I just received my Pioneer BDR-XS07TUHD and am planning to back up my DVDs and Blu-rays with MakeMKV. I believe the disc region is not an issue with MMKV as it will just grab all the data and not play anything back.
In addition to the backups, I would also like to be able to play the actual discs on my Mac but what to do about the region lock in the drive after 5 changes? Is there any way around that? Can these be flashed to be region-free? Or are there any software programs that would do the trick?
I’ve done quite a bit of searching already but haven’t found anything so thank you for any help you may be able to give!!
Pioneer BDR-XS07TUHD Hardware Region Lock Workaround
Re: Pioneer BDR-XS07TUHD Hardware Region Lock Workaround
I don't think there is any workaround for that.Konten wrote: ↑Tue Sep 20, 2022 7:58 pmI just received my Pioneer BDR-XS07TUHD and am planning to back up my DVDs and Blu-rays with MakeMKV. I believe the disc region is not an issue with MMKV as it will just grab all the data and not play anything back.
Can't you play your rips instead? Or use the unofficial method of playack using MakeMKV as the on-the-fly decrypter and a player such as VLC (or other unofficial players). You won't have to worry about any region coding this way.
Thank you very much, I will try the MakeMKV/VLC suggestion when I get home this weekend!! I thought that this might work only for Blu-ray and also that each time I would use a DVD with a different region, it would still use up one of the 5 tries I get before the drive region locks in hardware... I will test and fingers crossed!
MakeMKV should ignore/remove region coding.Konten wrote: ↑Thu Sep 22, 2022 4:00 pmThank you very much, I will try the MakeMKV/VLC suggestion when I get home this weekend!! I thought that this might work only for Blu-ray and also that each time I would use a DVD with a different region, it would still use up one of the 5 tries I get before the drive region locks in hardware... I will test and fingers crossed!![]()
