I was wondering if the newest version of MKVToolNix has the ability of performing a mild colour correction for a film? I saw in the V0.70 changelog that it had new colour abilities but am unsure what that means.
Any ideas? Thanks,
Ben.
Video colour correction - MKVToolNix?
ben_uk
Re: Video colour correction - MKVToolNix?
Forgive the thread bump, but does anyone know if it’s possible to do minor colour corrections in this way?
I think this is the bug fix description you're talking about:
The only tool that seems to have anything to do with color is mkvmerge. Either search for the word color on that page or look at section 2.8.
I don't think the MKVToolNix tools are what one would use to make adjustments to color in video. MKV files are just a container and are more or less agnostic to the format of the video inside them. The MKVToolNix tools are intended to manipulate .mkv files. To adjust the color of a video you need tools that work with whatever video format you have.
MKVToolNix GUI: multiplexer: color parameters that are floating point numbers (minimum/maximum luminance, projection pitch/roll/yaw) will only be set to a value during identification if the identification actually contains the property, and not to 0 anymore if it doesn't.I don't think the MKVToolNix tools are what one would use to make adjustments to color in video. MKV files are just a container and are more or less agnostic to the format of the video inside them. The MKVToolNix tools are intended to manipulate .mkv files. To adjust the color of a video you need tools that work with whatever video format you have.
