sw5163
#7306 Post by sw5163 » Tue Sep 06, 2022 6:48 pm
RESET_9999 wrote: Tue Sep 06, 2022 6:18 pm right, I only use FFmpeg for THD and DTS to mp4 then mp4box.
for ec3 its mp4muxer + mp4box
Yes I have tried mp4muxer + mp4box,
even directly extract from atmos.mp4 will break the "Complexity index".
For example in atmos.mp4 produced by mp4muxer:
Complexity index : 16
mp4box -add atmos.mp4 -new parse_by_mp4box.mp4
Complexity index : Not present / 16
I was wondering what other devices (TV's internal player, Bluray player) react to "Complexity index : Not present / 16".
If it's just ATV can't play it as atmos, then Apple is ridiculous.
#7307 Post by RESET_9999 » Tue Sep 06, 2022 6:53 pm
sw5163 wrote: Tue Sep 06, 2022 6:48 pm mp4box -add atmos.mp4 -new parse_by_mp4box.mp4
it works on my TV, i already tried and i never actually noticed that the complexity index was gone after muxing with mp4box. lol
if you look at all the DV mp4 with atmos on rarbg they also are the same.
#7308 Post by RESET_9999 » Tue Sep 06, 2022 6:56 pm
remuxed the mp4 in tsmuxer or mkvtoolnix and the Complexity index is back to normal, so i dont think it really matters (except for apple as usual haha)
sw5163
#7309 Post by sw5163 » Tue Sep 06, 2022 7:01 pm
RESET_9999 wrote: Tue Sep 06, 2022 6:56 pm except for apple as usual haha
F* Apple
#7310 Post by RESET_9999 » Tue Sep 06, 2022 7:02 pm
xxyz1 wrote: Tue Sep 06, 2022 8:59 am Hi guys,
Hi, Try 1.5.5.
7-1-1 should be fixed. Let me know if you find other bugs in the mp4muxer, I never really use it.
But for LG TV playback i recommend tsmuxer. Faster and playback is more stable than mp4.
realbabilu
#7311 Post by realbabilu » Wed Sep 07, 2022 4:23 am
sw5163 wrote: Tue Sep 06, 2022 7:01 pm
F* Apple
haye you tried subler ?
xxyz1
#7312 Post by xxyz1 » Wed Sep 07, 2022 6:11 am
@RESET_9999
Yeah, now it created an mp4 and the first time, the LG play it in DV!
But still some things.
Is it possible to select the tracks which should be muxed?
There are 2 audiotracks, only the eng was muxed, not the ger.
The correct german forced sub was muxed (luck?) and the TV shows it, but in mediainfo the "forced flag" is set to no. Anyway it's working, so if it's working on every file correctly, thats not a problem.
The ts / m2ts file that tsmuxer creates is not working on the 2016 OLED TV.(When I drag the input mkv file into it and let it mux)
In tsmuxer you can't set a forced flag to subs and converts srt to sub.
#7313 Post by RESET_9999 » Wed Sep 07, 2022 12:02 pm
xxyz1 wrote: Wed Sep 07, 2022 6:11 am Is it possible to select the tracks which should be muxed?
If you demux the mkv and you select 7-1-1, you can input any audio (up to 2) and any SRT (up to 2). Just make sure your hevc file doesn't have the same filename/path as the original MKV
for the other mp4muxer workflows, you have to edit the bat file with notepad and set the desired language. I didn't really test that though.
I could be wrong but I don't think you can set a forced flag with the mp4muxer/mp4box
I see. You might run into the green screen issue with some DV file on 2016 lg oled TVs
xxyz1
#7314 Post by xxyz1 » Wed Sep 07, 2022 1:53 pm
I edit the language and it works for the audio.
Thank you.
How can I pause the script after demuxing and before muxing?
For example I can editing the subtitles before muxing.
The tags (if it's german or englisch audio "eng" "deu" ect.) of the video / audio / subtitle doesn't work but this is wayne :mrgreen:
And the TV is not allowing to REW or FF the mp4 file. It's OK, because I can skip with the arrows.
I don't have this green screen but it says, Can'T play file. Or it plays the HDR10 only.
sw5163
#7315 Post by sw5163 » Wed Sep 07, 2022 2:23 pm
realbabilu wrote: Wed Sep 07, 2022 4:23 am haye you tried subler ?
Subler is fine, does everything as they suppose to be.
However it's only on Mac.
sw5163
#7316 Post by sw5163 » Wed Sep 07, 2022 5:31 pm
RESET_9999 wrote: Wed Sep 07, 2022 12:02 pm I could be wrong but I don't think you can set a forced flag with the mp4muxer/mp4box
I think
mp4box -add sub.srt:txtflags=0xC0000000
can set the forced tag for sub in mp4.
RESET_9999 wrote: Wed Sep 07, 2022 12:02 pm I see. You might run into the green screen issue with some DV file on 2016 lg oled TVs
If it's the same green screen issue caused by additional "reshaping data" like on Apple, just use dovi_tool to "remove_mapping".
#7317 Post by RESET_9999 » Wed Sep 07, 2022 6:24 pm
xxyz1 wrote: Wed Sep 07, 2022 1:53 pm The tags (if it's german or englisch audio "eng" "deu" ect.) of the video / audio / subtitle doesn't work but this is wayne :mrgreen:
not sure i understand what you mean.
you can't, sorry. Just have your files ready before running the script.
sw5163 wrote: Wed Sep 07, 2022 5:31 pm I think
thanks, will try.
sw5163 wrote: Wed Sep 07, 2022 5:31 pm If it's the same green screen issue caused by additional "reshaping data" like on Apple, just use dovi_tool to "remove_mapping".
yea maybe it's the same issue. I remember this was reported in the very early days of the mp4muxer when only dual-layer dolby vision rip was possible.
IIRC it was all the 4000nits P3 BL that had the issue.
xxyz1
#7318 Post by xxyz1 » Wed Sep 07, 2022 9:14 pm
RESET_9999 wrote: Wed Sep 07, 2022 6:24 pm
I mean the is no language tag.
Ok, can I manual muxing after use your script for demuxing?
What's the muxing script with
1 video stream DV 08.06
1 eac3 or ac3 audio stream
1 srt forced flag subtitle
looks like?
sw5163
#7319 Post by sw5163 » Wed Sep 07, 2022 9:46 pm
xxyz1 wrote: Wed Sep 07, 2022 9:14 pm What's the muxing script with
looks like?
mp4box -add dv.hevc -add audio.ec3:lang=eng -add sub.srt:lang=ger:txtflags=0xC0000000 -new p5.dvh1.mp4
or if you want proper P8.1
mp4box -add dv.hevc:dv-profile=8.1 -add audio.ec3:lang=eng -add sub.srt:lang=ger:txtflags=0xC0000000 -new p81.hvc1.mp4
I don't know the exact short tag for german.
If sub and audio are marked with same language tag, sub will default show up in most devices even without the 'forced' flag. So if you just want the sub to default show up, you can deliberately mark it English. I mark all my Chinese sub as eng, lol.
staknhalo
#7320 Post by staknhalo » Thu Sep 08, 2022 12:23 am
just bookmarking for myself, ignore :lol:
