Keeping the Menus
yashi43
Keeping the Menus
I'm re-learning how to rip. I have a bunch of UHDs, I have a pioneer bdr-xd07uhd for ripping. I have ripped (with menus) transformers 1 & 2, these 2 gave me an option for a bdmv(?) folder. the 3rd is giving the option for 2 video files. I'm fine with this as long as it keeps the Menus & atmos files. I'm using makemkv to play over a zidoo z9x. Any zidoo users out there?
Re: Keeping the Menus
When you're not ripping "everything", the menus would normally be left out, because they're "short" (under 2 minutes). If you are attempting to keep space used to a minimum, the menus will take up space, so ripping to individual files will generally ignore them.
