Brand New Pioneer BDR-212UBK Not Working
leosantare
I just got this new drive from B&H, and it failed to rip a 4K disc. This disc is also brand new and clean.
It reads the disc quickly without any issues but fails to rip. I ripped 2 other 4k discs before this one without any issues.
I ripped this disc before without any issues with my LG WH16NS60. However, my LG WH16NS60 is dead now.
Is there anything I can do before I return this brand-new drive?
Thank you,
Thank you,
- Info.png (155.98 KiB) Viewed 10281 times
- Failed.png (209.2 KiB) Viewed 10281 times
Re: Brand New Pioneer BDR-212UBK Not Working
clean the disc with a very soft lint free microfiber cloth and some water then dry with another.leosantare wrote: Sat Aug 20, 2022 4:36 am I just got this new drive from B&H, and it failed to rip a 4K disc. This disc is also brand new and clean.
Thank you,
leosantare
I did clean the disc as you suggested twice, and still no luck. Is there anything else I can try other than buying another brand-new copy?
Does the Scott Pilgrim 4k have a reputation of being problematic?
Update to 1.02 firmware. It might help. But chances are not high.
leosantare
Well, I was able to rip all my 4k's, (33 titles) with the bdr-212ubk no problem. Except for the Scott Pilgrim 4k and I cleaned it 5 times. It seems strange to me that I was able to rip this disc fine with my LG before it died.
Does the Scott Pilgrim 4k have a reputation of being problematic? In the meantime, I just ordered another brand new copy of this disc.
Thank you,
Thank you,
If you have already ripped it, why are you ripping it again??leosantare wrote: Mon Aug 29, 2022 1:09 am Well, I was able to rip all my 4k's, (33 titles) with the bdr-212ubk no problem. Except for the Scott Pilgrim 4k and I cleaned it 5 times. It seems strange to me that I was able to rip this disc fine with my LG before it died.
Thank you,
leosantare
In case I wasn't clear, I had to format my drive and re-rip all my discs again.
Do others have issues with this particular title?
Thank you,
Thank you,
Don't know about that particular title but it is not that uncommon for a UHD disc to be faulty and require replacing.leosantare wrote: Mon Aug 29, 2022 1:55 am In case I wasn't clear, I had to format my drive and re-rip all my discs again.
Thank you,
leosantare
I got another copy of the 4k title, and it ripped without any issues. Therefore, I have ripped (40) 4k discs on the BDR-212 without any issues. The drive is very quiet.
Thanks for the recommendation billy!
