Failed to install CDRom Device Arbiter Service
DigitalJockey
Post by DigitalJockey » Sun Sep 11, 2022 11:59 pm
Hello all,
I was just installing MakeMKV on my recently formated PC and while installing I´ve got a message saying "Failed to install CDRom Device Arbiter Service" and the only option I had was to proceed with the installation.
What can I do to correct this?
Thank you
Re: Failed to install CDRom Device Arbiter Service
Post by Woodstock » Mon Sep 12, 2022 1:32 am
Should work without it. The arbiter service is a way to bypass some of the {stuff} that Windows tries to put in your way.
I disable the installation on my Win7 machine. Might be more critical on Win10/11, unless you set the ownership properly. The arbiter service sets up a supervisor task that will talk to the drive when you're not running as a supervisor.
