Portals
Post by Portals » Mon Sep 19, 2022 3:00 am
Registered an account just to say thank you to RESET_9999, as well as everyone else. I'm finally able to play Dolby Vision content on my LG C2 via Jellyfin's WebOS app by simply converting Dolby Vision Profile 7 to Profile 8. I'm new to DV and had no idea that DV Profile 7 wasn't supported by a whole lot of devices yet.
Just in case any poor soul is having the problem I was having, here is what I did — using RESET_9999's scripts
Input file (Dolby Vision 7)
General
Unique ID                   : 108575998620693720312303693169930654183 (0x51AEFA08EA461E97531FBEFC934DD1E7)
Complete name               : C:\Tools4Movies\John.Wick.2014.2160p.BluRay.REMUX.HEVC.DV.TrueHD.Atmos.7.1-Flights_1.mkv
Format                      : Matroska
Format version              : Version 4
File size                   : 65.2 GiB
Duration                    : 1 h 41 min
Overall bit rate mode       : Variable
Overall bit rate            : 92.2 Mb/s
Movie name                  : John Wick (2014) 4K DV
Encoded date                : UTC 2022-06-19 11:23:51
Writing application         : mkvmerge v67.0.0 ('Under Stars') 64-bit
Writing library             : libebml v1.4.2 + libmatroska v1.6.4
Video
ID in the original source m : 4113 (0x1011)
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L5.1@High
HDR format                  : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                    : V_MPEGH/ISO/HEVC
Bit rate                    : 85.9 Mb/s
Width                       : 3 840 pixels
Height                      : 2 160 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0 (Type 2)
Bit depth                   : 10 bits
Bits/(Pixel*Frame)          : 0.432
Stream size                 : 60.7 GiB (93%)
Language                    : English
Default                     : No
Forced                      : No
Color range                 : Limited
Color primaries             : BT.2020
Transfer characteristics    : PQ
Matrix coefficients         : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light : 227 cd/m2
Original source medium      : Blu-ray
Audio #1
Format                      : MLP FBA 16-ch
Format/Info                 : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name             : Dolby TrueHD with Dolby Atmos
Codec ID                    : A_TRUEHD
Bit rate mode               : Variable
Bit rate                    : 4 955 kb/s
Maximum bit rate            : 9 456 kb/s
Channel(s)                  : 8 channels
Channel layout              : L R C LFE Ls Rs Lb Rb
Sampling rate               : 48.0 kHz
Frame rate                  : 1 200.000 FPS (40 SPF)
Compression mode            : Lossless
Stream size                 : 3.50 GiB (5%)
Title                       : TrueHD Atmos 7.1
Language                    : English
Default                     : Yes
Forced                      : No
Number of dynamic objects   : 15
Bed channel count           : 1 channel
Bed channel configuration   : LFE
Audio #2
Format                      : AC-3
Format/Info                 : Audio Coding 3
Commercial name             : Dolby Digital
Format settings             : Dolby Surround EX
Codec ID                    : A_AC3
Bit rate mode               : Constant
Bit rate                    : 640 kb/s
Channel(s)                  : 6 channels
Frame rate                  : 31.250 FPS (1536 SPF)
Compression mode            : Lossy
Stream size                 : 463 MiB (1%)
Title                       : AC3 5.1
Language                    : English
Service kind                : Complete Main
Default                     : No
Forced                      : No
Audio #3
Format                      : AC-3
Codec ID                    : A_AC3
Bit rate                    : 224 kb/s
Channel(s)                  : 2 channels
Stream size                 : 162 MiB (0%)
Title                       : Commentary by Filmmakers Chad Stahelski & David Leitch
Language                    : English
Default                     : No
Forced                      : No
Once this process is done, tsMuxeR should open automatically. You should have a P8 file and a E-AC3 file now. All you have to do is feed it those two files and select your desired output format. Pick whichever your media player or TV supports. Thankfully .ts is widely supported on most devices so that should suffice. If in doubt, refer to RESET_9999's incredible playback compatibility chart.
Resulting file is now Dolby Vision 8!
General
Complete name               : C:\Tools4Movies\John.Wick.2014.2160p.BluRay.REMUX.HEVC.DV.TrueHD.Atmos.7.1-Flights_1_P8.ts
Format                      : MPEG-TS
File size                   : 54.2 GiB
Overall bit rate            : 76.6 Mb/s
Maximum Overall bit rate    : 35.5 Mb/s
Video
Menu ID                     : 1 (0x1)
Format                      : HEVC
HDR format                  : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                    : 36
Bit rate                    : 71.3 Mb/s
Color space                 : YUV
Bit depth                   : 10 bits
Bits/(Pixel*Frame)          : 0.358
Stream size                 : 50.4 GiB (93%)
Audio
Menu ID                     : 1 (0x1)
Format                      : E-AC-3
Format/Info                 : Enhanced AC-3
Commercial name             : Dolby Digital Plus
Codec ID                    : 132
Bit rate                    : 1 536 kb/s
Frame rate                  : 62.500 FPS (768 SPF)
Stream size                 : 1.09 GiB (2%)
It turns out that the Dolby Vision master for John Wick doesn't add a whole lot. Still, it's a great film and this was a great learning experience.
Again, thank you so much to RESET_9999 for your amazing scripts, the authors of the tools, and everyone on the forums who contributed their knowledge. You guys make this world a better place to live in :]
Post by Manixx2020beyound » Mon Sep 19, 2022 3:33 pm
RESET_9999 wrote:
Sun Sep 18, 2022 3:51 pm
original vs resolve 2.9 vs hdr10plus vs hdr10 madvr vs resolve 4.0
https://slow.pics/c/ipOD7eqm
How can I use the graph for my own rpus?
To see my own results.
Post by RESET_9999 » Mon Sep 19, 2022 4:43 pm
install python and the required modules and run my script. (6-2-3)
EG:
pip install ijson
pip install awsmfunc
pip install colour-science
etc...
baker99
Post by baker99 » Mon Sep 19, 2022 7:57 pm
Finally got my X800M2, far better than the X700 if you want to stream over a network. So far everything is working well, even converting mkv files to m2ts (after adding an ac3 core). Thanks to RESET_999 and everyone else in this thread for all your hard work.
Donpoku
Post by Donpoku » Mon Sep 19, 2022 10:13 pm
EG:
pip install ijson
etc...
Thank you so much for your hard work, enjoying DV thanks to your tools :D
deadchip12
Post by deadchip12 » Tue Sep 20, 2022 12:11 am
RESET_9999 wrote:
Sun Sep 18, 2022 12:20 pm
kazuma wrote:
Sun Sep 18, 2022 9:39 am
Thank you reset_9999! i'm gonna try it tonight. what is the fastest method to convert? the duration is very long. is the convert time with a full bluray much shorter?
another question: Are the new lg oled models playing DV mp4 and ts files via usb? or only profile 8? what is the profit of an LG C9? that it can play also profile 7?
check the link in my signature.
About the known issues/limitations of the x700, it says "L2 trim does not work in LLDV". LLDV is the inferior player led dolby vision, correct? What about tv led dolby vision that tvs like lg oled support? I remember it was pointed out here a while back that there were some dolby vision issues with lg oled from previous years; is it player led or tv led dolby vision? Also, based in the spreadsheet, the x800m2 does not have this issue?
Post by RESET_9999 » Tue Sep 20, 2022 11:04 am
LG TVs support TV-LED so you don't have to worry about that.
BadSector81
Post by BadSector81 » Tue Sep 20, 2022 12:57 pm
@RESET_9999
Hi! thans for your DoVi Sripts. I love to use them!
Recently I got an error, plz help me. Used: 6-2-3:
[Choice? [1,2,3,4,5,6]?3
--this script plot DV L1 metadata (up to 13 files)
--You must have python, awsmfunc, ijson, numpy
--Also https://pypi.org/project/colour-science/
--Input can be RPU/MKV/TS/M2TS/MP4/
Drag and drop FILE #1 and press enter...C:\Utils\DoVi_Scripts\RPUtesszt.bin
Drag and drop FILE #2 and press enter...
Parsing RPU file...
Exporting metadata...
Done.
A rendszer nem találja a megadott fájlt.
"the script has completed"
A rendszer nem találja a megadott fájlt. (hungarian) means "The system cannot find the specified file"
For a sec a python window poped up but could't read. I installed all what you mentioned.
Post by RESET_9999 » Tue Sep 20, 2022 2:05 pm
@RESET_9999
No clue.
I'm really not a python expert, maybe try to re-install python and the modules.
did you download the latest version of the script with the tools (not only the bat file)? because there's a new tool(py script) needed for that workflow.
BadSector81
Post by BadSector81 » Tue Sep 20, 2022 7:24 pm
@RESET_9999
No clue.
Yes, I used your latest pack. I will try with reinstalling python. Thanks!
EDIT:
OK, I found the problem and the solution. It couldn't find my vapoursynth.dll. I moved it from
C:\Program Files\Python310\Lib\site-packages\ to C:\Users\xxx\Appdata\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\
And this workflow had permission problem too so moved everything from C: to D: and worked. Thanks!
sismon
Post by sismon » Wed Sep 21, 2022 11:32 am
Hello, can you please add the option to create a profile dv 05.06 to your tool? my tv (sony-plex-emby) does not support profile 7 as dv and profile 8 has bad colors. I want to create a perfect shape directly from bd. thanks sorry for en, I'm from the Czech Republic
Sony 65XF9005, nasa pc, avr stereo
Post by RESET_9999 » Wed Sep 21, 2022 1:07 pm
Use the appletv IOS mp4muxer workflows. (7-4)
Jose1001
Post by Jose1001 » Wed Sep 21, 2022 4:28 pm
Hello good afternoon, From DoVi_Scripts it is possible to restore a profile 08.06. and leave it as before, only with HDR and without DV?
Many graces and balances
Post by RESET_9999 » Wed Sep 21, 2022 4:43 pm
yes, 6-1
Jose1001
Post by Jose1001 » Wed Sep 21, 2022 7:59 pm
yes, 6-1
yes sir thank you very much
