Problem with Stargate SG1 Season 4 Disk 5
Email sent to support, but posting here as well. Getting a failed to extract on the final episode of Stargate SG-1, Season 4 on disc 5. Getting the error under both OSX and Windows 7, so it must be a poorly mastered disc.
setarip_old
Re: Problem with Stargate SG1 Season 4 Disk 5
Hi!
1) Have you tried cleaning the disc?
2) Try doing a FULL DISC rip and then do the individual epiusodes from that rip...
Disc is spotless. It rips fine full rip - and all other episodes rip fine as well. Episode fails to rip either from disc or from disc image. Episode plays fine directly from DVD, and Handbrake can rip it - just don't want a re-encode. Same errors many have reported that have been attributed to bad mastering and requires a workaround to be coded in the software. ifo files and debug log were emailed to support.
A 'me too' message, but I am also having problems ripping this episode. Is there any point in me sending IFO/logs to support since others seem to have done the same?
G
G
- Contact:
Please send the full log , C:\Users\jeffb/MakeMKV_log.txt from 1.6.6 to support@makemkv.com . Just the log, no need for IFO files.
Looks like 1.6.7 fixes this. Thanks.
- Contact:
Did you see audio and subtitle tracks in the tree when you opened the disc? Or You've selected all the tracks and they turned out empty?Woodstock wrote:This episode, however, ripped without any alternate audio or subtitle tracks.
