If I start makemkv, it reports that it's downloading the latest sdf ... then stalls, then closes with a 'fatal error' message.
MakeMKV version: 1.17.1-1.8. I've had the problem for the past couple of days, after updating to this version.
Threads on this forum suggest that I can download sdf.bin and copy it into the data directory. I copied it to /home/.MakeMKV (Linux), but that didn't help.
I don't need to use MakeMKV right away, and could wait a few days if a configuration needs to be fixed on the MakeMKV server.
DLing latest SDF, followed by Fatal error in 1.17.1-1.8
listen8
listen8
Re: DLing latest SDF, followed by Fatal error in 1.17.1-1.8
Thank you, d00zah. I'm using Tumbleweed, so it looks like I've got company.
listen8
The flatpak version works for me, too, as for another user on this forum:
https://flathub.org/apps/details/com.makemkv.MakeMKV
However, this would be my only flatpak app, so I'll hope that openSUSE can fix the glibc 2.36 issue.
