Pioneer BDR-XD07UHD FW 8/5/22 dropped Libre [Solved]
kdheslop@gmail.com
I was having problems with my BD UHD drives spinning errors and noticed new firmware dated 8/5/22, so I updated it and now it says it does not have Libre compatibility.
Of course, then I read that after updating to 1.04 you are not able to go back!
SOLVED: Program (database) updated and running new instance (not new install, just restarting) works now. Thank you Mike and Billy Carr for their help.
Am I the only one that has made this mistake?
Is there a way to enable Libre like before?
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.04
Serial number: THDL002731UC
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: Pioneer RS8D31
Firmware version: ID05
Disc Information
Label: XXXXXXX
Timestamp: 2018-05-24 12:00:07
Protection: AACS2.0/C v61
Data capacity: 62.15 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Revision: 1.04
Disc Information
Label: XXXXXXX
Number of layers: 2
Last edited by kdheslop@gmail.com on Sat Sep 17, 2022 7:29 pm, edited 4 times in total.
Re: Pioneer BDR-XD07UHD FW 8/5/22 dropped Libre
Contact @mike admin and see if he can extract a firmware dump from your drive. He can then do his magic and add it to the LibreDrive firmware list.kdheslop@gmail.com wrote: ↑Wed Sep 14, 2022 5:21 amI was having problems with my BD UHD drives spinning errors and noticed new firmware dated 8/5/22, so I updated it and now it says it does not have Libre compatability.
Of course then I read that after updating to 1.04 you are not able to go back!
Revision: 1.04
Disc Information
Label: XXXXXXX
Number of layers: 2
Yea..... I did the same thing
- Contact:
The SDF.bin was just updated a few hours ago. Should work now.
kdheslop@gmail.com
GOt message that the program or database is updated and running a new instance of MakeMKV, no new download, just reopening, and the drive works.MartyMcNuts wrote: ↑Wed Sep 14, 2022 8:01 am
Re: Pioneer BDR-XD07UHD FW 8/5/22 dropped Libre [Solved]
Thank you very much!
Quick follow-up question from a new guy - I'm buying this type of drive this week as my first drive to learn with; is the lesson learned from this to not update the firmware of the drive when it arrives, or is it ok to do so knowing that the problem has been resolved on makemkv now?
generally a bad idea its likely going to get patched eventually this ones ok but the next may not beLeroyJ wrote: ↑Sun Sep 18, 2022 6:24 amQuick follow-up question from a new guy - I'm buying this type of drive this week as my first drive to learn with; is the lesson learned from this to not update the firmware of the drive when it arrives, or is it ok to do so knowing that the problem has been resolved on makemkv now?
Mike, I suggest that you add this firmware to the list here so people know that it is now supported:mike admin wrote: ↑Sat Sep 17, 2022 7:09 pmThe SDF.bin was just updated a few hours ago. Should work now.
viewtopic.php?f=19&t=27378
Thanks for the info.
