staknhalo wrote: Fri Sep 02, 2022 9:35 pm Anyone here make DVH1 P5 mp4 on Windows for iOS playback? What are you using for generation with the DVH1 flag? mp4muxer doesn't do it right? Or does it have a flag for it? Not at my desktop ATM with all my stuff so can't easily check.
DVH1 still works on Android/Windows - so for the few P5 I have (because mostly P8 or P7) I'm gonna make them DVH1 (from DVHE) just for 'maximum compatibility).
mp4muxer --dv-profile 5 --input-file BL.hevc --input-file audio.ec3 --dvh1flag 0 --output-file output.mp4
now that the DV bug with cinema mode configuration is fixed on my C2, I can resume testing the internal player VS my x800m2.
With this new firmware, now L1 High contrast no longer clip(Internal & shield). Internal player looks perfect to me but I think I see a better L1 response on the x800m2 since the C2 update. Still quite different though.
staknhalo
Post by staknhalo »
RESET_9999 wrote: Fri Sep 02, 2022 10:26 pmmp4muxer --dv-profile 5 --input-file BL.hevc --input-file audio.ec3 --dvh1flag 0 --output-file output.mp4
thank you
sw5163
Post by sw5163 »
staknhalo wrote: Sat Sep 03, 2022 2:30 am
thank you
Don't use mp4muxer to change dvhe->dvh1 for iOS device.
Currently some files changed this way will lead to black screen on iOS device.(On mac will be fine)
I'm guessing it's because mp4muxer only change codec ID in hex instead of repackaging it.
Same as https://github.com/rixtox/mp4dovi/issues/9
Use mp4box instead
https://www.avsforum.com/threads/apple- ... t-61936696
yusesope wrote: Fri Oct 23, 2020 10:45 am The correct codec ID (for profile 8.1) should be "hvc1" in place of "hev1". But be careful, these boxes are not random: they indicate to the decoder how the information for the initialization of the latter is stored within the file. Changing the header with a hex editor isn't always enough!
yusesope wrote: Sat Oct 24, 2020 10:30 am As I said, very often it is not enough to change the header of a box for the file to be played. QuickTime is perhaps smarter and can retrieve the information needed to initialize the decoder. The iPad player may not be capable of it!
Trees
Post by Trees »
Hello everyone.
After years of lurking, and mastering hybriding 4K films and series, I'm looking to hybrid an RPU taken from an already hybrided film (P5 to P8.1) to a 1080p *.264 codec as opposed to a *.x265/HEVC codec.
I've found that a certain films look much much better in 1080p than they do in 2160p (caps-a-holic can confirm this), the upscaling has been done very poorly.
Is what I'm asking possible at all with public tools? I am not able to get content directly from streaming services so I'm relying on public tools to get this job done.
Looking forward to your replies.
TL;DR: I want to inject an Dolby Vision P8. 1 RPU into an 1080p film, how?
kazuma
Post by kazuma »
what was the path for eac3to334? i've the program but forgot this.
realbabilu
Post by realbabilu »
DonaldFaQ wrote: Fri Sep 02, 2022 10:06 am 1. If the DV7 mkv extracted using DDVT_DEMUXER with crop off by default. i got rpu.bin that different range (rpu has 280x) as video range (0px)
so i got restarted again with DDVT_DEMUXER, crop on right?
2. When i got the rpu.bin it should be same folder as input mkv right, by using DDVT_INJECTOR to get mkv DV8, right?
3. What the best for budget DV TV: DV 8.1 or DV 8 HLG format from DV7 mkv.
*1 if you demux a P7 single layer file, you have 2 options. First, you can save the RPU only and you can crop this RPU if u will. Second, you can save the BL and the EL layer (or only BL, or only EL). If you save both layers you can build a UHD with TS-Muxer for example. If you crop the RPU and extract that binary, the RPU in the EL layer will be untouched.. Only the own extracted RPU will be edited.
*2 Yes right. If the RPU.bin in the same folder as the input file, RPU inject options will triggered. If a EL.hevc in the same folder, P7 mux settings will be triggered. if a custom.json file in the same folder, this script will be processed during the mux process. Attention! All settings from the custom.json script will be processed BEFORE the intern tool scripts processed.
*3 I don't know. I have an LG OLED TV with a Nvidia Shield pro as player and using HDR + P8. FEL Layers obsolete because no media player supports FEL playback. Exception the Oppo Player (or the clone) with files in ISO format. With this combi you can watch P7 FEL. All other players i know playbacks only MEL .
Hi DonaldFaq
I see DDVT_DEMUXER.cmd is using mp4box for creating / muxing mp4.
I had use crop check for mismatch pixels size in mp4 container.
the result cant be played in my hisense tv. just black.
i demuxed with mp4demuxer, and remux with github dolby mp4muxer, its fine now.
I hope there is a release for choosing mp4box or mp4muxer as a mp4 muxer tools.
staknhalo
Post by staknhalo »
sw5163 wrote: Sat Sep 03, 2022 7:44 am
thank you
Use mp4box instead
thank you
sw5163
Post by sw5163 »
Trees wrote: Sat Sep 03, 2022 8:18 am TL;DR: I want to inject an Dolby Vision P8. 1 RPU into an 1080p film, how?
I don't think x264 supports HDR, so I'm assuming the 1080p track is a SDR one.
If that's the case, you can try muxing it into Profile 8.2 or Profile 9.
However, the result will very likely to be wrong, since it will need "reshaping data" in RPU for SDR->HDR10 colour and PQ change.
For example, from my understanding, P5 RPU has "reshaping data" for ICtCp->YCbCr.
P8.1 RPU doesn't need "reshaping data" for HDR10->HDR10.
P8.4 RPU has "reshaping data" for HLG->PQ.
P7 RPU has "reshaping data" for 4:2:2 12bit to normally play. (I'm not sure what it's really for)
And I think we can only remove "reshaping data" for now rather than adding it.
Therefore, unless you have proper P8.2 RPU or P9 RPU with required "reshaping data" in it, I don't think it's currently possible.
staknhalo
Post by staknhalo »
Hey guys just wanted to say, even though not a HDR capable device - my iPhone 8 Plus displays RPU effects when doing (both native/hybrid) P5 DVH1 - thanks again
Now, another problem/curiosity I never mentioned way back but just remembered - so if anyone here smarter than me on this wants to take a look
I have never seen this before or after when making a P5+HDR10 > Custom P8 - only ever on this one file/episode - and I've done many
WandaVision Ep2 - towards the start, (the entire scene IIRC) where her and Vision are scared of the noise in bed - only when made into a custom P8 there's incorrect strobing/flashing (not from RPU being misaligned, it's different) - I think it has to do with the base being black & white and something with the color shaping properties in a P5 RPU even though that's stripped or something? Or because of the ICtCp having to mimic just black & white but when put onto an actual black & white base layer? Like I said I don't really know, I just know it's something. You can see it on the walls when Vision is talking in bed really IIRC again.
If anyone is interested and can reproduce, I'm curious as to what you find. Might have even been a bug in Dovi_Tool back then, that's since been squashed for all I know or something?
I just ended keeping P5+HDR10 each for this ep myself.
Edit: And this didn't happen with Ep1 that was also black and white - but Ep1 and Ep2 are different styles of black and white - and I understand there's color info in there even though it looks black and white - it was more like specific objects/areas in the scene where strobing/flashing vs the entire screen - like I said, different from RPU misalignment, why I think it had something to do with 'color'
jayper
Post by jayper »
For Mode I, Workflow 1 can you use an MP4 to extract the base layer? The command line states (MKV/TS/M2TS) so I wasn't sure.
jayper wrote: Sun Sep 04, 2022 6:40 pm For Mode I, Workflow 1 can you use an MP4 to extract the base layer? The command line states (MKV/TS/M2TS) so I wasn't sure.
yes
jayper
Post by jayper »
Much appreciated!
redoine322
Post by redoine322 »
Hi Guys i want to ask what is the best way to convert movies to watch it on an internal LG C1 Player DV or HDR and how i can Convert Using your NEW script @RESET_9999 cause things got changed a bit, a big thanks for you amazing work Man
redoine322 wrote: Sun Sep 04, 2022 7:50 pm Hi Guys i want to ask what is the best way to convert movies to watch it on an internal LG C1 Player DV or HDR and how i can Convert Using your NEW script @RESET_9999 cause things got changed a bit, a big thanks for you amazing work Man
DV BDMV input: 4-1-1
DV P7 MKV input: 4-2-3
