Hi do anyone still have their Ugoos am6/b plus and can test/confirm if it does 3d either MVC/iso playback?
Many thanks.
Many thanks.
Is anyone familiar with a project called DoViBaker? https://github.com/erazortt/DoViBaker
My understanding from the project description is that this project claims to merge FEL into the BL. Now, I am not super familiar with all improvements reported here in this mega-thread, but if this is correct, would the resulting file allow us to take advantage of FEL improvements on devices that can't handle the FEL info directly?
Thanks, I had to reinstall Plex couple of months ago and I forgot about this option, now I added it back in the form of "192.168.1.0/24", it will turn out next time whether it works.bobbymkV wrote: ↑Wed Sep 14, 2022 5:03 pmI've been using Trick One listed on this site for years.
https://www.howtogeek.com/303282/how-to ... et-access/
I've added dual-track dual-layer input support for (4-2) in DoVi_Scripts_1.5.6
https://drive.google.com/drive/u/1/fold ... J2M9DvOQRu
you are incredible man. for which scenario is this the best choice? also what must i choose for the third choice?RESET_9999 wrote: ↑Sat Sep 17, 2022 3:25 pmI've added dual-track dual-layer input support for (4-2) in DoVi_Scripts_1.5.6
For when you have any MKV Profile 7 input (DT or ST): 4-2-3
If you can, I suggest you input the original bluray disc instead of some random mkv remux: 4-1-1
This is for LG TV playback. For x700/x800m2/oppo, just use the original bluray disc to TS with tsmuxer.
do you have a videogif example to do this? you're gifs are very useful. (original bluray to TS with tsmuxer). i didn't that step before. i did only mkv to bluray folder and then to ts.
I also did a bunch of other gif showing other things you can do with the script:
https://drive.google.com/drive/u/1/fold ... OVQkvbGaq8
Thank you reset_9999! i'm gonna try it tonight. what is the fastest method to convert? the duration is very long. is the convert time with a full bluray much shorter?
another question: Are the new lg oled models playing DV mp4 and ts files via usb? or only profile 8? what is the profit of an LG C9? that it can play also profile 7?
check the link in my signature.kazuma wrote: ↑Sun Sep 18, 2022 9:39 amThank you reset_9999! i'm gonna try it tonight. what is the fastest method to convert? the duration is very long. is the convert time with a full bluray much shorter?
I’ve tested encoding on both windows & Mac
Doblyvision encoding:on windows & Mac
Using cpu to encode produced fantastic results ONLY using CPU.(encode takes a very long time) results are extraordinary
Ofcourse source matters.
Did anyone ever do an visual analysis of a uhd using its native Rpu vs a frame by frame analysis Rpu produced by resolve?
Both Rpu produced from windows & Mac look the same no official sceane count just frame count total so I guess that’s the way resolve handles Profile 5/8.1/8.4
Being that I can uterlize out put blanketing within my frame by frame analysis, trying to determine which will produce the best visual results this mode is for dv live encoding. According to doblyvision notes,
I can also do an 8.1 with both types of Rpu out from resolve using both analysis modes to compare
Futher testing with profile 5 & imfs ,
Tested using a decklink monitor card to oled & shogun, when the external hdr monitor match’s p3d65 or bt2020 of the imf meta data is passed to profile 5
Registered an account just to say thank you to RESET_9999, as well as everyone else. I'm finally able to play Dolby Vision content on my LG C2 via Jellyfin's WebOS app by simply converting Dolby Vision Profile 7 to Profile 8. I'm new to DV and had no idea that DV Profile 7 wasn't supported by a whole lot of devices yet.
Just in case any poor soul is having the problem I was having, here is what I did — using RESET_9999's scripts
Input file (Dolby Vision 7)
Once this process is done, tsMuxeR should open automatically. You should have a P8 file and a E-AC3 file now. All you have to do is feed it those two files and select your desired output format. Pick whichever your media player or TV supports. Thankfully .ts is widely supported on most devices so that should suffice. If in doubt, refer to RESET_9999's incredible playback compatibility chart.
Resulting file is now Dolby Vision 8!
It turns out that the Dolby Vision master for John Wick doesn't add a whole lot. Still, it's a great film and this was a great learning experience.
Again, thank you so much to RESET_9999 for your amazing scripts, the authors of the tools, and everyone on the forums who contributed their knowledge. You guys make this world a better place to live in :]
General
Unique ID : 108575998620693720312303693169930654183 (0x51AEFA08EA461E97531FBEFC934DD1E7)
Complete name : C:\Tools4Movies\John.Wick.2014.2160p.BluRay.REMUX.HEVC.DV.TrueHD.Atmos.7.1-Flights_1.mkv
Format : Matroska
Format version : Version 4
File size : 65.2 GiB
Duration : 1 h 41 min
Overall bit rate mode : Variable
Overall bit rate : 92.2 Mb/s
Movie name : John Wick (2014) 4K DV
Encoded date : UTC 2022-06-19 11:23:51
Writing application : mkvmerge v67.0.0 ('Under Stars') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
ID in the original source m : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 85.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.432
Stream size : 60.7 GiB (93%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light : 227 cd/m2
Original source medium : Blu-ray
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 955 kb/s
Maximum bit rate : 9 456 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.50 GiB (5%)
Title : TrueHD Atmos 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 463 MiB (1%)
Title : AC3 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 224 kb/s
Channel(s) : 2 channels
Stream size : 162 MiB (0%)
Title : Commentary by Filmmakers Chad Stahelski & David Leitch
Language : English
Default : No
Forced : No
General
Complete name : C:\Tools4Movies\John.Wick.2014.2160p.BluRay.REMUX.HEVC.DV.TrueHD.Atmos.7.1-Flights_1_P8.ts
Format : MPEG-TS
File size : 54.2 GiB
Overall bit rate : 76.6 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 71.3 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.358
Stream size : 50.4 GiB (93%)
Audio
Menu ID : 1 (0x1)
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : 132
Bit rate : 1 536 kb/s
Frame rate : 62.500 FPS (768 SPF)
Stream size : 1.09 GiB (2%)
How can I use the graph for my own rpus?RESET_9999 wrote: ↑Sun Sep 18, 2022 3:51 pm↑↑
original vs resolve 2.9 vs hdr10plus vs hdr10 madvr vs resolve 4.0
https://slow.pics/c/ipOD7eqm
To see my own results.
