Different case but same pcbSomeUsername wrote: Thu Sep 15, 2022 4:21 pmThat can brick a drive? Daymn, good to know, ty!Billycar11 wrote: Thu Sep 15, 2022 2:37 pmYeah I'm guessing this is caused by the case don't try and flash it in there anymore with another cheap case I saw a guy brick his drive he had to send it to me for recoverySomeUsername wrote: Thu Sep 15, 2022 2:05 pm
I've bought that cheap one, which was recommended by a friend of mine
https://www.amazon.de/techPulse120-Lauf ... B072WJRK4R
Did some more search and found one of you post, with the recommendation to plugin the drive directly via sata.
I'll try this later when Im back at home
Since dont have any matcha cables/adapters for that slim sata stuff, guess I'm gonna order a Vantec NST-510S3-BK case as recommended in you guide.
Or is there any other (better?) case? I see in your selling thread that you use a different one for the BU40N
Regards and big thanks
Lostintime
I purchased an Archgon MD8107. It came with encrypted 1.02 FW but I was able to flash to 1.03MK.
I have two options for 1.0 firmware, DE_flash_HL-DT-ST_BD-RE_BU40N_BU10 or DE_LG BU40N_1.00 which one do I want to use? MakeMKV says it's a HL-DT-ST drive but I see some people using the LG firmware.
Don't matter same thing the BU10 one is technically for buffalo drivesLostintime wrote: Sat Sep 17, 2022 1:37 pm I purchased an Archgon MD8107. It came with encrypted 1.02 FW but I was able to flash to 1.03MK.
HL stands for Hitachi LG they are all LG drives the ones we flash so far.
MrAshyElbows
Hello all,
This is my first time doing this so please forgive me if my question is a stupid one. I bought the LG WH16NS60 and was able to successfully flash it down...downgrade the firmware to 1.02 or so I believe I did. MakeMKV does show the firmware 1.02.but it still says the type is blu-ray instead of 4K. When it's done properly will it say 4K next to type or will it say blu-ray? I used the SDFtool Flasher (v1.34) in case that makes a difference. I even tried seeing if DVDFab would show 4K, but it keeps prompting "Failure opening the disc due to unfriendly firmware installed on drive". It did it before the flash and it's doing after. I have attached a screenshot in case that helps.
the flash is for makemkmv you need de firmware for other rippers look at the disk type it says uhd so its working properlyMrAshyElbows wrote: Sun Sep 18, 2022 1:33 am Hello all,
This is my first time doing this so please forgive me if my question is a stupid one. I bought the LG WH16NS60 and was able to successfully flash it down...downgrade the firmware to 1.02 or so I believe I did. MakeMKV does show the firmware 1.02.but it still says the type is blu-ray instead of 4K. When it's done properly will it say 4K next to type or will it say blu-ray? I used the SDFtool Flasher (v1.34) in case that makes a difference. I even tried seeing if DVDFab would show 4K, but it keeps prompting "Failure opening the disc due to unfriendly firmware installed on drive". It did it before the flash and it's doing after. I have attached a screenshot in case that helps.2022-09-17 18_31_36-Settings.png
digs5446
Hey guys I really want to get a drive but last time I followed the recommendations here it turned out that the drive was not supported by the currentl for MacOS. I have a 2021 iMac that utilizes the M1 chip.
Can anyone recommend a drive that is compatible with newer Macs? Really don't want to have to return another drive after finding out the hard way.
All the drives work on Mac and always have you had a different problemdigs5446 wrote: Sun Sep 18, 2022 10:37 am Hey guys I really want to get a drive but last time I followed the recommendations here it turned out that the drive was not supported by the currentl for MacOS. I have a 2021 iMac that utilizes the M1 chip.
SomeUsername
So, the new Vantec case just arrived today and now the flashing did work properly like its described here
Guess I can throw away the crappy amazon case now
TsengFayt
Thanks for the guide. I was able to snag an ASUS BW-16D1HT with an older firmware and upgrade to 3.1 Patched.
Looking forward to the new ATHF movies coming out and I can finally put some of my more obscure titles on the Plex.
Thedeanorama
I'm pulling out what's left of my hair.
I have an LG WP50NB40 NB52 that I'm spinning my tires on. I'm using the SDFtool Flasher v1.3.4 to flash the drive. I've tried flashing HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin from the "All that you need firmware pack" to get to stage one of these steps (mainly because I ran into a roadblock sourcing "BP50NB40-NB50-1.03MK") :
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty
The only reason I figure I'm failing is that no matter what I do, and how many times I'm "successful" per SDFtool, BP60NB10 1.00_HBD never takes hold (see link below). For the life of me don't know where I'm going wrong. I'm not new to flashing devices but this is completely evading me.
https://photos.app.goo.gl/tbZiPzKSvKpxTErXA
No, no, no..... No need for the bootloader or my old HBD firmware! All of the required firmware files can be found in the MK firmware pack. Here is the link: viewtopic.php?f=19&t=19113Thedeanorama wrote: Thu Sep 29, 2022 11:06 pm I'm pulling out what's left of my hair.
Here is what to do.:
1. Flash your WP50NB40-NB52-1.03 to BP50NB40-NB50-1.03-MK (or WP50B40-NB50-1.03-MK).
2. For the second flash it is a little different. Select the recovery option.
3. In the popup select the same firmware file that you just previously flashed.
4. Now in the normal firmware selection dropdown box select the firmware you want on the drive (I use either BP60NB10 1.00-MK or BU40N 1.00).
5. Press START and wait around 30 seconds until the process has fully completed and the flasher says "Ready..."
That's it! Easy peasy!!
Thedeanorama
BAM!MartyMcNuts wrote: Fri Sep 30, 2022 12:57 amNo, no, no..... No need for the bootloader or my old HBD firmware! All of the required firmware files can be found in the MK firmware pack. Here is the link: viewtopic.php?f=19&t=19113Thedeanorama wrote: Thu Sep 29, 2022 11:06 pm I'm pulling out what's left of my hair.
Product: BD-RE BP60NB10
Revision: 1.02
The only BP60NB10 bin in the pack you linked was this one at 1.02, will that suffice?
I probably had this earlier in the day, it was the step about grabbing the proper .bin file on the 1st pop up of the Recover Drive I was getting wrong. I was picking the wrong version.
Give it a try. If you don't like it or get read errors then change it. BP60NB10 1.00-MK should be in the "MK/old" folder. You should be able to flash direclty to it from BP60NB10 1.02-MK.Thedeanorama wrote: Fri Sep 30, 2022 2:42 amBAM!MartyMcNuts wrote: Fri Sep 30, 2022 12:57 amNo, no, no..... No need for the bootloader or my old HBD firmware! All of the required firmware files can be found in the MK firmware pack. Here is the link: viewtopic.php?f=19&t=19113Thedeanorama wrote: Thu Sep 29, 2022 11:06 pm I'm pulling out what's left of my hair.
Revision: 1.02
ancient
Hi Marty/Guys
It's been a while since I've flashed, Marty's old version did not have the "include boot loader" option, which the new version does have.
Can someone please explain what this option is for? and does this need to be ticked?
(I'm using it on a BU40N)
Many thanks.
Many thanks.
Nah not needed for a bu40n needed for one of the methods for the bp50sancient wrote: Wed Oct 05, 2022 7:17 pm Hi Marty/Guys
Many thanks.
