I just received my Pioneer BDR-XS07TUHD and am planning to back up my DVDs and Blu-rays with MakeMKV. I believe the disc region is not an issue with MMKV as it will just grab all the data and not play anything back.
In addition to the backups, I would also like to be able to play the actual discs on my Mac but what to do about the region lock in the drive after 5 changes? Is there any way around that? Can these be flashed to be region-free? Or are there any software programs that would do the trick?
I’ve done quite a bit of searching already but haven’t found anything so thank you for any help you may be able to give!!
Re: Pioneer BDR-XS07TUHD Hardware Region Lock Workaround
#2 Post by MartyMcNuts » Wed Sep 21, 2022 11:46 pm
Konten wrote: Tue Sep 20, 2022 7:58 pm I just received my Pioneer BDR-XS07TUHD and am planning to back up my DVDs and Blu-rays with MakeMKV. I believe the disc region is not an issue with MMKV as it will just grab all the data and not play anything back.
I don't think there is any workaround for that.
Can't you play your rips instead? Or use the unofficial method of playack using MakeMKV as the on-the-fly decrypter and a player such as VLC (or other unofficial players). You won't have to worry about any region coding this way.
Konten
#3 Post by Konten » Thu Sep 22, 2022 4:00 pm
Thank you very much, I will try the MakeMKV/VLC suggestion when I get home this weekend!! I thought that this might work only for Blu-ray and also that each time I would use a DVD with a different region, it would still use up one of the 5 tries I get before the drive region locks in hardware... I will test and fingers crossed! :)
#4 Post by MartyMcNuts » Fri Sep 23, 2022 12:55 am
Konten wrote: Thu Sep 22, 2022 4:00 pm Thank you very much, I will try the MakeMKV/VLC suggestion when I get home this weekend!! I thought that this might work only for Blu-ray and also that each time I would use a DVD with a different region, it would still use up one of the 5 tries I get before the drive region locks in hardware... I will test and fingers crossed! :)
MakeMKV should ignore/remove region coding.
