I just hate the MP4 container
you're tsmuxer didnt workRESET_9999 wrote: ↑Fri Sep 09, 2022 7:02 pmyep, that's the problem.kazuma wrote: ↑Fri Sep 09, 2022 6:50 pms04e06. but i think the problem is different. very thanks for your input for this noob. my tsmuxer is from this website https://www.videohelp.com/software/tsMuxeR. but you gave me a another link. i think the problem is there. but i can't start you're tsmuxer because there is no tsmuxer.exe gui in it.
get the latest from GitHub or you can use the one included in my script tool pack (tools folder / tsmuxer GUI).
mmm, that's the one I used in all my GIF examples...
i get again the messages that 'the files couldn't be found' in command. (in dutch). there is a small little error on all this i think, but what?, i've even tried to run cmd as administrator, i restarted my laptop. very strange.
can you post the full log of the script like this:
_____ __ ___ _____ _ _
| __ \ \ \ / (_) / ____| (_) | |
| | | | __\ \ / / _ | (___ ___ _ __ _ _ __ | |_ ___
| | | |/ _ \ \/ / | | \___ \ / __| '__| | '_ \| __/ __|
| |__| | (_) \ / | | ____) | (__| | | | |_) | |_\__ \
|_____/ \___/ \/ |_| |_____/ \___|_| |_| .__/ \__|___/
-@RESET_9999---------------------------------|__|-----------
Choose a mode...
1) MODE.I= DoVi Convert/Edit/Sync/Inject (Base Layer file + P8/P7/P5 DoVi file to Profile 8)
2) MODE.F= DoVi Fix/Extract/Info/Verify-Sync-Brightness
3) MODE.H= DoVi Maker (from HDR10 madVR or HDR10plus)
4) MODE.P= Profile 7 Input (MKV/BDMV)
5) MODE.B= Dovi Batch tsMuxer: MKV/MP4 to TS (ST-DV+DD+SUB)
6) MODE.M= MIXED: Remover/Measurer/Playlist/Audio and more...
7) MODE.M4= MP4_MUXER Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?4
* CHOOSE A MODE *
1) MODE.1= Bluray Disc to Profile 8 or ST Profile 7
2) MODE.2= MKV ST Profile 7 to Profile 8
3) MODE.3= DEMUX MKV Profile 7 ST-DL to DT-DL
4) MODE.4= Back to main menu
Choice? [1,2,3,4]?1
* CHOOSE A WORKFLOW *
1) Workflow.1= Bluray Disc to Profile 8 + DD+
2) Workflow.2= Bluray Disc to Profile 8 + DD+ 7.1 (DEE only)
3) Workflow.3= Bluray Disc to Profile 8
4) Workflow.4= Bluray Disc to Profile 7 Single-Track Dual-Layer
5) Workflow.5= back to main menu
Choice? [1,2,3,4,5]?3
Un sous-répertoire ou un fichier D:\TEMP_folder existe déjà.
--This workflow will convert a dual layer bluray MPLS to profile 8
Drag and drop your BDMV folder and press enter...
Drag and drop the main movie playlist (MPLS) and press enter...
D:\samples\muti.lang.bd\BDMV\PLAYLIST\00000.mpls
Do you want to edit L5... y or n ? and/or press enter...
DGDemux 1.0.0.59 by Donald A. Graft
Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA]
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
'D:\TEMP_folder\EL.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'D:\TEMP_folder\EL.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
The file 'D:\TEMP_folder\EL.mkv' has been opened for writing.
'D:\TEMP_folder\EL.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1920/1080.
Progress: 100%
The cue entries (the index) are being written...
Multiplexing took 2 seconds.
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
libavutil 57. 17.100 / 57. 17.100
libavcodec 59. 18.100 / 59. 18.100
libavformat 59. 16.100 / 59. 16.100
libavdevice 59. 4.100 / 59. 4.100
libavfilter 8. 24.100 / 8. 24.100
libswscale 6. 4.100 / 6. 4.100
libswresample 4. 3.100 / 4. 3.100
libpostproc 56. 3.100 / 56. 3.100
Input #0, matroska,webm, from 'D:\TEMP_folder\EL.mkv':
Metadata:
encoder : libebml v1.4.2 + libmatroska v1.6.4
Duration: 00:09:59.89, start: 0.000000, bitrate: 7369 kb/s
Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
Metadata:
BPS : 7367224
DURATION : 00:09:59.891000000
NUMBER_OF_FRAMES: 14383
NUMBER_OF_BYTES : 552441436
_STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Side data:
DOVI configuration record: version: 1.0, profile: 7, level: 3, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6
Output #0, matroska, to 'D:\TEMP_folder\chunk.mkv':
Metadata:
encoder : Lavf59.16.100
Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn (default)
Metadata:
BPS : 7367224
Side data:
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Press [q] to stop, [?] for help
frame= 942 fps=0.0 q=-1.0 Lsize= 15544kB time=00:00:39.99 bitrate=3183.5kbits/s speed=1.27e+03x
video:15534kB audio:0kB subtitle:0kB other streams:0kB global headers:1kB muxing overhead: 0.065136%
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP_folder\el.chunk.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Parsing RPU file...
Exporting metadata...
Done.
D:\TEMP_folder\rpu-text.json
converting and injecting RPU...
Rewriting file with interleaved EL NALUs..
1 fichier(s) déplacé(s).
"The script has completed."| __ \ \ \ / (_) / ____| (_) | |RESET_9999 wrote: ↑Fri Sep 09, 2022 7:57 pmcan you post the full log of the script like this:
_____ __ ___ _____ _ _ | __ \ \ \ / (_) / ____| (_) | | | | | | __\ \ / / _ | (___ ___ _ __ _ _ __ | |_ ___ | | | |/ _ \ \/ / | | \___ \ / __| '__| | '_ \| __/ __| | |__| | (_) \ / | | ____) | (__| | | | |_) | |_\__ \ |_____/ \___/ \/ |_| |_____/ \___|_| |_| .__/ \__|___/ -@RESET_9999---------------------------------|__|----------- Choose a mode... 1) MODE.I= DoVi Convert/Edit/Sync/Inject (Base Layer file + P8/P7/P5 DoVi file to Profile 8) 2) MODE.F= DoVi Fix/Extract/Info/Verify-Sync-Brightness 3) MODE.H= DoVi Maker (from HDR10 madVR or HDR10plus) 4) MODE.P= Profile 7 Input (MKV/BDMV) 5) MODE.B= Dovi Batch tsMuxer: MKV/MP4 to TS (ST-DV+DD+SUB) 6) MODE.M= MIXED: Remover/Measurer/Playlist/Audio and more... 7) MODE.M4= MP4_MUXER Workflows 8) Exit Choice? [1,2,3,4,5,6,7,8]?4 ***************** * CHOOSE A MODE * ***************** 1) MODE.1= Bluray Disc to Profile 8 or ST Profile 7 2) MODE.2= MKV ST Profile 7 to Profile 8 3) MODE.3= DEMUX MKV Profile 7 ST-DL to DT-DL 4) MODE.4= Back to main menu Choice? [1,2,3,4]?1 ********************* * CHOOSE A WORKFLOW * ********************* 1) Workflow.1= Bluray Disc to Profile 8 + DD+ 2) Workflow.2= Bluray Disc to Profile 8 + DD+ 7.1 (DEE only) 3) Workflow.3= Bluray Disc to Profile 8 4) Workflow.4= Bluray Disc to Profile 7 Single-Track Dual-Layer 5) Workflow.5= back to main menu Choice? [1,2,3,4,5]?3 Un sous-répertoire ou un fichier D:\TEMP_folder existe déjà. ------------------------------------------------------------------ --This workflow will convert a dual layer bluray MPLS to profile 8 ------------------------------------------------------------------ Drag and drop your BDMV folder and press enter... Drag and drop the main movie playlist (MPLS) and press enter... D:\samples\muti.lang.bd\BDMV\PLAYLIST\00000.mpls Do you want to edit L5... y or n ? and/or press enter... DGDemux 1.0.0.59 by Donald A. Graft Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA] 00000.m2ts 1 % 2 % 3 % 4 % 5 % 6 % 7 % 8 % 9 % 10 % 11 % 12 % 13 % 14 % 15 % 16 % 17 % 18 % 19 % 20 % 21 % 22 % 23 % 24 % 25 % 26 % 27 % 28 % 29 % 30 % 31 % 32 % 33 % 34 % 35 % 36 % 37 % 38 % 39 % 40 % 41 % 42 % 43 % 44 % 45 % 46 % 47 % 48 % 49 % 50 % 51 % 52 % 53 % 54 % 55 % 56 % 57 % 58 % 59 % 60 % 61 % 62 % 63 % 64 % 65 % 66 % 67 % 68 % 69 % 70 % 71 % 72 % 73 % 74 % 75 % 76 % 77 % 78 % 79 % 80 % 81 % 82 % 83 % 84 % 85 % 86 % 87 % 88 % 89 % 90 % 91 % 92 % 93 % 94 % 95 % 96 % 97 % 98 % 99 % 100 % Done! mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit 'D:\TEMP_folder\EL.hevc': Using the demultiplexer for the format 'HEVC/H.265'. 'D:\TEMP_folder\EL.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'. The file 'D:\TEMP_folder\EL.mkv' has been opened for writing. 'D:\TEMP_folder\EL.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1920/1080. Progress: 100% The cue entries (the index) are being written... Multiplexing took 2 seconds. ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers built with gcc 11.2.0 (Rev7, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 57. 17.100 / 57. 17.100 libavcodec 59. 18.100 / 59. 18.100 libavformat 59. 16.100 / 59. 16.100 libavdevice 59. 4.100 / 59. 4.100 libavfilter 8. 24.100 / 8. 24.100 libswscale 6. 4.100 / 6. 4.100 libswresample 4. 3.100 / 4. 3.100 libpostproc 56. 3.100 / 56. 3.100 Input #0, matroska,webm, from 'D:\TEMP_folder\EL.mkv': Metadata: encoder : libebml v1.4.2 + libmatroska v1.6.4 Duration: 00:09:59.89, start: 0.000000, bitrate: 7369 kb/s Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default) Metadata: BPS : 7367224 DURATION : 00:09:59.891000000 NUMBER_OF_FRAMES: 14383 NUMBER_OF_BYTES : 552441436 _STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Side data: DOVI configuration record: version: 1.0, profile: 7, level: 3, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6 Output #0, matroska, to 'D:\TEMP_folder\chunk.mkv': Metadata: encoder : Lavf59.16.100 Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn (default) Metadata: BPS : 7367224 DURATION : 00:09:59.891000000 NUMBER_OF_FRAMES: 14383 NUMBER_OF_BYTES : 552441436 _STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Side data: DOVI configuration record: version: 1.0, profile: 7, level: 3, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6 Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help frame= 942 fps=0.0 q=-1.0 Lsize= 15544kB time=00:00:39.99 bitrate=3183.5kbits/s speed=1.27e+03x video:15534kB audio:0kB subtitle:0kB other streams:0kB global headers:1kB muxing overhead: 0.065136% Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP_folder\el.chunk.hevc'. Container format: HEVC/H.265 elementary stream Progress: 100% Reordering metadata... Done. Parsing RPU file... Exporting metadata... Done. D:\TEMP_folder\rpu-text.json converting and injecting RPU... Rewriting file with interleaved EL NALUs.. 1 fichier(s) déplacé(s). "The script has completed."
i get the same error if i skip the sup file. i don't need subtitle anyway.RESET_9999 wrote: ↑Fri Sep 09, 2022 8:06 pmsup subtitles are not supported. You must use the SRT subs
Well idk and I'm out of ideas. sorry
one last thing...
no, inside. i'm trying now for hours but i get always the same error.RESET_9999 wrote: ↑Fri Sep 09, 2022 9:20 pmone last thing...
are you using the bat file outside of the DoVi_Scripts folder? if yes, then that's the problem.
The bat file must be inside the folder otherwise the path to the tools wont work. If you want it somewhere else on your PC, make a shortcut.
very strange because when I move the bat file outside the dovi_script folder I get exactly the same error you got.
thats interesting. now i doubt. can you make a video.gif again how i suppose to do?RESET_9999 wrote: ↑Fri Sep 09, 2022 9:51 pmvery strange because when I move the bat file outside the dovi_script folder I get exactly the same error you got.
ow my god, i think it worked! i don't have a error this time! i know it was simple , but i was too stupid to get it right. you are a incredibly guy many thanks man!
