Running MakeMKV 1.17.1 on Xubuntu 20.04. I have an LG WD-16NS40 with the WH16NS60 firmware (LibreDrive MT1959). Up until recently the system has been detecting BD and UHD discs fine. MakeMKV still sees DVDs and I seem to have no problem ripping them. Blu-rays, however, just show up greyed out. Has anyone else run into this with a recent MakeMKV update?
A couple of things happened around the time: I updated to 1.17.1, but I also tried ripping a disc that was a bit dirty. Not sure if this would have thrown off the BD laser??? The drive isn't very old (less than a year).
Thanks all,
[Solved] LG WH16NS40 (w/ 60 upgrade) doesn't see BD discs anymore
chaslinux
Re: LG WH16NS40 (w/ 60 upgrade) doesn't see BD discs anymore
Shutdown for a min and it should come back
chaslinux
Thanks Billycar11, that's exactly what was needed!
I normally keep my machine on, so I've had this problem since yesterday. I did a complete shutdown (turned off the PSU as well just in case). When I saw the disc on the desktop I was so happy! Thanks, you really made my day!
yeah seen it alot with those desktop drives.chaslinux wrote: Tue Sep 20, 2022 12:37 am Thanks Billycar11, that's exactly what was needed!
be careful putting scratched or dirty discs in them sometimes they dont come back
