More strange behaviors with BU40N Slim Drive
ThatOneUnit
Post by ThatOneUnit »
Hello!
Looking for some advice on troubleshooting and any potential ideas as to what might fix some strange behavior on a BU40N external slim drive when trying to rip DVDs and UHD discs.
If you have any thoughts on troubleshooting please leave them below.
Thanks for your thoughts in advance! :D
Drive Info:
Strange Behavior:
DVD Issue: Insert DVD into drive; drive spins up to maybe half speed (definitely not full speed); a few seconds of spinning and drive makes three or four sets of quick double ticks/clicks and spins down to a low rpm; drive spins back up to about half speed (same speed as when first inserted) and makes the same quick few sets of double ticks/clicks and spins down to a low rpm; drive does this about a total of (5) times and then stops spinning; no disc is recognized by MKV or Windows 10.
When did this behavior start/what did you do before it started?
--Behavior started recently. Started opening a TV series DVD in MKV -- this took was taking forever (30+minutes) and I hit the 'stop' button in MKV. Took about 30secs-1min to stop 'opening' the DVD. Once opening stopped, MKV popped me on the 'opened' disc menu that had a few options to be ripped. Thought that was odd, but directed the files to the usual rip dump location and hit start. After about 30 seconds no data had been processed/written out (read rate = 0) and the 'remaining time' had gone up to 3 or 4 hours and was climbing -- this is much longer than the typical ~1hr I had seen for other previous TV series discs I had ripped earlier that same day. I hit the 'stop' button, but there was no response from the drive or MKV after about ~1min. In a rush to leave the house and stop this madness, I tried to force close MKV via TaskManager. No such luck as TM would not open. Windows File Explorer even became unresponsive. I decided to shut the PC down as the drive was still spinning at full speed. PC shutdown (soft power off) after a few minutes but the drive was still spinning. Decided to pull it's USB from the PC. Come back later that day to try a different DVD from a different TV series - no luck. This is when the strange behavior started.
Other Notes:
--CD, Bluray, UHD discs all can be read and ripped like normal
--This drive is not new and have ripped a lot of CD, DVD, Bluray, and a few UHD discs.
Re: More strange behaviors with BU40N Slim Drive
Likely the disc
