kazuma
Post by kazuma » Fri Sep 09, 2022 6:01 pm
RESET_9999 wrote: Fri Sep 09, 2022 5:38 pm
kazuma wrote: Fri Sep 09, 2022 5:26 pm i have downloaded a mkv remux of game of thrones episode. if i drag this file to your dovi script, it says no DV found. so i've mux the file with tsmuxer (not the tsmuxer of your link because there is no .exe?) to .ts with the baselayer, dvlayer and truehd. then i've dragged this to your doviscript program, but there is no dv file found.
i'm doing wrong, but what? can you please explain in me in steps?
Sounds like your file is dual-track DV (hdr layer + 1080p dv layer) which is not supported in MKV. I see that rarbg did that instead of Single track P7.
So what you have to do is:
1- Remux the mkv to bluray folder output with tsmuxer ( select only video 1 + 2, AC3).... uncheck TrueHD!
2- Then in my script use: 4-1-3 Go in the new bluray folder, drag and drop the MPLS file ( playlist folder) two times (first-time scan all the playlists, 2nd-time process the movie).
i did the steps but it not worked. again 'Input file doesnt contain a Dolby Vision track'. and yes the file is from rarbg.
Post by RESET_9999 » Fri Sep 09, 2022 6:18 pm
kazuma wrote: Fri Sep 09, 2022 6:01 pm i did the steps but it not worked. again 'Input file doesnt contain a Dolby Vision track'.
Well, I don't know what you're doing wrong because it's working (see the gif).
Do it manually with yusesope's tool otherwise:viewtopic.php?f=12&t=18602&start=2970#p96282
kazuma
Post by kazuma » Fri Sep 09, 2022 6:23 pm
RESET_9999 wrote: Fri Sep 09, 2022 6:18 pm
i do exactly the same thing. i get the message 'no files can be found', FINDSTR: Cannot open D:\TEMP_folder\rpu-text.json
converting and injecting RPU...Input file doesnt contain a Dolby Vision track'
Post by RESET_9999 » Fri Sep 09, 2022 6:26 pm
did you uncheck TrueHD before muxing the bluray folder ?
dgdemux(my script use it to demux) wont work with BDMV that contain a truehd (without core)
kazuma
Post by kazuma » Fri Sep 09, 2022 6:27 pm
RESET_9999 wrote: Fri Sep 09, 2022 6:26 pm did you uncheck TrueHD before muxing the bluray folder ?
yes , i selected ac3 audio. strange...
Post by RESET_9999 » Fri Sep 09, 2022 6:32 pm
kazuma wrote: Fri Sep 09, 2022 6:27 pm yes , i selected ac3 audio. strange...
which episode-season. I'll try
kazuma
Post by kazuma » Fri Sep 09, 2022 6:50 pm
RESET_9999 wrote: Fri Sep 09, 2022 6:32 pm
s04e06. but i think the problem is different. very thanks for your input for this noob. my tsmuxer is from this website https://www.videohelp.com/software/tsMuxeR. but you gave me a another link. i think the problem is there. but i can't start you're tsmuxer because there is no tsmuxer.exe gui in it.
Post by RESET_9999 » Fri Sep 09, 2022 7:02 pm
kazuma wrote: Fri Sep 09, 2022 6:50 pm s04e06. but i think the problem is different. very thanks for your input for this noob. my tsmuxer is from this website https://www.videohelp.com/software/tsMuxeR. but you gave me a another link. i think the problem is there. but i can't start you're tsmuxer because there is no tsmuxer.exe gui in it.
yep, that's the problem.
get the latest from GitHub or you can use the one included in my script tool pack (tools folder / tsmuxer GUI).
sw5163
Post by sw5163 » Fri Sep 09, 2022 7:05 pm
I see from @RESET_9999 's Playback-Devices C9 should support FEL mp4 and lossy audio.
If you want to do it manually, for example for the
'Game.of.Thrones.S01.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT'
You could try:
1. Extract bl.hevc, el.hevc, audio.ac3
ffmpeg -i remux.mkv -map 0:0 -c copy bl.hevc -map 0:1 -c copy el.hevc -map 0:4 -c copy audio.ac3
2. Mux using old mp4muxer from @RESET_9999 's tools pack
mp4muxer -i bl.hevc -i el.hevc -i audio.ac3 -o dual_track_fel.mp4
or if above is "not stable"
2. Generate single track BL_EL_RPU.hevc by dovi_tool (yusesope's tool is a little complicated)
dovi_tool mux --bl bl.hevc --el el.hevc
3. Mux using old mp4muxer from @RESET_9999 's tools pack
mp4muxer -i BL_EL_RPU.hevc -i audio.ac3 -o single_track_fel.mp4
But I'm not very certain about these command lines, please double check @RESET_9999 and point out my mistakes, thanks! :)
If both @RESET_9999 's script and above fail, it may because the file is corrupted.
Edit: Oh I see you have already found the problem, cheers.
Post by RESET_9999 » Fri Sep 09, 2022 7:24 pm
yes, that would work too and can be done without using command lines ( i know some people are afraid of cmd-line ).
I just hate the MP4 container :) and there's nothing i hate more than getting ready to watch a movie only to find out it doesnt play properly :(
kazuma
Post by kazuma » Fri Sep 09, 2022 7:30 pm
RESET_9999 wrote: Fri Sep 09, 2022 7:02 pm
you're tsmuxer didnt work :| . i'm now gonna try your last post.
Post by RESET_9999 » Fri Sep 09, 2022 7:33 pm
kazuma wrote: Fri Sep 09, 2022 7:30 pm you're tsmuxer didnt work :| . i'm now gonna try your last post.
mmm, that's the one I used in all my GIF examples...
kazuma
Post by kazuma » Fri Sep 09, 2022 7:49 pm
RESET_9999 wrote: Fri Sep 09, 2022 7:33 pm
i get again the messages that 'the files couldn't be found' in command. (in dutch). there is a small little error on all this i think, but what?, i've even tried to run cmd as administrator, i restarted my laptop. very strange.
Post by RESET_9999 » Fri Sep 09, 2022 7:57 pm
kazuma wrote: Fri Sep 09, 2022 7:49 pm i get again the messages that 'the files couldn't be found' in command. (in dutch). there is a small little error on all this i think, but what?, i've even tried to run cmd as administrator, i restarted my laptop. very strange.
can you post the full log of the script like this:
                        _____    __      ___       _____           _       _
                       |  __ \   \ \    / (_)     / ____|         (_)     | |
                       | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
                       | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
                       | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
                       |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
                       -@RESET_9999---------------------------------|__|-----------
 Choose a mode...
1) MODE.I=  DoVi Convert/Edit/Sync/Inject (Base Layer file + P8/P7/P5 DoVi file to Profile 8)
2) MODE.F=  DoVi Fix/Extract/Info/Verify-Sync-Brightness
3) MODE.H=  DoVi Maker (from HDR10 madVR or HDR10plus)
4) MODE.P=  Profile 7 Input (MKV/BDMV)
5) MODE.B=  Dovi Batch tsMuxer: MKV/MP4 to TS (ST-DV+DD+SUB)
6) MODE.M=  MIXED: Remover/Measurer/Playlist/Audio and more...
7) MODE.M4= MP4_MUXER Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?4
                                           * CHOOSE A MODE *
1) MODE.1= Bluray Disc to Profile 8 or ST Profile 7
2) MODE.2= MKV ST Profile 7 to Profile 8
3) MODE.3= DEMUX MKV Profile 7 ST-DL to DT-DL
4) MODE.4= Back to main menu
Choice? [1,2,3,4]?1
                                         * CHOOSE A WORKFLOW *
1) Workflow.1= Bluray Disc to Profile 8 + DD+
2) Workflow.2= Bluray Disc to Profile 8 + DD+ 7.1 (DEE only)
3) Workflow.3= Bluray Disc to Profile 8
4) Workflow.4= Bluray Disc to Profile 7 Single-Track Dual-Layer
5) Workflow.5= back to main menu
Choice? [1,2,3,4,5]?3
Un sous-répertoire ou un fichier D:\TEMP_folder existe déjà.
--This workflow will convert a dual layer bluray MPLS to profile 8
Drag and drop your BDMV folder and press enter...
Drag and drop the main movie playlist (MPLS) and press enter...
D:\samples\muti.lang.bd\BDMV\PLAYLIST\00000.mpls
Do you want to edit L5... y or n ? and/or press enter...
DGDemux 1.0.0.59 by Donald A. Graft
Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA]
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
'D:\TEMP_folder\EL.hevc': Using the demultiplexer for the format 'HEVC/H.265'.
'D:\TEMP_folder\EL.hevc' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'.
The file 'D:\TEMP_folder\EL.mkv' has been opened for writing.
'D:\TEMP_folder\EL.hevc' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1920/1080.
Progress: 100%
The cue entries (the index) are being written...
Multiplexing took 2 seconds.
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      57. 17.100 / 57. 17.100
  libavcodec     59. 18.100 / 59. 18.100
  libavformat    59. 16.100 / 59. 16.100
  libavdevice    59.  4.100 / 59.  4.100
  libavfilter     8. 24.100 /  8. 24.100
  libswscale      6.  4.100 /  6.  4.100
  libswresample   4.  3.100 /  4.  3.100
  libpostproc    56.  3.100 / 56.  3.100
Input #0, matroska,webm, from 'D:\TEMP_folder\EL.mkv':
  Metadata:
    encoder         : libebml v1.4.2 + libmatroska v1.6.4
  Duration: 00:09:59.89, start: 0.000000, bitrate: 7369 kb/s
  Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
      BPS             : 7367224
      DURATION        : 00:09:59.891000000
      NUMBER_OF_FRAMES: 14383
      NUMBER_OF_BYTES : 552441436
      _STATISTICS_WRITING_APP: mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Side data:
      DOVI configuration record: version: 1.0, profile: 7, level: 3, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6
Output #0, matroska, to 'D:\TEMP_folder\chunk.mkv':
  Metadata:
    encoder         : Lavf59.16.100
  Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
      BPS             : 7367224
    Side data:
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
Press [q] to stop, [?] for help
frame=  942 fps=0.0 q=-1.0 Lsize=   15544kB time=00:00:39.99 bitrate=3183.5kbits/s speed=1.27e+03x
video:15534kB audio:0kB subtitle:0kB other streams:0kB global headers:1kB muxing overhead: 0.065136%
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP_folder\el.chunk.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Parsing RPU file...
Exporting metadata...
Done.
Rewriting file with interleaved EL NALUs..
        1 fichier(s) déplacé(s).
"The script has completed."
kazuma
Post by kazuma » Fri Sep 09, 2022 8:02 pm
RESET_9999 wrote: Fri Sep 09, 2022 7:57 pm
 Choose a mode...
8) Exit
                                           * CHOOSE A MODE *
Choice? [1,2,3,4]?1
00000.m2ts
1 %
2 %
3 %
4 %
5 %
6 %
7 %
8 %
9 %
10 %
11 %
12 %
13 %
14 %
15 %
16 %
17 %
18 %
19 %
20 %
21 %
22 %
23 %
24 %
25 %
26 %
27 %
28 %
29 %
30 %
31 %
32 %
33 %
34 %
35 %
36 %
37 %
38 %
39 %
40 %
41 %
42 %
43 %
44 %
45 %
46 %
47 %
48 %
49 %
50 %
51 %
52 %
53 %
54 %
55 %
56 %
57 %
58 %
59 %
60 %
61 %
62 %
63 %
64 %
65 %
66 %
67 %
68 %
69 %
70 %
71 %
72 %
73 %
74 %
75 %
76 %
77 %
78 %
79 %
80 %
81 %
82 %
83 %
84 %
85 %
86 %
87 %
88 %
89 %
90 %
91 %
92 %
93 %
94 %
95 %
96 %
97 %
98 %
99 %
100 %
Done!
Progress: 100%
  Metadata:
    Metadata:
      BPS             : 7367224
    Side data:
  Metadata:
    Metadata:
      BPS             : 7367224
    Side data:
Stream mapping:
Progress: 100%
Parsing RPU file...
Done.
Choose a mode...
8) Exit
Choice? [1,2,3,4,5,6,7,8]?7
* CHOOSE A MODE *
1) MODE.1= Single-Track (p5, p8, p7)
2) MODE.2= Dual-Track (p7)
3) MODE.3= Demuxer (p5, p8, p7)
4) MODE.4= Apple iOS compatible MP4
5) MODE.5= back to main menu
Choice? [1,2,3,4,5]?2
* CHOOSE A WORFLOW *
1) Workflow.1= HEVC-1(BL) + HEVC-2(EL) + AUDIO + SRT subtitle(optionnal)
2) Workflow.2= MPLS P7 bluray to DT-DL + EAC3 + SRT subtitles(optionnal)
3) Workflow.3= MKV P7 to DT-DL + EAC3 + SRT subtitles(optionnal)
4) Workflow.4= back to main menu
Choice? [1,2,3,4]?1
-- Input can be HEVC/H265 - SRT/AC3/EC3/AAC/DTS/DTSHD/TrueHD
-- If no subtitles, just press enter to skip
Drag and drop BL and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_1_eng.hevc
Drag and drop EL and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_2_und.hevc
Drag and drop your audio file and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_5_eng.ac3
Drag and drop your SRT subtitle file and press enter...D:\Game.of.Thrones.S04E06.The.Laws.of.Gods.and.Men.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.track_25_nld.sup
muxing into a MP4 profile 7 DoVi file. Be patient, it can take a while. 40min+ on slow HDD
Het systeem kan het opgegeven pad niet vinden. (the path cannot be found)
the script has completed...
