Making changes to GUI
danielelectronics
Post by danielelectronics »
Hello All,
I've read on this forum and on reddit that "the GUI is open source" but after reading the license.txt file from the makemkv-oss source code archive that I downloaded from this forum, I am not so sure.
Basically, I want to make some very minor changes to the source code for the GUI to add some convenience features. I want to add "Select all but this item" and "Unselect all but this item" to the right-click menu in the title tree view. I'd like to share the changes as a patch file on this forum so that other people can apply the patch before building the GUI from source if they find these features useful.
Would this be a violation of the license? Whom should I ask for permission (if required)?
Thanks in advance!
Re: Making changes to GUI
Not sure what you would have read that says MakeMKV is "open source". Parts of it are, and those are isolated from the closed-source stuff.
danielelectronics
This thread say the GUI is open source.
viewtopic.php?t=3891#top
But when I downloaded the source code for the GUI from this post (link below), the license.txt file makes it seem like only some of it is open source. viewtopic.php?f=3&t=224
So I guess that's what I'm asking for clarification on. Can I modify some of the files that make up the GUI?
You can make any changes you want to the source, be it closed or open. Distributing changes would be different; but it's been so long since I looked at the source code I can't say what.
As I remember it, the parts that weren't "open source" were compressed in a way that made them non-readable.
Mike will have to say what's what, though.
danielelectronics
Thanks for the quick responses, Woodstock. Is Mike the author/owner of the program?
He's "the MAN", owner and author.
danielelectronics
:D
Well he's a legend for making this software. And for only $60.
danielelectronics
I've attached a gif of the feature. If I get permission, I'll share the changes in this forum as a patch file that folks can use when building the GUI from source.
Jimmers
Post by Jimmers »
Bump
I have run into several disks that use an obfuscation technique that creates a very large list of files that must be deselected. They can average around 100. This is a very tedious process to and the ability to de/select all would be very helpful
Post by mike admin »
To be honest, the MakeMKV GUI is open source mostly to satisfy the QT (and others) licensing requirements, and to ease the linux build. It was "truly" open source for a while, but was discontinued then.
As for your changes - obliviously, your contribution would be very welcome. I'd prefer to avoid making forks - so it wold be nice to integrate your changes into main source tree.
Thanks for asking the permission.
Please write me to support@makemkv.com .
wmcclain
Post by wmcclain »
Jimmers wrote: Thu Dec 22, 2022 12:10 pm Bump
Try right-click on the list.
Jimmers
Post by Jimmers »
wmcclain wrote: Fri Dec 23, 2022 5:27 pm Try right-click on the list.
I have.
danielelectronics
mike admin wrote: Thu Dec 22, 2022 4:09 pm To be honest, the MakeMKV GUI is open source mostly to satisfy the QT (and others) licensing requirements, and to ease the linux build. It was "truly" open source for a while, but was discontinued then.
Thank you for following up on this. I had forgotten about it to be honest. I would love it if these changes were included in the main source. I just made sure that everything still worked on 1.17.2, and sent a patch file with the changes to support@makemkv.com.
Thanks again,
Daniel
