UHD Friendly and UHD official are they same quality LG WH16NS40
speedygonzo5
Post by speedygonzo5 » Tue Sep 20, 2022 4:06 pm
delete duplicate thread
Re: UHD Friendly and UHD official are they same quality LG WH16NS40
Post by Billycar11 » Tue Sep 20, 2022 6:46 pm
speedygonzo5 wrote: Tue Sep 20, 2022 4:06 pm I am wondering far as picture goes what the difference between
LG WH16NS40
and
LG WH16NS60
Are these the same quality if I flash a ns40 to a ns60?
When playing disks would I still get uhd hdr ect? Also is there any difference in backing up media? With emphasis on quality when playing disk on a high end tv
Same drive the NS60 just adds an aacs 2 chip.
Also same as Asus bw161ht and wh14ns40
Both are junk
Get a BU40N equivalent or pioneer
speedygonzo5
Post by speedygonzo5 » Wed Sep 21, 2022 12:01 am
Well I'm really interested in the LG WH16NS40 drive due to its cost is much cheaper than the others. That aacs chips is it a must have or with a LG WH16NS40 could I copy it and playback with cyberlink powerdvd
Could I access and get full uhd hdr quality that way or is a accs chip a must have to copy
Also I heard I can't use DVDfab with Pioneer would need makemkv?
Post by Billycar11 » Wed Sep 21, 2022 12:12 am
speedygonzo5 wrote: Wed Sep 21, 2022 12:01 am Well I'm really interested in the LG WH16NS40 drive due to its cost is much cheaper than the others. That aacs chips is it a must have or with a LG WH16NS40 could I copy it and playback with cyberlink powerdvd
the aacs chip is not needed to copy or unofficially play.
again i highly recommend ageist offical playback what are your pc specs?
you can playback after copying with power dvd but you can do direct disc playback with vlc or jriver media center with full menus with makemkv integration purchase required.
makemkv is lossless so it will be full quality.
speedygonzo5
Post by speedygonzo5 » Wed Sep 21, 2022 1:47 pm
System specs
8700k 16gb ram rtx 2080 graphics card nvme and hdd I had an older ihos drive that worked but it has sense died idk if it was giving me 4k hdr or not but I never had any issues with DVDfab or cyberlink
I don't understand if there's a accs chip why or how is it allowed to just flash the drive and circumvent the chip? My. Main focus would be on quality but am. On a budget to somewhat
Is DVDfab lossless?
Say I where to get a bun40n would I be able to play through cyberlink powerdvd 21 (already bout the software while back) or. At the very lease would I be able to. Copy the disk then do a playback with a bun40?
What's the big deal with the bun40n and would I need a paticuler type of 5.25 adapter. To. Fit In computer and be able to flash it Is flashing not nessacary with that one? Also with the bun40n does that one work with cyberlink or dvdfab
I'm. Open to. Buying makemkv but if I can use what I already have like. Powerdvd and DVDfab that would be ideal however if makemkv is somehow better quality would deffinatly consider it
Post by Billycar11 » Wed Sep 21, 2022 11:17 pm
speedygonzo5 wrote: Wed Sep 21, 2022 1:47 pm System specs
Is DVDfab lossless?
Your pc will never be able to do official UHD playback with a rtx 2080 you would need to use the Intel GPU
Other ripers are not always lossless makemkv is always lossless.
Not with your current setup you will never be able to do official playback with an rtx card as I have said many times now use unofficial playback with makemkv.
speedygonzo5
Post by speedygonzo5 » Thu Sep 22, 2022 10:43 am
OK one last question what programs do unofficial playback
And or could I get around official playback by copying it would I playback just fine then? Also I rember at one point the graphics card speeding up the copy process but I don't remember as was a while ago
Post by MartyMcNuts » Thu Sep 22, 2022 10:55 am
speedygonzo5 wrote: Thu Sep 22, 2022 10:43 am OK one last question what programs do unofficial playback
Rip and play the rip will work ok, just do not use PowerDVD. Use a player like VLC or MPC-HC or one of the many others. If you really need to do direct disc playback, then use the unofficial method via an on-the-fly decrypter such as MakeMKV or AnyDVD and a player such as VLC or MPC-HC.
