MakeMKV Crash - Windows 11
rudydsk@gmail.com
Post by rudydsk@gmail.com »
Since upgrading from MakeMKV v1.17.0 to 1.17.1, my machine reboots during the ripping process. I have only tested it with file based UHD backups (with full folder structure), and it seems to be rebooting the machine at random sections of the UHD. I also tried ripping other UHD files, but I get the same result. I found the following error in the Event Viewer with points to makemkvcon64.exe. As a test, I reverted back to 1.17.0 and the issue has disappeared. It could be related to the operating system (Windows 11), but I thought I would post event log in case it's a bug with the makemkvcon64.exe file:
Level Date and Time Source Event ID Task Category
Information 9/8/2022 11:54:07 AM Windows Error Reporting 1001 None "Fault bucket 1158826428182483897, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: makemkvcon64.exe
P2: 1.17.1.0
P3: 10.0.22000.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
\\?\C:\Users\Username\AppData\Local\Temp\RDRE07D.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.f273d3f8-6646-4966-8dd4-8d43310141bc.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.aad0dace-5b36-4e0e-bf06-29d314a0844c.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.fb1d4895-c539-4410-a3d8-e6b5e4bac58e.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.e1371245-7c35-42cb-a239-4091b13369b5.tmp.txt
These files may be available here:
Analysis symbol:
Rechecking for solution: 0
Report Id: 4c69b45e-c5f0-4740-878c-74d60ef39eed
Report Status: 268435456
Hashed bucket: 00a475afa01fd0b88014fa7f2826d3b9
Cab Guid: 0"
