Justice League (2017) - which one?
NotMeOssifer
Post by NotMeOssifer » Fri Sep 16, 2022 1:45 pm
Some times when there's no obvious video file, a quick Google brings up a result. Problem is, a quick Google for this keeps bringing up UHD results or the Zack Snyder version that lasts 10 years.
I'm talking about the standard 2017 film.
Ripping both files off the disc puts them both at 2:00:02hrs.
The only difference I see is that one is 25.5GB, 30434total bitrate (t01) whereas the other is 25.1GB, 29985total bitrate (t03).
Which is 'the correct' one?
I've used VLC to randomly skip through as some times you get some kind of anti piracy splash page or whatever but I never saw such a thing.
Side note - while on the topic of this film, I ripped the really long version a while back using MakeMKV.
When watching a 2 disc movie like this via Plex, can you get it to seamlessley move from 1 video file to the other? How do you transition?
Re: Justice League (2017) - which one?
Post by dcoke22 » Mon Sep 19, 2022 3:04 am
NotMeOssifer wrote: Fri Sep 16, 2022 1:45 pm Side note - while on the topic of this film, I ripped the really long version a while back using MakeMKV.
Like almost everything in Plex, you have to name it right.
Naming and organizing your Movie files
See the section titled: Movies Split Across Multiple Files
