kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 7:02 pm
kazuma wrote:
Fri Sep 09, 2022 6:50 pm
s04e06. but i think the problem is different. very thanks for your input for this noob. my tsmuxer is from this website https://www.videohelp.com/software/tsMuxeR. but you gave me a another link. i think the problem is there. but i can't start you're tsmuxer because there is no tsmuxer.exe gui in it.
yep, that's the problem.
get the latest from GitHub or you can use the one included in my script tool pack (tools folder / tsmuxer GUI).
you're tsmuxer didnt work :| . i'm now gonna try your last post.
kazuma wrote:
Fri Sep 09, 2022 7:30 pm
mmm, that's the one I used in all my GIF examples...
kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 7:33 pm
i get again the messages that 'the files couldn't be found' in command. (in dutch). there is a small little error on all this i think, but what?, i've even tried to run cmd as administrator, i restarted my laptop. very strange.
kazuma wrote:
Fri Sep 09, 2022 7:49 pm
can you post the full log of the script like this:
                        _____    __      ___       _____           _       _
                       |  __ \   \ \    / (_)     / ____|         (_)     | |
                       | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
                       | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
                       | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
                       |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
                       -@RESET_9999---------------------------------|__|-----------
 Choose a mode...
1) MODE.I=  DoVi Convert/Edit/Sync/Inject (Base Layer file + P8/P7/P5 DoVi file to Profile 8)
2) MODE.F=  DoVi Fix/Extract/Info/Verify-Sync-Brightness
3) MODE.H=  DoVi Maker (from HDR10 madVR or HDR10plus)
4) MODE.P=  Profile 7 Input (MKV/BDMV)
5) MODE.B=  Dovi Batch tsMuxer: MKV/MP4 to TS (ST-DV+DD+SUB)
6) MODE.M=  MIXED: Remover/Measurer/Playlist/Audio and more...
7) MODE.M4= MP4_MUXER Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?4
                                           * CHOOSE A MODE *
1) MODE.1= Bluray Disc to Profile 8 or ST Profile 7
2) MODE.2= MKV ST Profile 7 to Profile 8
3) MODE.3= DEMUX MKV Profile 7 ST-DL to DT-DL
4) MODE.4= Back to main menu
Choice? [1,2,3,4]?1
                                         * CHOOSE A WORKFLOW *
1) Workflow.1= Bluray Disc to Profile 8 + DD+
2) Workflow.2= Bluray Disc to Profile 8 + DD+ 7.1 (DEE only)
3) Workflow.3= Bluray Disc to Profile 8
4) Workflow.4= Bluray Disc to Profile 7 Single-Track Dual-Layer
5) Workflow.5= back to main menu
Choice? [1,2,3,4,5]?3
Un sous-répertoire ou un fichier D:\TEMP_folder existe déjà.
--This workflow will convert a dual layer bluray MPLS to profile 8
Drag and drop your BDMV folder and press enter...
Drag and drop the main movie playlist (MPLS) and press enter...
D:\samples\muti.lang.bd\BDMV\PLAYLIST\00000.mpls
Do you want to edit L5... y or n ? and/or press enter...
DGDemux 1.0.0.59 by Donald A. Graft
Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA]
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
'D:\TEMP_folder\EL.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'D:\TEMP_folder\EL.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
The file 'D:\TEMP_folder\EL.mkv' has been opened for writing.
'D:\TEMP_folder\EL.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1920/1080.
Progress: 100%
The cue entries (the index) are being written...
Multiplexing took 2 seconds.
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      57. 17.100 / 57. 17.100
  libavcodec     59. 18.100 / 59. 18.100
  libavformat    59. 16.100 / 59. 16.100
  libavdevice    59.  4.100 / 59.  4.100
  libavfilter     8. 24.100 /  8. 24.100
  libswscale      6.  4.100 /  6.  4.100
  libswresample   4.  3.100 /  4.  3.100
  libpostproc    56.  3.100 / 56.  3.100
Input #0, matroska,webm, from 'D:\TEMP_folder\EL.mkv':
  Metadata:
    encoder         : libebml v1.4.2 + libmatroska v1.6.4
  Duration: 00:09:59.89, start: 0.000000, bitrate: 7369 kb/s
  Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
      BPS             : 7367224
      DURATION        : 00:09:59.891000000
      NUMBER_OF_FRAMES: 14383
      NUMBER_OF_BYTES : 552441436
      _STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Side data:
      DOVI configuration record: version: 1.0, profile: 7, level: 3, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6
Output #0, matroska, to 'D:\TEMP_folder\chunk.mkv':
  Metadata:
    encoder         : Lavf59.16.100
  Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
      BPS             : 7367224
    Side data:
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
Press [q] to stop, [?] for help
frame=  942 fps=0.0 q=-1.0 Lsize=   15544kB time=00:00:39.99 bitrate=3183.5kbits/s speed=1.27e+03x
video:15534kB audio:0kB subtitle:0kB other streams:0kB global headers:1kB muxing overhead: 0.065136%
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP_folder\el.chunk.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Parsing RPU file...
Exporting metadata...
Done.
D:\TEMP_folder\rpu-text.json
converting and injecting RPU...
Rewriting file with interleaved EL NALUs..
        1 fichier(s) déplacé(s).
"The script has completed."
kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 7:57 pm
 Choose a mode...
8) Exit
                                           * CHOOSE A MODE *
Choice? [1,2,3,4]?1
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
Progress: 100%
  Metadata:
    Metadata:
      BPS             : 7367224
    Side data:
  Metadata:
    Metadata:
      BPS             : 7367224
    Side data:
Stream mapping:
Progress: 100%
Parsing RPU file...
Done.
Choose a mode...
8) Exit
Choice? [1,2,3,4,5,6,7,8]?7
* CHOOSE A MODE *
1) MODE.1= Single-Track (p5, p8, p7)
2) MODE.2= Dual-Track (p7)
3) MODE.3= Demuxer (p5, p8, p7)
4) MODE.4= Apple iOS compatible MP4
5) MODE.5= back to main menu
Choice? [1,2,3,4,5]?2
* CHOOSE A WORFLOW *
1) Workflow.1= HEVC-1(BL) + HEVC-2(EL) + AUDIO + SRT subtitle(optionnal)
2) Workflow.2= MPLS P7 bluray to DT-DL + EAC3 + SRT subtitles(optionnal)
3) Workflow.3= MKV P7 to DT-DL + EAC3 + SRT subtitles(optionnal)
4) Workflow.4= back to main menu
Choice? [1,2,3,4]?1
-- Input can be HEVC/H265 - SRT/AC3/EC3/AAC/DTS/DTSHD/TrueHD
-- If no subtitles, just press enter to skip
Drag and drop BL and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_1_eng.hevc
Drag and drop EL and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_2_und.hevc
Drag and drop your audio file and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_5_eng.ac3
Drag and drop your SRT subtitle file and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_25_nld.sup
muxing into a MP4 profile 7 DoVi file. Be patient, it can take a while. 40min+ on slow HDD
Het systeem kan het opgegeven pad niet vinden. (the path cannot be found)
the script has completed...
sup subtitles are not supported. You must use the SRT subs
kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 8:06 pm
i get the same error if i skip the sup file. i don't need subtitle anyway.
kazuma wrote:
Fri Sep 09, 2022 8:11 pm
Well idk and I'm out of ideas. sorry :(
one last thing...
are you using the bat file outside of the DoVi_Scripts folder? if yes, then that's the problem.
The bat file must be inside the folder otherwise the path to the tools wont work. If you want it somewhere else on your PC, make a shortcut.
kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 9:20 pm
one last thing...
no, inside. i'm trying now for hours but i get always the same error.
kazuma wrote:
Fri Sep 09, 2022 9:47 pm
very strange because when I move the bat file outside the dovi_script folder I get exactly the same error you got.
kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 9:51 pm
thats interesting. now i doubt. can you make a video.gif again how i suppose to do?
kazuma
Post by kazuma »
RESET_9999 wrote:
Fri Sep 09, 2022 10:09 pm
ow my god, i think it worked! i don't have a error this time! i know it was simple , but i was too stupid to get it right. you are a incredibly guy many thanks man!
sw5163
Post by sw5163 »
sw5163 wrote:
Thu Sep 08, 2022 3:55 pm
Another interesting thing regarding the "complexity index",
on Windows Movies & TV:
`ffmpeg -i atmos(7.1).eac3 -c copy` (breaks complexity index) shows 6 channel:
Correction: it's not atmos or "complexity index"
Any 7.1.ec3 copy by ffmpeg shows 6 channel
1536kb/s or 1664 kb/s 7.1.ec3 won't play on Apple.
768kb/s 7.1.ec3 plays fine.
1536kb/s 5.1.ec3 plays fine.
No idea what's going on here.
Also @RESET_9999 do you think an eac3 with core inside it can be added to mp4?
