MakeMKV is saying I need to register but.....
Twinflicks
Post by Twinflicks »
I purchased makemkv last year. I'm trying to use it today and it's telling me I need to register or update. When I updated its asking for my registration number. Is there a way to get this from my purchase? I can't find any info on the makemkv site, unless I'm missing something. Can any give me directions on how to retrieve my registration code?
Re: MakeMKV is saying I need to register but.....
Which version?
Normally, if you update over the top of your current version, it absorbs the registration automagically. But a fresh install needs to have it put in. You would have received an email with the original registration, which still applies to the new copy.
If you have LOST the original email, you can ask the author for a copy. That's best done via email, so no one copies your registration.
Twinflicks
is it the support email address?
support@makemkv.com works, yes. I think... it's been a LONG time since I used it! :)
Twinflicks
i sent an email this morning, still no response.
Instant response isn't something Mike does all the time, unfortunately. Usually a day or two is necessary, sometimes a week. He's been fairly active lately, though...
Twinflicks
I hope so because I'm not using this for perosnal. I have a client that wants to use footage from a disc that's protected and im on a deadline.
Post by d00zah »
You are free to use the beta key while you wait.
viewtopic.php?f=5&t=1053
Twinflicks
Thanks man
Twinflicks
d00zah wrote:
Thu Sep 08, 2022 1:37 am
That didn't work
Post by d00zah »
It's not quite "that time of the month", just yet. Make sure, when copying the key, avoid leading/trailing spaces... just visible characters.
Twinflicks
And still didn't work. Keeps saying trial period over, purchase or input registration code
Post by d00zah »
How are you applying the code? Windows? Code should be fine...
'Help' > 'Register' > paste beta code > 'OK'?
