Post by RESET_9999 » Tue Sep 06, 2022 2:49 pm
xxyz1 wrote:
Tue Sep 06, 2022 8:59 am
Hi guys,
my posts are getting online hours later, so you can't recognized it.... (Because of I'm a new user?)
I tried some with RESET_9999 script, but it didn't work anything.
File: Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
7 > 1 > 1 > drag hevc ENTER > drag eac3 ENTER > no 2nd eac3 ENTER > no subs ENTER
CMD closed nothing happend.
5 > drag MKV ENTER > no 2nd mkv ENTER
What exactly I've to do?
For remind: Try to look DV on OLED LG 55B6D but with mkv files it can't play.
that picture looks like a known problem with some SRT tracks and tsmuxer
The easiest way is to remux your mkv file in tsmuxer directly. no need to use my script if you just want to mux 1 file.
https://github.com/justdan96/tsMuxer/releases
As for 7-1-1, I'll check it out.
sw5163
Post by sw5163 » Tue Sep 06, 2022 4:03 pm
May I ask where did you guys get those P8.1 files? On private tracker?
I have never seen DV other than P7 and P5 on rarbg.
Also I was told ffmpeg/mp4box do not support EAC3/atmos, is that true?
Is there a way to get EAC3/atmos with truly playable atmos in mp4 container?
Many thanks!
Post by RESET_9999 » Tue Sep 06, 2022 4:21 pm
Most of the P8 files I have were converted/synced from P5 web-dl. Most of them are from private trackers indeed.
mp4box has no problem with DD+ Atmos. it can even mux TrueHD and DTS-HD.
There seems to be a way to convert TrueHD to DD+ atmos as well but I don't know how yet. So far I'm only able to extract the atmos metadata to wav from DD+ files.
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Format profile                           : Blu-ray Disc
Codec ID                                 : A_EAC3
Duration                                 : 4 h 2 min
Bit rate                                 : 1 512 kb/s
Channel layout                           : L R C LFE Ls Rs Tfl Tfr
Stream size                              : 2.56 GiB (100%)
Complexity index                         : 16
Number of dynamic objects                : 15
staknhalo
Post by staknhalo » Tue Sep 06, 2022 4:36 pm
I make my own p8 like Reset from p5+hdr10 because otherwise I need to keep separate p5+hdr10 files for each title (for backwards compatibility on devices that can't play p5 or with a player that can't color shift to be backwards compatible) - unlike Reset if I gotta start trimming stuff I just don't bother, I already have to do so much so for mismatches/not easy to do immediately files, I'll just keep p5+hdr10 (which is why I initially had some p5 I wanted to make work with Apple devices)
sw5163
Post by sw5163 » Tue Sep 06, 2022 5:05 pm
Thank you guys for explaining! :)
When I encapsulate EAC3/atmos to mp4 by mp4box, the "Complexity ID" change to "Complexity index: Not present / 15"
I was told it would then not be recognized by Apple. (Not atmos but still EAC3 5.1)
Does that mean you can get base 5.1ac3 + several sky channels wav?
Post by RESET_9999 » Tue Sep 06, 2022 5:41 pm
mux eac3 / THD / DTSHD to mp4 with ffmpeg first than import with mp4box.
it creates wav file like this and it can be encoded to a new eac3 atmos file in DEE. But i dont see any point doing that. Maybe downsizing 768kbps to 448kbps?
https://github.com/VoidXH/Cavern/
General
Complete name                            : D:\test.wav
Format                                   : Wave
Format profile                           : RF64
File size                                : 927 MiB
Duration                                 : 7 min 1 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 18.4 Mb/s
Audio
Format                                   : PCM
Format settings                          : Little / Signed
Codec ID                                 : 1
Bit rate                                 : 18.4 Mb/s
Channel(s)                               : 16 channels
Stream size                              : 927 MiB (100%)
Metadata format                          : ADM, Version 0
Metadata muxing mode                     : axml
Number of programmes                     : 1
Number of contents                       : 2
Number of objects                        : 16
Number of pack formats                   : 16
Number of channel formats                : 16
Number of track UIDs                     : 16
Number of track formats                  : 16
Number of stream formats                 : 16
Programme #1                             : Cavern_Export
 Title                                   : Cavern_Export
 Start                                   : 00:00:00.00000
 End                                     : 00:07:01.92100
 Content #s                              : 1 + 2
Content #1                               : Channels
 Title                                   : Channels
 Mode                                    : Mixed
 Object #s                               : 1
Content #2                               : Objects
 Title                                   : Objects
 Mode                                    : Mixed
 Object #s                               : 2 + 3 + 4 + 5 + 6 + 7 + 8 + 9 + 10 + 11 + 12 + 13 + 14 + 15 + 16
Object #1                                : RoomCentricCenter
 Title                                   : RoomCentricCenter
 Duration                                : 00:07:01.92100
 Pack format #s                          : 1
 Track UID #s                            : 1
Object #2                                : Audio Object 1
 Title                                   : Audio Object 1
 Pack format #s                          : 2
 Track UID #s                            : 2
Object #3                                : Audio Object 2
 Title                                   : Audio Object 2
 Pack format #s                          : 3
 Track UID #s                            : 3
Object #4                                : Audio Object 3
 Title                                   : Audio Object 3
 Pack format #s                          : 4
 Track UID #s                            : 4
Object #5                                : Audio Object 4
 Title                                   : Audio Object 4
 Pack format #s                          : 5
 Track UID #s                            : 5
Object #6                                : Audio Object 5
 Title                                   : Audio Object 5
 Pack format #s                          : 6
 Track UID #s                            : 6
Object #7                                : Audio Object 6
 Title                                   : Audio Object 6
 Pack format #s                          : 7
 Track UID #s                            : 7
Object #8                                : Audio Object 7
 Title                                   : Audio Object 7
 Pack format #s                          : 8
 Track UID #s                            : 8
Object #9                                : Audio Object 8
 Title                                   : Audio Object 8
 Pack format #s                          : 9
 Track UID #s                            : 9
Object #10                               : Audio Object 9
 Title                                   : Audio Object 9
 Pack format #s                          : 10
 Track UID #s                            : 10
Object #11                               : Audio Object 10
 Title                                   : Audio Object 10
 Pack format #s                          : 11
 Track UID #s                            : 11
Object #12                               : Audio Object 11
 Title                                   : Audio Object 11
 Pack format #s                          : 12
 Track UID #s                            : 12
Object #13                               : Audio Object 12
 Title                                   : Audio Object 12
 Pack format #s                          : 13
 Track UID #s                            : 13
Object #14                               : Audio Object 13
 Title                                   : Audio Object 13
 Pack format #s                          : 14
 Track UID #s                            : 14
Object #15                               : Audio Object 14
 Title                                   : Audio Object 14
 Pack format #s                          : 15
 Track UID #s                            : 15
Object #16                               : Audio Object 15
 Title                                   : Audio Object 15
 Pack format #s                          : 16
 Track UID #s                            : 16
PackFormat #1                            : RoomCentricCenter
 TypeDefinition                          : DirectSpeakers
 Channel layout                          : C
 Channel format #s                       : 1
PackFormat #2                            : Cavern_Obj_1
 Title                                   : Cavern_Obj_1
 TypeDefinition                          : Objects
 Channel format #s                       : 2
PackFormat #3                            : Cavern_Obj_2
 Title                                   : Cavern_Obj_2
 Channel format #s                       : 3
PackFormat #4                            : Cavern_Obj_3
 Title                                   : Cavern_Obj_3
 Channel format #s                       : 4
PackFormat #5                            : Cavern_Obj_4
 Title                                   : Cavern_Obj_4
 Channel format #s                       : 5
PackFormat #6                            : Cavern_Obj_5
 Title                                   : Cavern_Obj_5
 Channel format #s                       : 6
PackFormat #7                            : Cavern_Obj_6
 Title                                   : Cavern_Obj_6
 Channel format #s                       : 7
PackFormat #8                            : Cavern_Obj_7
 Title                                   : Cavern_Obj_7
 Channel format #s                       : 8
PackFormat #9                            : Cavern_Obj_8
 Title                                   : Cavern_Obj_8
 Channel format #s                       : 9
PackFormat #10                           : Cavern_Obj_9
 Title                                   : Cavern_Obj_9
 Channel format #s                       : 10
PackFormat #11                           : Cavern_Obj_10
 Title                                   : Cavern_Obj_10
 Channel format #s                       : 11
PackFormat #12                           : Cavern_Obj_11
 Title                                   : Cavern_Obj_11
 Channel format #s                       : 12
PackFormat #13                           : Cavern_Obj_12
 Title                                   : Cavern_Obj_12
 Channel format #s                       : 13
PackFormat #14                           : Cavern_Obj_13
 Title                                   : Cavern_Obj_13
 Channel format #s                       : 14
PackFormat #15                           : Cavern_Obj_14
 Title                                   : Cavern_Obj_14
 Channel format #s                       : 15
PackFormat #16                           : Cavern_Obj_15
 Title                                   : Cavern_Obj_15
 Channel format #s                       : 16
ChannelFormat #1                         : RoomCentricCenter
 Channel layout                          : C
 Type                                    : Static
ChannelFormat #2                         : Cavern_Obj_1
ChannelFormat #3                         : Cavern_Obj_2
ChannelFormat #4                         : Cavern_Obj_3
ChannelFormat #5                         : Cavern_Obj_4
ChannelFormat #6                         : Cavern_Obj_5
ChannelFormat #7                         : Cavern_Obj_6
ChannelFormat #8                         : Cavern_Obj_7
ChannelFormat #9                         : Cavern_Obj_8
ChannelFormat #10                        : Cavern_Obj_9
ChannelFormat #11                        : Cavern_Obj_10
ChannelFormat #12                        : Cavern_Obj_11
ChannelFormat #13                        : Cavern_Obj_12
ChannelFormat #14                        : Cavern_Obj_13
ChannelFormat #15                        : Cavern_Obj_14
ChannelFormat #16                        : Cavern_Obj_15
TrackUID #1                              : ATU_00001001
 Bit depth                               : 24
 Sampling rate                           : 48000
 Track index                             : 1
 Pack format #s                          : 1
 Track format #s                         : 1
TrackUID #2                              : ATU_00001002
 Bit depth                               : 24
 Track index                             : 2
 Pack format #s                          : 2
 Track format #s                         : 2
TrackUID #3                              : ATU_00001003
 Bit depth                               : 24
 Track index                             : 3
 Pack format #s                          : 3
 Track format #s                         : 3
TrackUID #4                              : ATU_00001004
 Bit depth                               : 24
 Track index                             : 4
 Pack format #s                          : 4
 Track format #s                         : 4
TrackUID #5                              : ATU_00001005
 Bit depth                               : 24
 Track index                             : 5
 Pack format #s                          : 5
 Track format #s                         : 5
TrackUID #6                              : ATU_00001006
 Bit depth                               : 24
 Track index                             : 6
 Pack format #s                          : 6
 Track format #s                         : 6
TrackUID #7                              : ATU_00001007
 Bit depth                               : 24
 Track index                             : 7
 Pack format #s                          : 7
 Track format #s                         : 7
TrackUID #8                              : ATU_00001008
 Bit depth                               : 24
 Track index                             : 8
 Pack format #s                          : 8
 Track format #s                         : 8
TrackUID #9                              : ATU_00001009
 Bit depth                               : 24
 Track index                             : 9
 Pack format #s                          : 9
 Track format #s                         : 9
TrackUID #10                             : ATU_0000100a
 Bit depth                               : 24
 Track index                             : 10
 Pack format #s                          : 10
 Track format #s                         : 10
TrackUID #11                             : ATU_0000100b
 Bit depth                               : 24
 Track index                             : 11
 Pack format #s                          : 11
 Track format #s                         : 11
TrackUID #12                             : ATU_0000100c
 Bit depth                               : 24
 Track index                             : 12
 Pack format #s                          : 12
 Track format #s                         : 12
TrackUID #13                             : ATU_0000100d
 Bit depth                               : 24
 Track index                             : 13
 Pack format #s                          : 13
 Track format #s                         : 13
TrackUID #14                             : ATU_0000100e
 Bit depth                               : 24
 Track index                             : 14
 Pack format #s                          : 14
 Track format #s                         : 14
TrackUID #15                             : ATU_0000100f
 Bit depth                               : 24
 Track index                             : 15
 Pack format #s                          : 15
 Track format #s                         : 15
TrackUID #16                             : ATU_00001010
 Bit depth                               : 24
 Track index                             : 16
 Pack format #s                          : 16
 Track format #s                         : 16
TrackFormat #1                           : PCM_RoomCentricCenter
 Title                                   : PCM_RoomCentricCenter
 FormatDefinition                        : PCM
 LinkedTo_StreamFormat_Pos               : 1
TrackFormat #2                           : PCM_Cavern_Obj_1
 Title                                   : PCM_Cavern_Obj_1
 LinkedTo_StreamFormat_Pos               : 2
TrackFormat #3                           : PCM_Cavern_Obj_2
 Title                                   : PCM_Cavern_Obj_2
 LinkedTo_StreamFormat_Pos               : 3
TrackFormat #4                           : PCM_Cavern_Obj_3
 Title                                   : PCM_Cavern_Obj_3
 LinkedTo_StreamFormat_Pos               : 4
TrackFormat #5                           : PCM_Cavern_Obj_4
 Title                                   : PCM_Cavern_Obj_4
 LinkedTo_StreamFormat_Pos               : 5
TrackFormat #6                           : PCM_Cavern_Obj_5
 Title                                   : PCM_Cavern_Obj_5
 LinkedTo_StreamFormat_Pos               : 6
TrackFormat #7                           : PCM_Cavern_Obj_6
 Title                                   : PCM_Cavern_Obj_6
 LinkedTo_StreamFormat_Pos               : 7
TrackFormat #8                           : PCM_Cavern_Obj_7
 Title                                   : PCM_Cavern_Obj_7
 LinkedTo_StreamFormat_Pos               : 8
TrackFormat #9                           : PCM_Cavern_Obj_8
 Title                                   : PCM_Cavern_Obj_8
 LinkedTo_StreamFormat_Pos               : 9
TrackFormat #10                          : PCM_Cavern_Obj_9
 Title                                   : PCM_Cavern_Obj_9
 LinkedTo_StreamFormat_Pos               : 10
TrackFormat #11                          : PCM_Cavern_Obj_10
 Title                                   : PCM_Cavern_Obj_10
 LinkedTo_StreamFormat_Pos               : 11
TrackFormat #12                          : PCM_Cavern_Obj_11
 Title                                   : PCM_Cavern_Obj_11
 LinkedTo_StreamFormat_Pos               : 12
TrackFormat #13                          : PCM_Cavern_Obj_12
 Title                                   : PCM_Cavern_Obj_12
 LinkedTo_StreamFormat_Pos               : 13
TrackFormat #14                          : PCM_Cavern_Obj_13
 Title                                   : PCM_Cavern_Obj_13
 LinkedTo_StreamFormat_Pos               : 14
TrackFormat #15                          : PCM_Cavern_Obj_14
 Title                                   : PCM_Cavern_Obj_14
 LinkedTo_StreamFormat_Pos               : 15
TrackFormat #16                          : PCM_Cavern_Obj_15
 Title                                   : PCM_Cavern_Obj_15
 LinkedTo_StreamFormat_Pos               : 16
StreamFormat #1                          : PCM_RoomCentricCenter
 Format                                  : PCM
 Pack format #s                          : 1
 Track format #s                         : 1
StreamFormat #2                          : PCM_Cavern_Obj_1
 Format                                  : PCM
 Pack format #s                          : 2
 Track format #s                         : 2
StreamFormat #3                          : PCM_Cavern_Obj_2
 Format                                  : PCM
 Pack format #s                          : 3
 Track format #s                         : 3
StreamFormat #4                          : PCM_Cavern_Obj_3
 Format                                  : PCM
 Pack format #s                          : 4
 Track format #s                         : 4
StreamFormat #5                          : PCM_Cavern_Obj_4
 Format                                  : PCM
 Pack format #s                          : 5
 Track format #s                         : 5
StreamFormat #6                          : PCM_Cavern_Obj_5
 Format                                  : PCM
 Pack format #s                          : 6
 Track format #s                         : 6
StreamFormat #7                          : PCM_Cavern_Obj_6
 Format                                  : PCM
 Pack format #s                          : 7
 Track format #s                         : 7
StreamFormat #8                          : PCM_Cavern_Obj_7
 Format                                  : PCM
 Pack format #s                          : 8
 Track format #s                         : 8
StreamFormat #9                          : PCM_Cavern_Obj_8
 Format                                  : PCM
 Pack format #s                          : 9
 Track format #s                         : 9
StreamFormat #10                         : PCM_Cavern_Obj_9
 Format                                  : PCM
 Pack format #s                          : 10
StreamFormat #11                         : PCM_Cavern_Obj_10
 Format                                  : PCM
 Pack format #s                          : 11
StreamFormat #12                         : PCM_Cavern_Obj_11
 Format                                  : PCM
 Pack format #s                          : 12
StreamFormat #13                         : PCM_Cavern_Obj_12
 Format                                  : PCM
 Pack format #s                          : 13
StreamFormat #14                         : PCM_Cavern_Obj_13
 Format                                  : PCM
 Pack format #s                          : 14
StreamFormat #15                         : PCM_Cavern_Obj_14
 Format                                  : PCM
 Pack format #s                          : 15
StreamFormat #16                         : PCM_Cavern_Obj_15
 Format                                  : PCM
 Pack format #s                          : 16
Transport #1                             : Yes
 Track index #1                          : ATU_00001001
  Track UID #s                           : 1
 Track index #2                          : ATU_00001002
  Track UID #s                           : 2
 Track index #3                          : ATU_00001003
  Track UID #s                           : 3
 Track index #4                          : ATU_00001004
  Track UID #s                           : 4
 Track index #5                          : ATU_00001005
  Track UID #s                           : 5
 Track index #6                          : ATU_00001006
  Track UID #s                           : 6
 Track index #7                          : ATU_00001007
  Track UID #s                           : 7
 Track index #8                          : ATU_00001008
  Track UID #s                           : 8
 Track index #9                          : ATU_00001009
  Track UID #s                           : 9
 Track index #10                         : ATU_0000100a
  Track UID #s                           : 10
 Track index #11                         : ATU_0000100b
  Track UID #s                           : 11
 Track index #12                         : ATU_0000100c
  Track UID #s                           : 12
 Track index #13                         : ATU_0000100d
  Track UID #s                           : 13
 Track index #14                         : ATU_0000100e
  Track UID #s                           : 14
 Track index #15                         : ATU_0000100f
  Track UID #s                           : 15
 Track index #16                         : ATU_00001010
  Track UID #s                           : 16
sw5163
Post by sw5163 » Tue Sep 06, 2022 5:47 pm
I see it can't fully process TrueHD/atmos yet.
My bad, I just keep thinking get 16 channel PCM from TrueHD/atmos.
ffmpeg copy eac3/atmos to mp4 breaks "complexity index" in the first place.
mp4box -add eac3/atmos directly from atmos.mp4 also breaks "complexity index".
I have managed to fix/restore "complexity index" by
mp4muxer -i atmos.ec3 -o atmos.mp4
mp4box -add dv.hevc dv.mp4
mp4mux(bento4) --track dv.mp4 --track atmos.mp4 merged.mp4
It has correct media info.
But I have no idea would it trigger atmos successfully.
The guy sending message to me on PLEX forum is just disappeared.
Update: He said it works.
Post by RESET_9999 » Tue Sep 06, 2022 6:18 pm
right, I only use FFmpeg for THD and DTS to mp4 then mp4box.
for ec3 its mp4muxer + mp4box
sw5163
Post by sw5163 » Tue Sep 06, 2022 6:48 pm
Yes I have tried mp4muxer + mp4box,
even directly extract from atmos.mp4 will break the "Complexity index".
For example in atmos.mp4 produced by mp4muxer:
mp4box -add atmos.mp4 -new parse_by_mp4box.mp4
Complexity index : Not present / 16
I was wondering what other devices (TV's internal player, Bluray player) react to "Complexity index : Not present / 16".
If it's just ATV can't play it as atmos, then Apple is ridiculous.
Post by RESET_9999 » Tue Sep 06, 2022 6:53 pm
it works on my TV, i already tried and i never actually noticed that the complexity index was gone after muxing with mp4box. lol
if you look at all the DV mp4 with atmos on rarbg they also are the same.
Post by RESET_9999 » Tue Sep 06, 2022 6:56 pm
remuxed the mp4 in tsmuxer or mkvtoolnix and the Complexity index is back to normal, so i dont think it really matters (except for apple as usual haha)
sw5163
Post by sw5163 » Tue Sep 06, 2022 7:01 pm
F* Apple
Post by RESET_9999 » Tue Sep 06, 2022 7:02 pm
Hi guys,
Hi, Try 1.5.5.
7-1-1 should be fixed. Let me know if you find other bugs in the mp4muxer, I never really use it.
But for LG TV playback i recommend tsmuxer. Faster and playback is more stable than mp4.
realbabilu
Post by realbabilu » Wed Sep 07, 2022 4:23 am
F* Apple
haye you tried subler ?
xxyz1
Post by xxyz1 » Wed Sep 07, 2022 6:11 am
@RESET_9999
Yeah, now it created an mp4 and the first time, the LG play it in DV!
But still some things.
Is it possible to select the tracks which should be muxed?
There are 2 audiotracks, only the eng was muxed, not the ger.
The correct german forced sub was muxed (luck?) and the TV shows it, but in mediainfo the "forced flag" is set to no. Anyway it's working, so if it's working on every file correctly, thats not a problem.
The ts / m2ts file that tsmuxer creates is not working on the 2016 OLED TV.(When I drag the input mkv file into it and let it mux)
In tsmuxer you can't set a forced flag to subs and converts srt to sub.
