3D RIP works without MVC Track, but I need it!
Xeth84
Post by Xeth84 »
I've been converting my 3D Blu-rays to Full-SBS files over the last month. Things have been going pretty well until I have hit a snag. The disc fails to rip. Usually when this happens, I remove some nonessentials tracks until it works. This time. I have removed all the tracks, even the main audio, without success until I removed the MVC track which is essential for the 3D to work. So is there a fix out there or a way to rip just the MVC track and combine them after?
Re: 3D RIP works without MVC Track, but I need it!
If it doesn't rip on that disk, replacement is the proper option, unless you can rip it from a different disk.
The problem is that the 3D track is intermixed with the original track, so removing it skips over the part that won't rip. The fact that it "missed" the bad spot when leaving the track out means it's relatively small, so you might get by with cleaning the disk.
Xeth84
Post by Xeth84 »
I did clean the disc before the 1st attempt and after trying a few more.
