Post by Manixx2020beyound »
RESET_9999 wrote:
Sun Sep 18, 2022 3:51 pm
original vs resolve 2.9 vs hdr10plus vs hdr10 madvr vs resolve 4.0
https://slow.pics/c/ipOD7eqm
How can I use the graph for my own rpus?
To see my own results.
install python and the required modules and run my script. (6-2-3)
EG:
pip install ijson
pip install awsmfunc
pip install colour-science
etc...
baker99
Post by baker99 »
Finally got my X800M2, far better than the X700 if you want to stream over a network. So far everything is working well, even converting mkv files to m2ts (after adding an ac3 core). Thanks to RESET_999 and everyone else in this thread for all your hard work.
Donpoku
Post by Donpoku »
RESET_9999 wrote:
Mon Sep 19, 2022 4:43 pm
EG:
pip install ijson
etc...
Thank you so much for your hard work, enjoying DV thanks to your tools :D
deadchip12
Post by deadchip12 »
RESET_9999 wrote:
Sun Sep 18, 2022 12:20 pm
kazuma wrote:
Sun Sep 18, 2022 9:39 am
Thank you reset_9999! i'm gonna try it tonight. what is the fastest method to convert? the duration is very long. is the convert time with a full bluray much shorter?
another question: Are the new lg oled models playing DV mp4 and ts files via usb? or only profile 8? what is the profit of an LG C9? that it can play also profile 7?
check the link in my signature.
About the known issues/limitations of the x700, it says "L2 trim does not work in LLDV". LLDV is the inferior player led dolby vision, correct? What about tv led dolby vision that tvs like lg oled support? I remember it was pointed out here a while back that there were some dolby vision issues with lg oled from previous years; is it player led or tv led dolby vision? Also, based in the spreadsheet, the x800m2 does not have this issue?
deadchip12 wrote:
Tue Sep 20, 2022 12:11 am
LG TVs support TV-LED so you don't have to worry about that.
BadSector81
Post by BadSector81 »
@RESET_9999
Hi! thans for your DoVi Sripts. I love to use them!
Recently I got an error, plz help me. Used: 6-2-3:
[Choice? [1,2,3,4,5,6]?3
--this script plot DV L1 metadata (up to 13 files)
--You must have python, awsmfunc, ijson, numpy
--Also https://pypi.org/project/colour-science/
--Input can be RPU/MKV/TS/M2TS/MP4/
Drag and drop FILE #1 and press enter...C:\Utils\DoVi_Scripts\RPUtesszt.bin
Drag and drop FILE #2 and press enter...
Parsing RPU file...
Exporting metadata...
Done.
A rendszer nem találja a megadott fájlt.
"the script has completed"
A rendszer nem találja a megadott fájlt. (hungarian) means "The system cannot find the specified file"
For a sec a python window poped up but could't read. I installed all what you mentioned.
BadSector81 wrote:
Tue Sep 20, 2022 12:57 pm
@RESET_9999
No clue.
I'm really not a python expert, maybe try to re-install python and the modules.
did you download the latest version of the script with the tools (not only the bat file)? because there's a new tool(py script) needed for that workflow.
BadSector81
RESET_9999 wrote:
Tue Sep 20, 2022 2:05 pm
@RESET_9999
No clue.
Yes, I used your latest pack. I will try with reinstalling python. Thanks!
EDIT:
OK, I found the problem and the solution. It couldn't find my vapoursynth.dll. I moved it from
C:\Program Files\Python310\Lib\site-packages\ to C:\Users\xxx\Appdata\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\
And this workflow had permission problem too so moved everything from C: to D: and worked. Thanks!
sismon
Post by sismon »
Hello, can you please add the option to create a profile dv 05.06 to your tool? my tv (sony-plex-emby) does not support profile 7 as dv and profile 8 has bad colors. I want to create a perfect shape directly from bd. thanks sorry for en, I'm from the Czech Republic
Sony 65XF9005, nasa pc, avr stereo
sismon wrote:
Wed Sep 21, 2022 11:32 am
Use the appletv IOS mp4muxer workflows. (7-4)
Jose1001
Post by Jose1001 »
Hello good afternoon, From DoVi_Scripts it is possible to restore a profile 08.06. and leave it as before, only with HDR and without DV?
Many graces and balances
Jose1001 wrote:
Wed Sep 21, 2022 4:28 pm
yes, 6-1
Jose1001
Post by Jose1001 »
RESET_9999 wrote:
Wed Sep 21, 2022 4:43 pm
yes, 6-1
yes sir thank you very much
Jose1001
Post by Jose1001 »
Hello again RESET_9999 one last question.
To convert a 07.06 to 08.06 .mkv is the correct path in Dovi_Scripts 1.5.5. is: 4,2,5?
I know that the path: 7,1,4 is for MP4 but I want to finish in 08.06 .mkv
Thank you very much
