Pioneer BDR-XD07UHD FW 8/5/22 dropped Libre [Solved]
kdheslop@gmail.com
#1 Post by kdheslop@gmail.com » Wed Sep 14, 2022 5:21 am
I was having problems with my BD UHD drives spinning errors and noticed new firmware dated 8/5/22, so I updated it and now it says it does not have Libre compatibility.
Of course, then I read that after updating to 1.04 you are not able to go back!
SOLVED: Program (database) updated and running new instance (not new install, just restarting) works now. Thank you Mike and Billy Carr for their help.
Am I the only one that has made this mistake?
Is there a way to enable Libre like before?
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.04
Serial number: THDL002731UC
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: Pioneer RS8D31
Firmware version: ID05
Disc Information
Label: XXXXXXX
Timestamp: 2018-05-24 12:00:07
Protection: AACS2.0/C v61
Data capacity: 62.15 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Last edited by kdheslop@gmail.com on Sat Sep 17, 2022 7:29 pm, edited 4 times in total.
Re: Pioneer BDR-XD07UHD FW 8/5/22 dropped Libre
#2 Post by MartyMcNuts » Wed Sep 14, 2022 8:01 am
I was having problems with my BD UHD drives spinning errors and noticed new firmware dated 8/5/22, so I updated it and now it says it does not have Libre compatability.
Of course then I read that after updating to 1.04 you are not able to go back!
Revision: 1.04
Disc Information
Label: XXXXXXX
Number of layers: 2
Contact @mike admin and see if he can extract a firmware dump from your drive. He can then do his magic and add it to the LibreDrive firmware list.
vMattv
#3 Post by vMattv » Thu Sep 15, 2022 7:57 pm
Yea..... I did the same thing :lol:
#4 Post by mike admin » Sat Sep 17, 2022 7:09 pm
The SDF.bin was just updated a few hours ago. Should work now.
kdheslop@gmail.com
#5 Post by kdheslop@gmail.com » Sat Sep 17, 2022 7:27 pm
GOt message that the program or database is updated and running a new instance of MakeMKV, no new download, just reopening, and the drive works.
vMattv
Re: Pioneer BDR-XD07UHD FW 8/5/22 dropped Libre [Solved]
#6 Post by vMattv » Sat Sep 17, 2022 7:39 pm
Thank you very much!
LeroyJ
#7 Post by LeroyJ » Sun Sep 18, 2022 6:24 am
Quick follow-up question from a new guy - I'm buying this type of drive this week as my first drive to learn with; is the lesson learned from this to not update the firmware of the drive when it arrives, or is it ok to do so knowing that the problem has been resolved on makemkv now?
#8 Post by Billycar11 » Sun Sep 18, 2022 6:45 am
generally a bad idea its likely going to get patched eventually this ones ok but the next may not be
#9 Post by Coopervid » Sun Sep 18, 2022 11:53 am
Mike, I suggest that you add this firmware to the list here so people know that it is now supported:
viewtopic.php?f=19&t=27378
LeroyJ
#10 Post by LeroyJ » Sun Sep 18, 2022 12:41 pm
Thanks for the info.
