Any updates on the CMv2.9 bug on the newer LG TVs?
which mode/workflow did you use? post the mediainfo of your input please
I will compare more movies this weekend, but I'm 99% sure that using the internal player renders better quality (regarless of FEL and lossless audio).
Not only L1 works properly but the colors have a lot more pop.(https://youtu.be/dupNfI8vkPk)
I'll upload the comparisons on my youtube channel: https://www.youtube.com/channel/UCEYM1g ... gPuyd4JL_g
Thanks for the information. I should have mentioned I was asking about FEL playback which the LG C1 cannot play.RESET_9999 wrote: ↑Fri Sep 09, 2022 5:15 pmI will compare more movies this weekend, but I'm 99% sure that using the internal player renders better quality (regarless of FEL and lossless audio).
I've placed an order (but cancelled) an order for the Oppo-203 clone and also returned the Sony x800m2 because of that bug and I was wondering if any playback method existed w/o any bugs (for the LG C1).
i have downloaded a mkv remux of game of thrones episode. if i drag this file to your dovi script, it says no DV found. so i've mux the file with tsmuxer (not the tsmuxer of your link because there is no .exe?) to .ts with the baselayer, dvlayer and truehd. then i've dragged this to your doviscript program, but there is no dv file found.RESET_9999 wrote: ↑Fri Sep 09, 2022 5:15 pmwhich mode/workflow did you use? post the mediainfo of your input please
i'm doing wrong, but what? can you please explain me in steps?
Sounds like your file is dual-track DV (hdr layer + 1080p dv layer) which is not supported in MKV. I see that rarbg did that instead of Single track P7.kazuma wrote: ↑Fri Sep 09, 2022 5:26 pmi have downloaded a mkv remux of game of thrones episode. if i drag this file to your dovi script, it says no DV found. so i've mux the file with tsmuxer (not the tsmuxer of your link because there is no .exe?) to .ts with the baselayer, dvlayer and truehd. then i've dragged this to your doviscript program, but there is no dv file found.
i'm doing wrong, but what? can you please explain in me in steps?
So what you have to do is:
1- Remux the mkv to bluray folder output with tsmuxer ( select only video 1 + 2, AC3).... uncheck TrueHD!
2- Then in my script use: 4-1-3 Go in the new bluray folder, drag and drop the MPLS file ( playlist folder) two times (first-time scan all the playlists, 2nd-time process the movie).
Nop, it doesnt exist
I would say the Shield is the closest of doing it right but because of the red push, it ruins everything.
https://www.youtube.com/watch?v=qeyQWs8JgXo
i did the steps but it not worked. again 'Input file doesnt contain a Dolby Vision track'. and yes the file is from rarbg.RESET_9999 wrote: ↑Fri Sep 09, 2022 5:38 pmSounds like your file is dual-track DV (hdr layer + 1080p dv layer) which is not supported in MKV. I see that rarbg did that instead of Single track P7.kazuma wrote: ↑Fri Sep 09, 2022 5:26 pmi have downloaded a mkv remux of game of thrones episode. if i drag this file to your dovi script, it says no DV found. so i've mux the file with tsmuxer (not the tsmuxer of your link because there is no .exe?) to .ts with the baselayer, dvlayer and truehd. then i've dragged this to your doviscript program, but there is no dv file found.
Well, I don't know what you're doing wrong because it's working (see the gif).
Do it manually with yusesope's tool otherwise:viewtopic.php?f=12&t=18602&start=2970#p96282
i do exactly the same thing. i get the message 'no files can be found', FINDSTR: Cannot open D:\TEMP_folder\rpu-text.jsonRESET_9999 wrote: ↑Fri Sep 09, 2022 6:18 pmWell, I don't know what you're doing wrong because it's working (see the gif).
converting and injecting RPU...Input file doesnt contain a Dolby Vision track'
did you uncheck TrueHD before muxing the bluray folder ?
dgdemux(my script use it to demux) wont work with BDMV that contain a truehd (without core)
yes , i selected ac3 audio. strange...RESET_9999 wrote: ↑Fri Sep 09, 2022 6:26 pmdid you uncheck TrueHD before muxing the bluray folder ?
which episode-season. I'll try
s04e06. but i think the problem is different. very thanks for your input for this noob. my tsmuxer is from this website https://www.videohelp.com/software/tsMuxeR. but you gave me a another link. i think the problem is there. but i can't start you're tsmuxer because there is no tsmuxer.exe gui in it.
yep, that's the problem.kazuma wrote: ↑Fri Sep 09, 2022 6:50 pms04e06. but i think the problem is different. very thanks for your input for this noob. my tsmuxer is from this website https://www.videohelp.com/software/tsMuxeR. but you gave me a another link. i think the problem is there. but i can't start you're tsmuxer because there is no tsmuxer.exe gui in it.
get the latest from GitHub or you can use the one included in my script tool pack (tools folder / tsmuxer GUI).
I see from @RESET_9999 's Playback-Devices C9 should support FEL mp4 and lossy audio.
If you want to do it manually, for example for the
'Game.of.Thrones.S01.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT'
You could try:
1. Extract bl.hevc, el.hevc, audio.ac3
ffmpeg -i remux.mkv -map 0:0 -c copy bl.hevc -map 0:1 -c copy el.hevc -map 0:4 -c copy audio.ac3
mp4muxer -i bl.hevc -i el.hevc -i audio.ac3 -o dual_track_fel.mp4
2. Generate single track BL_EL_RPU.hevc by dovi_tool (yusesope's tool is a little complicated)
dovi_tool mux --bl bl.hevc --el el.hevc
mp4muxer -i BL_EL_RPU.hevc -i audio.ac3 -o single_track_fel.mp4
If both @RESET_9999 's script and above fail, it may because the file is corrupted.
Edit: Oh I see you have already found the problem, cheers.
