Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
MadsKvist wrote: Wed Sep 07, 2022 5:51 am Can someone help me out with this label? I don't see SVC NS50+ LG anywhere, it's it still safe to flash it?20220907_070956.jpg
Fine to flash if your unsure get an automated flasher from me or Marty
hart2hart wrote: Wed Sep 07, 2022 4:48 pm Thanks to all. I just purchased 3 LG BU40N and slimline enclosures. Which version of FW is recommended?
1.03 if your unsure how to flash I have an automated flasher that will flash all 3 automatically for you
hart2hart
Post by hart2hart »
Billycar11 wrote: Wed Sep 07, 2022 8:52 pm
Thanks. I flashed drives all the way back to the DOS tools and have used the SDF Flasher several times. I got version 1.3.4 of the flasher tool but when I got to
viewtopic.php?f=19&t=19113
and download the MK firmwares, there is no 1.03 version but instead a 1.04 version in a folder called BU40N-N-Main.
Finally, realized there is a google drive link above link I quoted for all the firmware you need and it has a 1.03MK version. Do I first upgrade to this then to 1.04MK or stay with 1.03MK?
RippyMcRipFace
Post by RippyMcRipFace »
Billycar11 wrote: Wed Sep 07, 2022 8:47 pm
RippyMcRipFace wrote: Tue Sep 06, 2022 8:32 pm I purchased two WH16NS40s and enclosed them in OWC Mercury Pro 5.25s. They are connected via USB to a Windows 11 PC. Flashed both to WH16NS60 1.02MK using GUI SDF. First drive flashed fine and is operating as expected. Second drive flash resulted in "Command produced error code 0x8f062900" and can't seem to load DVDs. It will load BDs. Recommendations?
I’ve tried those two things separately, but not together. Will experiment.
Power off case and unplug it from PC and try again unless you have already done so?
hart2hart wrote: Thu Sep 08, 2022 2:24 am
1.03-MK is in the "MK\old" folder. Don't use 1.04. It is sh*t.
The all you need firmware pack man that why I made it.
hart2hart
Post by hart2hart »
Billycar11 wrote: Wed Sep 07, 2022 8:52 pm 1.03 if your unsure how to flash I have an automated flasher that will flash all 3 automatically for you
hart2hart
Post by hart2hart »
HD Goofnut
Post by HD Goofnut »
Which external drives rip without having to be flashed?
HD Goofnut wrote: Wed Sep 14, 2022 6:40 pm Which external drives rip without having to be flashed?
uhd pioneers but that is already changing new firmware support is needs to be added for the new firmware or maybe it already time for downgrade firmware and mk
SomeUsername
Post by SomeUsername »
Still run into the "No drive tool logic found in SDF.bin" error :?
Got a new BU40N drive:
OS device name: G:
Product: BD-RE BU40N
Revision: 1.04
Serial number:
Firmware date: 2120-05-06 11:42
Harware support: Yes
Firmware support: No
Run the command as described with the image from the "The all you need firmware pack" and even tried to flash the "DE_LG_BU40N_1.00.bin", still the same issue :/
.\makemkvcon64.exe f --all-yes -d G: rawflash enc -i .\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Internal error 0x8d000000
Also followed the troubleshooting steps by opening a regular Blu-ray wihtout any error messages and still get the same error :/
Any ideas?
SomeUsername wrote: Thu Sep 15, 2022 6:27 am in SDF.bin
Any ideas?
What case is your drive in
SomeUsername
Billycar11 wrote: Thu Sep 15, 2022 1:08 pm
Any ideas?
I've bought that cheap one, which was recommended by a friend of mine
https://www.amazon.de/techPulse120-Lauf ... B072WJRK4R
Did some more search and found one of you post, with the recommendation to plugin the drive directly via sata.
I'll try this later when Im back at home
SomeUsername wrote: Thu Sep 15, 2022 2:05 pm
Any ideas?
Yeah I'm guessing this is caused by the case don't try and flash it in there anymore with another cheap case I saw a guy brick his drive he had to send it to me for recovery
SomeUsername
Billycar11 wrote: Thu Sep 15, 2022 2:37 pm
That can brick a drive? Daymn, good to know, ty!
Since dont have any matcha cables/adapters for that slim sata stuff, guess I'm gonna order a Vantec NST-510S3-BK case as recommended in you guide.
Or is there any other (better?) case? I see in your selling thread that you use a different one for the BU40N
Regards and big thanks
