Disks from same series stop ripping part way through.
sasaki11
#1 Post by sasaki11 » Sat Sep 17, 2022 3:28 pm
I'm recently running into an issue where a series is having issues with disks with ripping all the way. Some disks do finish, others don't. I'm certain the issue are with the disks themselves and not the program or my drive as I've tried the disk in a separate bluray drive as well and I get a similar issue - and disks including 4K from other series work just fine.
What sort of boggles my mind is that these disks all ripped fine before, and now a few months later they won't. Between now and then they've just been sitting in their case on the shelf. Is it an issue with the mastering of the disks, or with the way I've been storing them? I tried cleaning the disks and well, and they just won't finish.
Wondering if anyone else has ran into a similar situation?
The drive I'm currently using is a LG WH16NS40 flashed using the 1.2CW and running in a NexStar DX.
