kazuma wrote: Fri Sep 09, 2022 8:11 pm
i get the same error if i skip the sup file. i don't need subtitle anyway.
one last thing...
are you using the bat file outside of the DoVi_Scripts folder? if yes, then that's the problem.
The bat file must be inside the folder otherwise the path to the tools wont work. If you want it somewhere else on your PC, make a shortcut.
one last thing...
no, inside. i'm trying now for hours but i get always the same error.
ow my god, i think it worked! i don't have a error this time! i know it was simple , but i was too stupid to get it right. you are a incredibly guy many thanks man!
sw5163 wrote: Thu Sep 08, 2022 3:55 pm
Another interesting thing regarding the "complexity index",
on Windows Movies & TV:
`ffmpeg -i atmos(7.1).eac3 -c copy` (breaks complexity index) shows 6 channel:
Correction: it's not atmos or "complexity index"
Any 7.1.ec3 copy by ffmpeg shows 6 channel
1536kb/s or 1664 kb/s 7.1.ec3 won't play on Apple.
768kb/s 7.1.ec3 plays fine.
1536kb/s 5.1.ec3 plays fine.
No idea what's going on here.
Also @RESET_9999 do you think an eac3 with core inside it can be added to mp4?
Complete name : D:\P8_DoVi.au.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 187 MiB
Duration : 2 min 1 s
Overall bit rate : 12.9 Mb/s
Encoded date : UTC 2022-09-09 22:25:50
Tagged date : UTC 2022-09-09 22:25:50
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 12.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.061
Stream size : 176 MiB (94%)
Default : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Format profile : Blu-ray Disc
Codec ID : ec-3
Duration : 1 min 0 s
Bit rate mode : Constant
Bit rate : 1 512 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Tfl Tfr
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 10.8 MiB (6%)
Service kind : Complete Main
Default : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
sw5163 wrote: Fri Sep 09, 2022 10:20 pm
yep
Could you please share the steps for doing this?
Does it has to use DEE? Many thanks.
Since 1536kb/s 7.1.ec3 won't play on Apple. I want to give some test to see what will happen if I encode an ac3 core to it.
Maybe also TrueHD with core to mp4, it's unlikely Apple will play TrueHD though.
sw5163 wrote: Fri Sep 09, 2022 11:03 pm
I just used my script(7-1-1) with a random P8 BL and this Atmos 7.1 EC3 track from Snyders Justice League(somehow a release group was able to achieve that). https://drive.google.com/file/d/170Te6w ... sp=sharing
I just tested on my TV, and I get the same result as my DEE 7.1 (without atmos) tracks. AVR reports Dolby surround PCM. its playing the ac3 core
Yep, the only way I know to encode 7.1 EC3 with a core is with DEE.
IIRC, it only works with pure TrueHD without a core. DTSHD works too and the mp4(dv + audio) plays fine on my C8
kazuma wrote: Fri Sep 09, 2022 11:41 pm
there is no difference betweeen profile 7 and profile 8 on an LG C9 i think?
There should be, unless c9 doesn’t support FEL dv.
Please check https://www.avsforum.com/threads/dune-p ... t-60582530.
If p7 and p8 look the same, it could because the improvement from MEL->FEL is not very noticeable when watching real content.
But the difference can be observed once you test it with those synthetic FEL test.
You can test it with those FEL test files under @RESET_9999’s signature, if you want.
